查看: 2493|回复: 2
[他山之石] Field Code - Lee Mac
发表于 2013-8-22 10:08:27 | 显示全部楼层 |阅读模式
  1. ;; Field Code  -  Lee Mac
  2. ;; Returns the field expression associated with an entity
  3. (defun LM:fieldcode ( ent / replacefield replaceobject enx )
  4.     (defun replacefield ( str enx / ent fld pos )
  5.         (if (setq pos (vl-string-search "\\_FldIdx" (setq str (replaceobject str enx))))
  6.             (progn
  7.                 (setq ent (assoc 360 enx)
  8.                       fld (entget (cdr ent))
  9.                 )
  10.                 (strcat
  11.                     (substr str 1 pos)
  12.                     (replacefield (cdr (assoc 2 fld)) fld)
  13.                     (replacefield (substr str (1+ (vl-string-search ">%" str pos))) (cdr (member ent enx)))
  14.                 )
  15.             )
  16.             str
  17.         )
  18.     )
  19.     (defun replaceobject ( str enx / ent pos )
  20.         (if (setq pos (vl-string-search "ObjIdx" str))
  21.             (strcat
  22.                 (substr str 1 (+ pos 5)) " "
  23.                 (LM:ObjectID (vlax-ename->vla-object (cdr (setq ent (assoc 331 enx)))))
  24.                 (replaceobject (substr str (1+ (vl-string-search ">%" str pos))) (cdr (member ent enx)))
  25.             )
  26.             str
  27.         )
  28.     )
  29.
  30.     (if
  31.         (and
  32.             (wcmatch  (cdr (assoc 0 (setq enx (entget ent)))) "TEXT,MTEXT,ATTRIB,MULTILEADER,*DIMENSION")
  33.             (setq enx (cdr (assoc 360 enx)))
  34.             (setq enx (dictsearch enx "ACAD_FIELD"))
  35.             (setq enx (dictsearch (cdr (assoc -1 enx)) "TEXT"))
  36.         )
  37.         (replacefield (cdr (assoc 2 enx)) enx)
  38.     )
  39. )
  40. ;; ObjectID  -  Lee Mac
  41. ;; Returns a string containing the ObjectID of a supplied VLA-Object
  42. ;; Compatible with 32-bit & 64-bit systems
  43. (defun LM:ObjectID ( obj )
  44.     (eval
  45.         (list 'defun 'LM:ObjectID '( obj )
  46.             (if
  47.                 (and
  48.                     (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
  49.                     (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
  50.                 )
  51.                 (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
  52.                '(itoa (vla-get-objectid obj))
  53.             )
  54.         )
  55.     )
  56.     (LM:ObjectID obj)
  57. )
  58. ;; Active Document  -  Lee Mac
  59. ;; Returns the VLA Active Document Object
  60. (defun LM:acdoc nil
  61.     (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
  62.     (LM:acdoc)
  63. )
发表于 2013-8-22 10:34:37 | 显示全部楼层
这个field是怎么添加到实体上的?
对 Text Mtext 用 TextString 就自动解析了, Attrib 好像也是这样, 这个格式自动解释为 Field  详情 回复 发表于 2013-8-22 10:38
 楼主| 发表于 2013-8-22 10:38:06 | 显示全部楼层
newer 发表于 2013-8-22 10:34
这个field是怎么添加到实体上的?
GMT+8, 2026-11-22 08:08 , Processed in 0.323060 second(s), 15 queries , Gzip On, File On.
