查看: 2625|回复: 0
[原创] VB.NET模拟CAD中的椭圆命令(drawjig)
发表于 2013-8-1 22:19:10 | 显示全部楼层 |阅读模式
  1. Option Explicit Off    '隐式声明变量
  2. Imports Autodesk.AutoCAD.ApplicationServices
  3. Imports Autodesk.AutoCAD.DatabaseServices
  4. Imports Autodesk.AutoCAD.EditorInput
  5. Imports Autodesk.AutoCAD.Geometry
  6. Imports Autodesk.AutoCAD.Runtime
  7. Public Class AU_DrawJig
  8.     Inherits Autodesk.AutoCAD.EditorInput.DrawJig
  9.     Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
  10.     Dim db As Database = HostApplicationServices.WorkingDatabase()         '将数据库作为公用函数
  11.     Dim el_pt1, el_pt2, elcen As Point3d : Dim normal As Vector3d = Vector3d.ZAxis '椭圆的轴的两点和Z轴矢量
  12.     Dim elent As Ellipse  '在内存中创建椭圆
  13.     Dim ratio As Double '短轴与长轴的长度比例
  14.     Dim czdst As Double '长半轴距离
  15.     Dim vec As Vector2d : Dim ddd As Double : Dim elmaj, elmaj1 As Vector3d : Dim ang As Double
  16.     Public Shared Function apple_polar3d(ByVal pPt As Point3d, ByVal dAng As Double, ByVal dDist As Double)
  17.         Return New Point3d(pPt.X + dDist * Math.Cos(dAng), pPt.Y + dDist * Math.Sin(dAng), pPt.Z)
  18.     End Function
  19.     <CommandMethod("cc")> _
  20. Public Sub DoJigA()
  21.         '设置轴端点1
  22.         Dim el_ptopt As PromptPointOptions = New PromptPointOptions(vbCrLf & "点取椭圆的轴端点<第一点>:")
  23.         el_ptopt.AllowNone = True '允许回车/空格响应
  24.         Dim respt As PromptPointResult = ed.GetPoint(el_ptopt) '开始动态取值
  25.         If respt.Status = PromptStatus.Cancel Then '如果取消了就退出
  26.             Return
  27.         End If
  28.         el_pt1 = respt.Value '设置椭圆轴端点1
  29.         '设置轴端点2
  30.         Dim el_ptopt1 As PromptPointOptions = New PromptPointOptions(vbCrLf & "点取椭圆的轴端点<第二点>:")
  31.         el_ptopt1.AllowNone = True '允许回车/空格响应
  32.         el_ptopt1.UseBasePoint = True
  33.         el_ptopt1.BasePoint = el_pt1 '使用上一个点作为基点
  34.         Dim respt1 As PromptPointResult = ed.GetPoint(el_ptopt1) '开始动态取值
  35.         If respt1.Status = PromptStatus.Cancel Or el_pt1.DistanceTo(el_pt2) = 0 Then '如果取消了或两点距离为0就退出
  36.             Return
  37.         End If
  38.         el_pt2 = respt1.Value '设置椭圆轴端点2
  39.         elcen = New Point3d((el_pt1.X + el_pt2.X) / 2, (el_pt1.Y + el_pt2.Y) / 2, 0) '得到椭圆圆心,只取平面点,两点的中点
  40.         elmaj = elcen.GetVectorTo(el_pt2) '长轴矢量,起点为圆心,中点为长轴的一个端点
  41.         ratio = 0.0001 '短轴与长轴的长度比例
  42.         czdst = el_pt1.DistanceTo(elcen)  '长轴一半的长度
  43.         ddd = 0.000001
  44.         el_pt12d = New Point2d(el_pt1.X, el_pt1.Y) : el_pt22d = New Point2d(el_pt2.X, el_pt2.Y)
  45.         vec = el_pt12d - el_pt22d   '从A到B的向量
  46.         ang = vec.Angle + Math.PI * 0.5 '角度
  47.         elent = New Ellipse(Point3d.Origin, Vector3d.ZAxis, New Vector3d(0.000001, 0.0, 0.0), 1, 0.0, 0.0) '初始化椭圆
  48.         'If SamplerStatus.Cancel Then
  49.         Using trans As Transaction = db.TransactionManager.StartTransaction()
  50.             Dim bt As BlockTable = DirectCast(trans.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
  51.             Dim btr As BlockTableRecord = DirectCast(trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
  52.             Dim jigRes As PromptResult = ed.Drag(Me)  ' 开始拖动。
  53.             If jigRes.Status = PromptStatus.OK Then
  54.                 ' 将圆对象加入到图形数据库中。
  55.                 btr.AppendEntity(elent)
  56.                 trans.AddNewlyCreatedDBObject(elent, True)
  57.                 trans.Commit()
  58.             End If
  59.         End Using
  60.         'End If
  61.     End Sub
  62.     Protected Overrides Function Sampler(ByVal prompts As JigPrompts) As SamplerStatus
  63.         Dim prOptions2 As New JigPromptDistanceOptions(vbLf & "点取生成椭圆/回车结束:")
  64.         prOptions2.UseBasePoint = True
  65.         prOptions2.BasePoint = elcen               '以椭圆圆心为基点
  66.         prOptions2.Cursor = CursorType.NoSpecialCursor
  67.         myPR = prompts.AcquireDistance(prOptions2) '得到一个距离DOUBLE
  68.         curRat = myPR.Value
  69.         If myPR.Status <> PromptStatus.Cancel Then
  70.             If ddd = curRat Or ddd = 0 Then '数值不能为0
  71.                 Return SamplerStatus.NoChange
  72.             Else
  73.                 If curRat <> 0 Then
  74.                     ddd = curRat
  75.                     ratio = Math.Abs(ddd / czdst) '一定要取绝对值,因为有可能出现负数
  76.                     If ratio > 1 Then
  77.                         elmaj1 = elcen.GetVectorTo(apple_polar3d(elcen, ang, ddd))
  78.                         ratio = 1 / ratio
  79.                         elent.Set(elcen, normal, elmaj1, ratio, 0, 2 * Math.PI)  '更新椭圆参数
  80.                     Else
  81.                         elent.Set(elcen, normal, elmaj, ratio, 0, 2 * Math.PI)  '更新椭圆参数
  82.                     End If
  83.                     Return SamplerStatus.OK
  84.                 Else
  85.                     Return SamplerStatus.NoChange
  86.                 End If
  87.             End If
  88.         Else
  89.             Return SamplerStatus.Cancel  '如果用户按ESC拖拽取消
  90.         End If
  91.     End Function
  92.     Protected Overrides Function WorldDraw(ByVal draw As Autodesk.AutoCAD.GraphicsInterface.WorldDraw) As Boolean
  93.         draw.Geometry.Draw(elent)
  94.         Return True
  95.     End Function
  96. End Class
GMT+8, 2026-11-3 07:34 , Processed in 0.471841 second(s), 32 queries , Gzip On.
