查看: 1696|回复: 3
[老徐讲堂] 一个添加二维多段线顶点的实例(未经调试)
已领礼包: 12个
发表于 2013-8-14 06:11:39 | 显示全部楼层 |阅读模式
  1. static void Asdkaddvertexaddvertex(void)
  2. {
  3.   // Add your code for command Asdkaddvertex.addvertex here
  4.   ads_name ss; ads_point pt,pt1;
  5.   if (acedEntSel(_T("\n选择要加点的二维线:"),ss,pt)!=RTNORM)
  6.   {
  7.    return;
  8.   }
  9.   AcDbObjectId id;
  10.   acdbGetObjectId(id,ss);
  11.   AcDbEntity *pEnt;
  12.   acdbOpenObject(pEnt,id,AcDb::kForWrite);
  13.   if (pEnt->isKindOf(AcDb2dPolyline::desc()))
  14.   {
  15.    if (acedGetPoint(pt,_T("\n指定插入点:"),pt1)!=RTNORM)
  16.    {
  17.     return;
  18.    }
  19.    AcDb2dPolyline *pPline = AcDb2dPolyline::cast(pEnt);
  20.    if (pPline->polyType()!=AcDb::k2dSimplePoly)
  21.    {
  22.     AfxMessageBox(_T("请选择非拟合线!"));
  23.     pEnt->close();
  24.     return;
  25.    }
  26.    AcGePoint3d p0 (pt[X],pt[Y] ,0.0);
  27.    AcGePoint3d p1  (pt1[X],pt1[Y],0.0);
  28.    AcGePoint3d p2;
  29.    pPline->getClosestPointTo(p0,p2);
  30.    double param1(0);
  31.    pPline->getParamAtPoint(p2,param1);
  32.    int n = int (param1)   ;
  33.       AcDbObjectIterator *pVertIter = pPline->vertexIterator();
  34.    AcDb2dVertex *pVertex;
  35.    AcGePoint3d location;
  36.    AcDbObjectId vertexObjId;
  37.
  38.    for (int vertexNumber = 0; !pVertIter->done(); vertexNumber++, pVertIter->step())
  39.    {
  40.     vertexObjId = pVertIter->objectId();
  41.     acdbOpenObject(pVertex, vertexObjId, AcDb::kForRead);
  42.     double bugle = pVertex->bulge();
  43.     double startwidth = pVertex->startWidth();
  44.     double endwidth = pVertex->endWidth();
  45.     double tangen = pVertex->tangent();
  46.     location = pVertex->position();
  47.     if(vertexNumber == n)
  48.     {
  49.       AcDb2dVertex *pNewVertex = new AcDb2dVertex(p1,bugle,startwidth,endwidth,tangen);
  50.
  51.       AcDbObjectId newId;
  52.       pPline->insertVertexAt(newId,vertexObjId,pNewVertex);
  53.       pNewVertex->close();
  54.     }
  55.     pVertex->close();
  56.    }
  57.    delete pVertIter;
  58.
  59.
  60.   }
  61.   else
  62.   {
  63.    AfxMessageBox(_T("请选择二维线!"));
  64.
  65.   }
  66.   pEnt->close();
  67. }
发表于 2013-8-14 08:39:49 | 显示全部楼层
好长~~~~~~
GMT+8, 2026-11-3 09:23 , Processed in 0.394027 second(s), 29 queries , Gzip On.
