查看: 1574|回复: 0
[每日一码] (Fy:SetPropertiesFrom)继承属性
发表于 2013-10-30 14:39:21 | 显示全部楼层 |阅读模式
  1. (defun Fy:SetPropertiesFrom (e From / lst el)
  2.   (setq    lst (vl-remove-if-not
  3.           '(lambda (x) (vl-position x '(8 6 62 48 390 39 38 370)))
  4.           (entget from)
  5.         )
  6.     el  (entget e)
  7.   )
  8.   (foreach x lst
  9.     (setq el (subst (assoc (car x) el) x el))
  10.   )
  11.   (entmod el)
  12. )
GMT+8, 2026-11-6 16:46 , Processed in 0.365694 second(s), 29 queries , Gzip On.
