查看: 2503|回复: 3
[每日一码] Point Manager
已领礼包: 2670个
财富等级: 家财万贯
发表于 2013-6-13 17:58:32 | 显示全部楼层 |阅读模式
Point ManagerProgram Description
This is an extremely versatile program engineered to manipulate point data in many ways. The user may select an input type (the source of the point data) and output type (the result of reading the data from the input object).
The input/output types may be a txt/csv file, a selection of AutoCAD Points, a selection of 3D/LWPolylines, or a selection of blocks. Point (and possibly attribute) data may be read from any of these sources, and subsequently exported to any of the above objects.
The program caters for point data in various formats (xyz, yxz etc) with arbitrary data delimiters (commas, semi-colons etc), and furthermore, the point data may be sorted prior to export.
If the selected output type is an AutoCAD object, various options are supplied to allow control of object Layer and block scale & rotation; these can be altered upon pressing the 'Object Options' button.
If attribute data follows the point data within a txt/csv file, the user may choose to populate block attributes with such data - similarly, attribute data may be extracted to a file from an input type of attributed blocks.
Further guidance is provided upon pressing the 'Help' button.
文件名称:PtManager_V2.4.lsp
下载次数:7  文件大小:68.21 KB
Dialog Preview
Point Format Dialog
Object Options Dialog
已领礼包: 51个
发表于 2013-6-13 18:03:05 | 显示全部楼层
DEAR SIR, THKS..
经过我多年的观察!应该是thx  发表于 2013-6-13 20:05
已领礼包: 1094个
发表于 2022-4-9 06:43:58 | 显示全部楼层
感谢楼主分享!
GMT+8, 2026-11-3 01:48 , Processed in 0.420461 second(s), 38 queries , Gzip On.
