查看: 1340|回复: 4
[求助] 请帮忙改下程序
发表于 2013-6-24 14:59:15 | 显示全部楼层 |阅读模式
1.请将附件中的dcl直接写在lisp中
2.只对单行文字有效
3.不用输命令 双击单行文字直接调用
请会的朋友帮忙改一下,万分感谢~~~
 楼主| 发表于 2013-6-24 15:01:52 | 显示全部楼层
这个是附件 刚才忘记发上来了~
UE.zip
1.32 KB, 下载次数: 7, 下载积分: D豆 -1 , 活跃度 1
发表于 2013-6-24 15:08:51 来自手机 | 显示全部楼层
高版本的快捷属性可以自定义属性的来自: Android客户端
已领礼包: 604个
发表于 2013-6-24 15:13:51 | 显示全部楼层
  1. (defun C:w1 ()
  2. (setq fname (vl-filename-mktemp nil nil ".dcl"))
  3. (setq fn (open fname "w"))
  4. (write-line "edit:dialog" fn)
  5. (write-line "{" fn)
  6. (write-line "  label=\"文字编辑\";" fn)
  7. (write-line "  :edit_box" fn)
  8. (write-line "  {" fn)
  9. (write-line "    label=\"文字:\";" fn)
  10. (write-line "    key=\"edit\";" fn)
  11. (write-line "    edit_width=40;" fn)
  12. (write-line "    allow_accept=true;" fn)
  13. (write-line "  }" fn)
  14. (write-line "  :row" fn)
  15. (write-line "  {" fn)
  16. (write-line "    spacer;" fn)
  17. (write-line "    :errtile" fn)
  18. (write-line "    {" fn)
  19. (write-line "      width=14;" fn)
  20. (write-line "    }" fn)
  21. (write-line "    ok_cancel;" fn)
  22. (write-line "  }" fn)
  23. (write-line "  spacer;" fn)
  24. (write-line "}" fn)
  25. (close fn)
  26. (setq fn (open fname "r"))
  27. (setq dclid (load_dialog fname))
  28. (while (or (eq (substr (setq lin (vl-string-right-trim "\" fn)" (vl-string-left-trim "(write-line \"" (read-line fn)))) 1 2) "//")(eq (substr lin 1 (vl-string-search " " lin)) "")(not (eq (substr lin (+ (vl-string-search " " lin) 1) 9) " : dialog"))))
  29. ;;以下根据情况处理
  30. (new_dialog (substr lin 1 (vl-string-search " " lin)) dclid)
  31. (action_tile "accept" "(done_dialog 1)")
  32. (setq return# (start_dialog))
  33. (unload_dialog dclid)
  34. (close fn)
  35. (vl-file-delete fname)
  36. (princ)
  37. )
评分
参与人数 1D豆 +5 收起 理由
炫翔 + 5 技术引导讨论和指点奖!
查看全部评分
 楼主| 发表于 2013-6-24 18:42:42 | 显示全部楼层
/db_自贡黄明儒_
你好
命令: W1 ERROR : 参数类型错误: numberp: nil
不知道是怎么回事哦,能帮忙看看么
GMT+8, 2026-11-6 23:36 , Processed in 0.546481 second(s), 44 queries , Gzip On.
