查看: 1189|回复: 0
[原创] 创建一个LAYOUT
已领礼包: 51个
发表于 2013-10-10 22:44:50 | 显示全部楼层 |阅读模式
  1. (defun c:addMyLayout ()
  2.   (vl-load-com)
  3.   (setq acadApp (vlax-get-Acad-object))
  4.   (setq acadDoc (vla-get-ActiveDocument acadApp))
  5.   (setq layouts (vla-get-Layouts acadDoc))
  6.   ;; Delete the layout named "Test" if it exists
  7.   (vlax-for objLayout layouts
  8.     (if (= (vla-get-name objLayout) "Test")
  9.       (progn
  10.         (princ
  11.           (strcat "\nDeleted Layout named "
  12.               (vla-get-name objLayout) "..."
  13.           )
  14.         )
  15.         (vla-delete objLayout) ;delete the Layout
  16.         (vlax-release-object objLayout) ; release the Layout Object
  17.       );progn
  18.     );if
  19.   ) ;vlax-for
  20.   (setq layoutObj (vla-add layouts "Test"))
  21.   ;; Assign Grayscale.CTB to the Layout
  22.   (vla-put-StyleSheet layoutObj "Grayscale.ctb")
  23.   ;; Assign DWF configuration to the Layout
  24.   (if (= (substr (vlax-variant-value (vla-getvariable acadDoc "ACADVER")) 1 2) "15")
  25.     (vla-put-configname layoutObj "PublishToWeb DWF.pc3")
  26.     (vla-put-configname layoutObj "DWF6 ePlot.pc3")
  27.   ) ;if
  28.   ;; Assign Paper Size B to the Layout
  29.   (vla-put-canonicalmedianame
  30.     layoutObj
  31.     "ANSI_expand_B_(11.00_x_17.00_Inches)"
  32.   )
  33.   ;; Make the new Layout Active
  34.   (vla-put-activelayout acadDoc layoutObj)
  35.   ;; Example getting StyleSheet and Configname, not doing anything
  36.   ;; with them here however
  37.   (setq currPStyle (vla-Get-StyleSheet layoutObj))
  38.   (setq currConfig (vla-Get-configname layoutObj))
  39.   (princ)
  40. )
GMT+8, 2026-11-6 16:46 , Processed in 0.395225 second(s), 29 queries , Gzip On.
