查看: 1987|回复: 0
[分享] Accessing the properties of a dynamic AutoCAD block using .NET
已领礼包: 6个
发表于 2013-6-12 20:28:33 | 显示全部楼层 |阅读模式
This is one of those funny scenarios... I was just thinking about what to do for my next post - whether to dive into some new features of AutoCAD 2010 (which I will do soon, I promise! :-) or whether to choose something from my ever-increasing to-do list, when I received two emails.
One was from our old friend Fernando Malard, suggesting a topic for a blog post, and the other was from Philippe Leefsma, a member of our DevTech team in Europe, in response to an ADN members question. It provided some code that could eventually form the basis for a response to Fernando's question. Coincidence? Maybe. Am I one to ignore serendipity at work (or to look a gift horse in the mouth)? No!
So, here's Fernando's question:
Just would suggest a new topic for your Blog. An article explaining how to insert a dynamic block and modifying its dynamic properties like point, rotation, dimension. This is something I’m currently working on .NET and I think it would be a very interesting topic to evolve.
Philippe's code is a little different - it shows how to retrieve and display the "dynamic" properties of a dynamic block read in from an external file - but it was a great start for my first step towards Fernando's goal, which was simply to access the dynamic properties for a block selected by the user.
Here's the C# code I based on Philippe's:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace DynamicBlocks
  public class Commands
    [CommandMethod("DBP")]
    static public void DynamicBlockProps()
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      PromptStringOptions pso =
        new PromptStringOptions(
          "\nEnter dynamic block name or enter to select: "
      pso.AllowSpaces = true;
      PromptResult pr = ed.GetString(pso);
      if (pr.Status != PromptStatus.OK)
        return;
      Transaction tr =
        db.TransactionManager.StartTransaction();
      using (tr)
        BlockReference br = null;
        // If a null string was entered allow entity selection
        if (pr.StringResult == "")
          // Select a block reference
          PromptEntityOptions peo =
            new PromptEntityOptions(
              "\nSelect dynamic block reference: "
          peo.SetRejectMessage("\nEntity is not a block.");
          peo.AddAllowedClass(typeof(BlockReference), false);
          PromptEntityResult per =
            ed.GetEntity(peo);
          if (per.Status != PromptStatus.OK)
            return;
          // Access the selected block reference
          br =
            tr.GetObject(
              per.ObjectId,
              OpenMode.ForRead
            ) as BlockReference;
        else
          // Otherwise we look up the block by name
          BlockTable bt =
            tr.GetObject(
              db.BlockTableId,
              OpenMode.ForRead) as BlockTable;
          if (!bt.Has(pr.StringResult))
            ed.WriteMessage(
              "\nBlock \"" + pr.StringResult + "\" does not exist."
            return;
          // Create a new block reference referring to the block
          br =
            new BlockReference(
              new Point3d(),
              bt[pr.StringResult]
        BlockTableRecord btr =
          (BlockTableRecord)tr.GetObject(
            br.DynamicBlockTableRecord,
            OpenMode.ForRead
        // Call our function to display the block properties
        DisplayDynBlockProperties(ed, br, btr.Name);
        // Committing is cheaper than aborting
        tr.Commit();
    private static void DisplayDynBlockProperties(
      Editor ed, BlockReference br, string name
      // Only continue is we have a valid dynamic block
      if (br != null && br.IsDynamicBlock)
        ed.WriteMessage(
          "\nDynamic properties for \"{0}\"\n",
          name
        // Get the dynamic block's property collection
        DynamicBlockReferencePropertyCollection pc =
          br.DynamicBlockReferencePropertyCollection;
        // Loop through, getting the info for each property
        foreach (DynamicBlockReferenceProperty prop in pc)
          // Start with the property name, type and description
          ed.WriteMessage(
            "\nProperty: \"{0}\" : {1}",
            prop.PropertyName,
            prop.UnitsType
          if (prop.Description != "")
            ed.WriteMessage(
              "\n  Description: {0}",
              prop.Description
          // Is it read-only?
          if (prop.ReadOnly)
            ed.WriteMessage(" (Read Only)");
          // Get the allowed values, if it's constrained
          bool first = true;
          foreach (object value in prop.GetAllowedValues())
            ed.WriteMessage(
              (first ? "\n  Allowed values: [" : ", ")
            ed.WriteMessage("\"{0}\"", value);
            first = false;
          if (!first)
            ed.WriteMessage("]");
          // And finally the current value
          ed.WriteMessage(
            "\n  Current value: \"{0}\"\n",
            prop.Value
Here's what happens when we run the DBP command, selecting the "Hex Socket Bolt (Side) - Metric" block from the "Mechanical - Metric.dwg" file in the Samples\Dynamic Blocks folder of your AutoCAD installation.
Command: DBP
Dynamic properties for "Hex Socket Bolt (Side) - Metric"
Property: "d1" : Distance
  Allowed values: ["3", "4", "5", "6", "8", "10", "12", "14", "16", "20", "24",
"27", "30", "36"]
  Current value: "14"
Property: "Origin" : NoUnits (Read Only)
  Current value: "(97.714,-5,0)"
Property: "b" : Distance
  Allowed values: ["18", "20", "22", "24", "28", "32", "36", "40", "44", "52",
"57", "60", "65", "66", "72", "73", "84", "85"]
  Current value: "40"
  Current value: "(100,-3.5,0)"
Property: "k" : Distance
"27", "30", "36"]
  Current value: "14"
  Current value: "(5.64204767561892E-15,-7,0)"
Property: "d2" : Distance
  Allowed values: ["5.5", "7", "8.5", "10", "13", "16", "18", "21", "24", "30",
"36", "40", "45", "54"]
  Current value: "21"
  Current value: "(3.5527136788005E-15,-8,0)"
Property: "Size" : NoUnits
  Allowed values: ["M3", "M4", "M5", "M6", "M8", "M10", "M12", "M14"]
  Current value: "M14"
Property: "Visibility" : NoUnits
Property: "Length (M3)" : Distance
  Description: Set the bolt length
  Allowed values: ["25", "30", "35", "40", "45", "50", "60"]
  Current value: "100"
  Current value: "(0,0,0)"
Property: "Length (M4)" : Distance
  Allowed values: ["30", "35", "40", "45", "50", "60", "70", "80"]
Property: "Length (M5)" : Distance
  Allowed values: ["30", "35", "40", "45", "50", "55", "60", "70", "80", "90",
"100"]
Property: "Length (M6)" : Distance
  Allowed values: ["35", "40", "45", "50", "55", "60", "65", "70", "75", "80",
"90", "100", "110", "120"]
  Current value: "(2.25597318603832E-14,0,0)"
Property: "Length (M8)" : Distance
  Allowed values: ["40", "45", "50", "55", "60", "65", "70", "75", "80", "85",
"90", "100", "110", "120", "130", "140", "150", "160", "180", "200"]
Property: "Length (M10)" : Distance
  Allowed values: ["45", "50", "55", "60", "65", "70", "75", "80", "85", "90",
Property: "Length (M12)" : Distance
  Allowed values: ["55", "60", "65", "70", "75", "80", "85", "90", "100",
Property: "Length (M14)" : Distance
  Allowed values: ["60", "65", "70", "75", "80", "90", "100", "110", "120",
"130", "140", "150", "160"]
Many of the properties are actually 0, but have ended up being printed as a very small number... it would be simple enough to check these against a tolerance rather than trusting them to be understood as being zero.
OK, that's a good enough start for today. In the next post we'll address the need to capture dynamic properties from an inserted dynamic block and copy them across to another, already-inserted dynamic block. A bit like a "property painter" for dynamic blocks. (If you're thinking that this doesn't sound quite like what Fernando originally asked for, then you'd be quite right. We exchanged a few emails, and I then opted for a "property painter" approach to address the problem.)
Thanks for the inspiration, Fernando and Philippe! :-)
GMT+8, 2026-11-3 09:36 , Processed in 0.476619 second(s), 28 queries , Gzip On.
