查看: 6641|回复: 9
[求助] 关于修改外部参照绝对路径的问题
发表于 2013-9-2 11:47:43 | 显示全部楼层 |阅读模式
插入外部参照或图像后,当初选的是绝对路径,现在想修改为相对路径有什么方法吗?
已领礼包: 987个
发表于 2013-9-2 13:02:53 | 显示全部楼层
(command "_.-xref" "_path" < Xref Name > < New Path >)
< Xref Name >为外部参照名
< New Path >为绝对路径
已经插入了,怎么改?  详情 回复 发表于 2013-9-2 13:43
已领礼包: 1268个
发表于 2013-9-2 13:06:16 来自手机 | 显示全部楼层
..\\filename
已经插入了,在哪里面修改?  详情 回复 发表于 2013-9-2 13:43
 楼主| 发表于 2013-9-2 13:43:12 | 显示全部楼层
< Xref Name >为外部参照名
< New Path >为绝 ...
已经插入了,怎么改?
 楼主| 发表于 2013-9-2 13:43:44 | 显示全部楼层
已经插入了,在哪里面修改?
已领礼包: 987个
发表于 2013-9-10 10:25:04 | 显示全部楼层
;;-------------=={ 相对路径转化为完整路径 }==-------------;;
;;  Converts a Relative XRef path to a Full Path.             ;;
;;  Author: Lee Mac, Copyright  2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  dir  - Directory of the Drawing in which the Xref resides ;;
;;  path - Relative Xref Path                                 ;;
;;  Returns:  Full XRef Path                                  ;;
(defun LM:XRef:Relative->Full ( dir path ) (setq dir (vl-string-right-trim "\\" dir))
  (cond
    ( (eq ".." (substr path 1 2))
      (LM:XRef:Relative->Full
        (substr dir 1 (vl-string-position 92 dir nil t))
        (substr path 4)
    ( (eq "."  (substr path 1 1))
      (strcat dir (substr path 2))
    ( (strcat dir "\\" path) )
已领礼包: 987个
发表于 2013-9-10 10:26:17 | 显示全部楼层
;;-------------=={ 完整路径转换为相对路径 }==-------------;;
;;  Converts a Full XRef path to a Relative Path.             ;;
;;  Arguments:                                                ;;
;;  path - Full Xref Path                                     ;;
;;  Returns:  Relative XRef Path                              ;;
(defun LM:XRef:Full->Relative ( dir path / p q ) (setq dir (vl-string-right-trim "\\" dir))
  (cond
    ( (and
        (setq p (vl-string-position 58  dir))
        (setq q (vl-string-position 58 path))
        (not (eq (strcase (substr dir 1 p)) (strcase (substr path 1 q))))
      path
    ( (and
        (setq p (vl-string-position 92  dir))
        (setq q (vl-string-position 92 path))
      (LM:Xref:Full->Relative (substr dir (+ 2 p)) (substr path (+ 2 q)))
    ( (and
        (eq (strcase dir) (strcase (substr path 1 q)))
      (strcat ".\\" (substr path (+ 2 q)))
    ( (eq "" dir)
      path
    ( (setq p (vl-string-position 92 dir))
      (LM:Xref:Full->Relative (substr dir (+ 2 p)) (strcat "..\\" path))
    ( (LM:Xref:Full->Relative "" (strcat "..\\" path)) )
评分
参与人数 1D豆 +10 收起 理由
XDSoft + 10 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 987个
发表于 2013-9-10 10:28:59 | 显示全部楼层
下面是个完整的程序,可以在相对路径与完整路径之间相互转化。
RepathXrefs 1.0a.lsp
31.92 KB, 下载次数: 132, 下载积分: D豆 -1 , 活跃度 1
命令: REPATHXREFS DOSLib from Robert McNeel & Associates is required. It's available for free at www.mcneel.com. Exiting... 参数类型错误: VLA-OBJECT nil 对于win7 64位的系统 cad2014也是64位的  详情 回复 发表于 2015-5-15 00:04
关键修改还是用的 command xref  详情 回复 发表于 2013-9-10 19:10
已领礼包: 1268个
发表于 2013-9-10 19:10:22 | 显示全部楼层
已领礼包: 51个
发表于 2015-5-15 00:04:03 | 显示全部楼层
命令: REPATHXREFS
对于win7 64位的系统 cad2014也是64位的 运行了出现这个问题,应该怎么办呢
GMT+8, 2026-11-6 05:12 , Processed in 0.510121 second(s), 52 queries , Gzip On.
