查看: 1754|回复: 3
[原创] 删除块属性
已领礼包: 593个
发表于 2013-8-17 11:14:31 | 显示全部楼层 |阅读模式
另外一个帖子http://www.xdcad.net/forum/forum.php?mod=viewthread&tid=459431
  1. (vl-load-com)
  2. (defun c:killatt (/ thisdrawing ss ssl e bn bnl elst obj blocks)
  3.   (setq thisdrawing
  4.   (vla-get-activedocument (vlax-get-acad-object))
  5.   )
  6.   (vla-startundomark thisdrawing)
  7.   (vl-catch-all-apply
  8.     '(lambda (/ ss ssl e bn bnl elst obj blocks)
  9.        (if (setq ss (ssget '((0 . "insert") (66 . 1))))
  10.   (progn
  11.     (setq ssl (sslength ss))
  12.     (while (> ssl 0)
  13.       (setq e  (ssname ss (setq ssl (1- ssl)))
  14.      bn (cdr (assoc 2 (setq el (entget e))))
  15.       )
  16.       (if (member bn bnl)
  17.         nil
  18.         (setq bnl (cons bn bnl))
  19.       )
  20.       (setq
  21.         elst
  22.   (cons
  23.     (vl-remove-if-not
  24.       '(lambda (x)
  25.          (vl-position (car x) '(0 2 8 10 50 41 42 43))
  26.        )
  27.       el
  28.     )
  29.     elst
  30.   )
  31.       )
  32.       (setq blocks (vla-get-blocks thisdrawing))
  33.       (mapcar
  34.         '(lambda (x / i)
  35.     (vlax-for i (vla-item blocks x)
  36.       (if (wcmatch (vla-get-objectname i) "*Attri*")
  37.         (vla-delete i)
  38.       )
  39.     )
  40.   )
  41.         bnl
  42.       )
  43.       (mapcar 'entmake elst)
  44.       (vl-cmdf ".erase" ss "")
  45.       (vla-endundomark thisdrawing)
  46.     )
  47.   )
  48.        )
  49.      )
  50.   )
  51.   (vla-endundomark thisdrawing)
  52.   (princ)
  53. )
  54. (princ
  55.   "\nStart Command With Killatt, eachy[eachy@outlook.com]!"
  56. )
  57. (princ)
发表于 2013-8-17 11:49:12 | 显示全部楼层
好像有点问题。如果选择多个属性块的话会删的只剩一个块:'(
这么快测试出来了?  详情 回复 发表于 2013-8-17 17:46
已领礼包: 685个
发表于 2013-8-17 17:46:27 | 显示全部楼层
这么快测试出来了?
已领礼包: 275个
发表于 2020-12-12 11:03:43 | 显示全部楼层
感谢分享,感谢分享
GMT+8, 2026-11-3 19:10 , Processed in 0.622977 second(s), 35 queries , Gzip On.
