查看: 1713|回复: 0
[分享] Remove insertion grip point using overrule
已领礼包: 593个
发表于 2013-6-12 01:37:34 | 显示全部楼层 |阅读模式
Remove insertion grip point using overrule                         By Adam Nagy
If you think that the insertion grip point of a block reference is in the way then you can use GripOverrule to remove it.
The following sample only removes the insertion grip point of dynamic block references:
  1. using System;
  2. using Autodesk.AutoCAD.Runtime;
  3. using Autodesk.AutoCAD.DatabaseServices;
  4. using Autodesk.AutoCAD.Geometry;
  5. namespace ClassLibrary1
  6. {
  7.   public class Commands
  8.   {
  9.     public class MyGripOverrule : GripOverrule
  10.     {
  11.       public override void GetGripPoints(
  12.         Entity entity, GripDataCollection grips,
  13.         double curViewUnitSize, int gripSize,
  14.         Vector3d curViewDir, GetGripPointsFlags bitFlags)
  15.       {
  16.         // It should not be anything else, since we are
  17.         // filtering for block references
  18.         BlockReference br = (BlockReference)entity;
  19.         base.GetGripPoints(entity, grips,
  20.           curViewUnitSize, gripSize,
  21.           curViewDir, bitFlags);
  22.         // We'll only remove it for dynamic blocks
  23.         if (br.IsDynamicBlock)
  24.         {
  25.           GripData toRemove = null;
  26.           foreach (GripData gd in grips)
  27.           {
  28.             if (gd.GripPoint == br.Position)
  29.             {
  30.               toRemove = gd;
  31.               break;
  32.             }
  33.           }
  34.           if (toRemove != null)
  35.             grips.Remove(toRemove);
  36.         }
  37.       }
  38.     }
  39.     [CommandMethod("RemoveInsertionPoint")]
  40.     public static void RemoveInsertionPoint()
  41.     {
  42.       Overrule.AddOverrule(
  43.         RXClass.GetClass(typeof(BlockReference)),
  44.         new MyGripOverrule(), true
  45.       );
  46.       Overrule.Overruling = true;
  47.     }
  48.   }
  49. }
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-3 10:44 , Processed in 0.400536 second(s), 29 queries , Gzip On.
