查看: 2214|回复: 4
[原创] 查询动态块所有参数
已领礼包: 593个
发表于 2013-9-24 11:08:02 | 显示全部楼层 |阅读模式
  1. (defun IsDYNblock (blkref)
  2.   (and
  3.     (= (vla-get-objectname blkref) "AcDbBlockReference")
  4.     (= (vl-catch-all-apply
  5.      'vlax-get-property
  6.      (list blkref 'isdynamicblock)
  7.        )
  8.        :vlax-true
  9.     )
  10.   )
  11. )
  12. ;;以后写 Setpropertyvalue
  13. (defun GetallDynBlockProperties
  14.        (obj / lisp-value dynproperties Allproperties)
  15.   (defun lisp-value (v)
  16.     (cond
  17.       ((= (type v) 'variant)
  18.        (lisp-value (variant-value v))
  19.       )
  20.       ((= (type v) 'safearray)
  21.        (list (mapcar 'lisp-value (safearray-value v))) ;_Modify by eachy
  22.       )
  23.       (t v)
  24.     )
  25.   )
  26.   (defun Allproperties (lst)
  27.     (mapcar
  28.       '(lambda (x)
  29.      (list (cons "AllowedValues"
  30.              (lisp-value (vla-get-allowedvalues x))
  31.            )
  32.            (cons "Description" (vla-get-description x))
  33.            (cons "PropertyName" (vla-get-propertyname x))
  34.            (cons "ReadOnly" (vla-get-readonly x))
  35.            (cons "Show" (vla-get-show x))
  36.            (cons "UnitsType" (lisp-value (vla-get-unitstype x)))
  37.            (cons "Value" (lisp-value (vla-get-value x)))
  38.      )
  39.        )
  40.       lst
  41.     )
  42.   )
  43.   (if (= (type obj) 'VLA-OBJECT)
  44.     (progn
  45.       (setq dynproperties
  46.          (safearray-value
  47.            (variant-value
  48.          (vla-getdynamicblockproperties obj)
  49.            )
  50.          )
  51.       )
  52.       (list
  53.     dynproperties
  54.     (Allproperties dynproperties)
  55.       )
  56.     )
  57.     (Allproperties obj)
  58.   )
  59. )
  60. (defun c:Getdynallproperties (/ e blkref)
  61.   (if
  62.     (and (setq e (car (entsel "\nPick Insert: ")))
  63.      (setq blkref (vlax-ename->vla-object e))
  64.      (isdynblock blkref)
  65.     )
  66.      (foreach x    (cadr (GetallDynBlockProperties blkref))
  67.        (princ "\n(")
  68.        (foreach    y x
  69.      (princ "\n\t  ")
  70.      (princ y)
  71.        )
  72.        (princ "\n)")
  73.      )
  74.      (princ "\nNot DynBlock!")
  75.   )
  76.   (princ)
  77. )
评分
参与人数 3D豆 +15 收起 理由
xshrimp + 5 很给力!经验;技术要点;资料分享奖!
炫翔 + 5 很给力!经验;技术要点;资料分享奖!
牢固 + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 2671个
财富等级: 家财万贯
发表于 2013-9-24 17:13:22 | 显示全部楼层
Dear Sir, Nice Lisp thx for sharing
Program Description
This program enables a user to quickly obtain important information about any object upon moving the cursor over that object.
There are two modes of use:
  • Standard Mode (DInfo)
  • Layer Isolation Mode (LayIso)
The mode in which the program is running can be determined by the icon next to cursor, when the cursor is in empty space. This mode can be changed by pressing the Tab key whilst running the program.
Furthermore, the size of the program cursor can be altered by either pressing "+" or "-" whilst running the program.
When the cursor is moved over an object in the drawing, the cursor will recognise the object and turn red. Relevant information about the object will be displayed next to the cursor.
文件名称:DInfoV1-5.lsp
下载次数:37  文件大小:22.72 KB
Upon pressing Tab the user can switch to Layer Isolation Mode, in which LayIso will be displayed next to the cursor.
In this mode, the user has the ability to isolate the layer of the object upon clicking on the object.
All the layers can be turned back on by Shift-Clicking anywhere in the drawing.
已领礼包: 2671个
财富等级: 家财万贯
发表于 2013-9-24 17:25:23 | 显示全部楼层
dear sir, nice lisp
my personal suggention use Information about an object is displayed upon the user moving the cursor over the object
已领礼包: 5800个
发表于 2013-9-24 20:16:08 | 显示全部楼层
感谢eachy大侠! 支持eachy大侠!因我未安装API(以后也不准备安装),看到原汁原味的LSP就是亲切!
加载api不等于用来写程序,还可以用来分析数据,或者开阔思路  详情 回复 发表于 2013-9-24 20:31
已领礼包: 593个
 楼主| 发表于 2013-9-24 20:31:50 来自手机 | 显示全部楼层
GMT+8, 2026-11-6 17:56 , Processed in 0.653018 second(s), 49 queries , Gzip On.
