查看: 970|回复: 11
2013-10-28 QQ群:CAD-LISP(199191568) 聊天记录:签到
发表于 2013-10-28 15:52:01 | 显示全部楼层 |阅读模式
呆子恒(46053770)于2013-10-28 15-52-01:
签到
 楼主| 发表于 2013-10-28 15:54:52 | 显示全部楼层
小黑脸/db(554710749)于2013-10-28 15-54-52:
签到
 楼主| 发表于 2013-10-28 15:56:21 | 显示全部楼层
快乐之旅(769165365)于2013-10-28 15-56-21:
签到
 楼主| 发表于 2013-10-28 15:59:43 | 显示全部楼层
明天过后(295244813)于2013-10-28 15-59-43:
签到
 楼主| 发表于 2013-10-28 16:11:20 | 显示全部楼层
长河(50973100)于2013-10-28 16-11-20:
签到
 楼主| 发表于 2013-10-28 16:39:19 | 显示全部楼层
www.mc112.com(297454641)于2013-10-28 16-39-19:
签到
 楼主| 发表于 2013-10-28 16:59:36 | 显示全部楼层
海(11813113)于2013-10-28 16-59-36:
签到
 楼主| 发表于 2013-10-28 17:00:22 | 显示全部楼层
34、Pan(471968306)于2013-10-28 17-00-22:
[qqimg]{973F1FE0-C433-EDE0-219C-518746E6C122}.gif[/qqimg]
 楼主| 发表于 2013-10-28 17:19:49 | 显示全部楼层
简简单单(1401589648)于2013-10-28 17-19-49:
签到
 楼主| 发表于 2013-10-28 18:09:24 | 显示全部楼层
度(273888442)于2013-10-28 18-09-24:
请问怎么把多个lisp变成一个呀,,
 楼主| 发表于 2013-10-28 18:09:46 | 显示全部楼层
度(273888442)于2013-10-28 18-09-46:
DEFUN C:ZA () (SETVAR "CMDECHO" 0) (PROMPT "縮放全部") (COMMAND "ZOOM" "A") (PRIN1))
(DEFUN C:ZD () (SETVAR "CMDECHO" 0) (PROMPT "動態縮放") (COMMAND "ZOOM" "D") (PRIN1))
(DEFUN C:ZE () (SETVAR "CMDECHO" 0) (PROMPT "縮放實際畫面") (COMMAND "ZOOM" "E" "ZOOM" "0.95X") (PRIN1))
(DEFUN C:ZS () (SETVAR "CMDECHO" 0) (PROMPT "視窗拉近")(COMMAND "ZOOM" "1.1X") (PRIN1))
(DEFUN C:ZX () (SETVAR "CMDECHO" 0) (PROMPT "視窗拉遠") (COMMAND "ZOOM" "0.9X") (PRIN1))
(DEFUN C:ZW () (SETVAR "CMDECHO" 0) (PROMPT "縮放物件") (COMMAND "ZOOM" "O" ) (PRIN1))
(DEFUN C:ZZ () (SETVAR "CMDECHO" 0) (PROMPT "縮放回前次視窗") (COMMAND "ZOOM" "P") (PRIN1))
(DEFUN C:FW () (SETVAR "CMDECHO" 0) (PROMPT "编辑样条线") (COMMAND "PEDIT") (PRIN1))
(DEFUN C:FI () (SETVAR "CMDECHO" 0) (PROMPT "过滤器") (COMMAND "FILTER") (PRIN1))
(DEFUN C:CC () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND ("COPY" "" "M") (PRIN1))
(DEFUN C:FE () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "PLINE") (PRIN1))
(DEFUN C:FF () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "LINE") (PRIN1))
(DEFUN C:U5 () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "UCS" ) (PRIN1))
(DEFUN C:U7 () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "PLAN" "W" "" ) (PRIN1))
(DEFUN C:U6 () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "PLAN" "" ) (PRIN1))
(DEFUN C:GBB () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "LAYISO") (PRIN1))
(DEFUN C:FD () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "LAYON") (PRIN1))
(DEFUN C:EF () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "EXTEND" ) (PRIN1))
(DEFUN C:FV () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "MIRROR") (PRIN1))
(DEFUN C:VV () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "MOVE") (PRIN1))
(DEFUN C:RT () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "ROTATE" ) (PRIN1))
(DEFUN C:EE () (SETVAR "CMDECHO" 0) (PROMPT "复制") (COMMAND "EXTEND" "") (PRIN1))
GMT+8, 2026-11-24 10:42 , Processed in 0.234331 second(s), 6 queries , Gzip On, File On.
