查看: 958|回复: 4
2013-08-20 QQ群:CAD开发高级服务群(325489190) 聊天记录:(defun c:ec4 () (COMMAND "UNDO&qu
发表于 2013-8-20 08:32:15 | 显示全部楼层 |阅读模式
图~涂(443181606)于2013-08-20 08-32-15:
(defun c:ec4 ()
(COMMAND "UNDO" "BE")
(setq p0 (getpoint))
(setq p1 (getpoint))
(setq ang (angle p0 p1))
(if (< ang (/ pi 2))
(progn
(command "insert" "ec1-4" p0 "" "" "")
(command "explode" "l")
(setq ang 100)
)各位前辈 这几句话 肿么个意思呢
发表于 2013-8-20 10:11:48 | 显示全部楼层
月明(24259243)于2013-08-20 10-11-48:
你写的?
发表于 2013-8-20 10:13:01 | 显示全部楼层
月明(24259243)于2013-08-20 10-13-01:
这个没什么用,比我写的差
发表于 2013-8-20 19:55:17 | 显示全部楼层
非(1832727311)于2013-08-20 19-55-17:
今天可有课?
GMT+8, 2026-11-24 10:48 , Processed in 0.191045 second(s), 6 queries , Gzip On, File On.
