查看: 1494|回复: 4
[他山之石] Convert Field to String
发表于 2013-8-21 20:17:38 | 显示全部楼层 |阅读模式
  1. (defun C:CFTT (/ del-field index ss1 item)
  2.   (vl-load-com)
  3.   (defun del-field (ent / edic elist etype obj val)
  4.     (if
  5.       (and
  6. (setq edic (cdr (assoc 360 (setq elist (entget ent)))))
  7. (dictsearch edic "ACAD_FIELD")
  8.       )     ;and
  9.        (progn
  10.   (setq obj   (vlax-ename->vla-object ent)
  11.         etype (cdr (assoc 0 elist))
  12.   )    ;setq
  13.   (cond
  14.     ((= etype "DIMENSION")
  15.      (setq val (vla-get-textoverride obj))
  16.      (dictremove edic "ACAD_FIELD")
  17.      (vla-put-textoverride obj val)
  18.     )
  19.     ((= etype "MTEXT")
  20.      (setq val (vla-get-textstring obj))
  21.      (dictremove edic "ACAD_FIELD")
  22.      (vla-put-textstring obj val)
  23.     )
  24.     (T (dictremove edic "ACAD_FIELD"))
  25.   )    ;cond
  26.        )    ;progn
  27.     )     ;if
  28.   )     ;defun
  29. ;;;----------Convert all selected field text to plain text
  30.   (if
  31.     (setq ss1 (ssget (list (cons 0 "TEXT,MTEXT,MULTILEADER,DIMENSION")
  32.       (cons 67 1)
  33.        )
  34.        )
  35.     )
  36.      (progn
  37.        (setq index 0)
  38.        (repeat (sslength ss1)
  39.   (setq item (ssname ss1 index))
  40.   (if (del-field item)
  41.     (entupd item)
  42.   )
  43.   (setq index (+ 1 index))
  44.        )    ;repeat
  45.      )
  46.      :progn
  47.   )     ;if
  48. ;;;----------Convert all field attributes in blocks to text attributes
  49.   (if
  50.     (setq ss1 (ssget (list (cons 0 "INSERT") (cons 67 1) (cons 66 1))))
  51.      (progn
  52.        (setq index 0)
  53.        (repeat (sslength ss1)
  54.   (setq item (ssname ss1 index))
  55.   (while (= (cdr (assoc 0 (entget (setq item (entnext item)))))
  56.      "ATTRIB"
  57.   )
  58.     (if (del-field item)
  59.       (entupd item)
  60.     )
  61.   )    ;while
  62.   (setq index (+ 1 index))
  63.        )    ;repeat
  64.      )     ;progn
  65.   )     ;if
  66.   (princ)
  67. )     ;defun
发表于 2013-8-21 21:02:56 | 显示全部楼层
API里面也有了 xdrx_text_fieldToText, xdrx_text_removeField
API 的可以用于 Dimension Mtext Attrib 吗?  详情 回复 发表于 2013-8-22 09:12
 楼主| 发表于 2013-8-22 09:12:33 | 显示全部楼层
查了下带field的API, 现在有: xdrx_attrib_fieldLength xdrx_table_FieldId xdrx_table_SetFieldId xdrx_text_FieldToText xdrx_text_removeField  详情 回复 发表于 2013-8-22 09:25
发表于 2013-8-22 09:25:56 | 显示全部楼层
查了下带field的API,
现在有:
xdrx_table_FieldId
这个查询有吗? _$ (vla-fieldcode (vlax-ename->vla-object (entlast))) "%%" _$  详情 回复 发表于 2013-8-22 09:32
 楼主| 发表于 2013-8-22 09:32:09 | 显示全部楼层
newer 发表于 2013-8-22 09:25
查了下带field的API,
现在有:
这个查询有吗?
"%<\\AcObjProp Object(%<\\_ObjId 2129684384>%).Length \\f \"%lu2%pr0\">%"
_$
GMT+8, 2026-10-17 04:59 , Processed in 0.418805 second(s), 38 queries , Gzip On.
