查看: 7938|回复: 8
[求助] 错误: DXF 组不正确: (10)
发表于 2013-10-30 23:19:00 | 显示全部楼层 |阅读模式
(vl-load-com)
(defun c:lj ()
  (lyq-dgxlj)
;;; 等高线连接
(defun lyq-dgxlj ()
  (setq dgxss (ssget '(( 0 . "LWPOLYLINE")(8 . "dgx"))))
  (setq n 0)
  (setq leng 1000)
  (repeat (sslength dgxss)
    (setq ssn (ssname dgxss n))
    (setq ssn (vlax-ename->vla-object ssn))
    (if (< (vla-get-Length ssn) leng)
      (setq leng (vla-get-Length ssn))
    (setq n (1+ n))
  (alert (strcat "请输入不大于最短线段长为:\n" (itoa (fix leng))
                 "的阈值\n*****否则*****后果自负"
  (setq ds (getreal "\n请输入阈值:")) ; 获取最短线长度,设定阈值
  (setq n 0)
  (setq elemin (cdr (assoc 38 (entget (ssname dgxss 0)))))
  (setq elemax (cdr (assoc 38 (entget (ssname dgxss 0)))))
    (setq elevation (cdr (assoc 38 (entget (ssname dgxss n)))))
    (setq elemin (min
                   elemin
                   elevation
    (setq elemax (max
                   elemin
                   elevation
    (setq n (1+ n))
  (setq elevation elemin)
  (while (<= elevation elemax)
    (setq dgxss1 (ssget "x" (list (CONS 0 "LWPOLYLINE")(cons 8 "dgx") (cons 38 elevation))))
    (if (/= dgxss1 nil)
      (lyq-lianjie dgxss1 ds)
    (setq elevation (1+ elevation))
  (princ)
(defun lyq-lianjie(ss ds)
  (setq duandian ())
  (setq n 0)
  (repeat (sslength ss)
    (setq ssn (ssname ss n))
    (setq startp (lyq-startp ssn)
          endp (lyq-endp ssn)
    (setq duandian (cons startp duandian))
    (setq duandian (cons endp duandian))
    (setq n (1+ n))
  )                                       ; 生成端点列表
  (setq n 0)
          endp (lyq-endp ssn)
    (setq duandian (vl-remove startp duandian))
    (setq duandian (vl-remove endp duandian))
    (setq neap (neapoint duandian startp))
    (if (< mdist ds)
      (progn
        (lyq-emove ssn startp neap)
        (setq duandian (vl-remove neap duandian))
    (setq neap (neapoint duandian endp))
    (if (< mdist ds)
      (progn
        (lyq-emove ssn endp neap)
    (setq n (1+ n))
  )                                       ; 移动符合条件的顶点
  (command "pedit" "m" ss "" "j" 0 "")
;;; 返回点表中距离点最近的点
(defun neapoint (pointlist point / m mpoint neap)
  (if (/= pointlist nil)
    (progn
      (setq neap (car pointlist))
      (setq mdist (distance neap point))
      (setq m 0)
      (repeat (length pointlist)
        (setq mpoint (nth m pointlist))
        (setq dist (distance mpoint point))
        (if (> mdist dist)
          (setq neap mpoint
                mdist dist
        (setq m (1+ m))
  neap
;;; 将顶点e1移动至e2
(defun lyq-emove (obj e1 e2 / ent)
  (setq ent (entget obj))
  (setq ent (subst
              (cons '10 e2)
              (cons '10 e1)
              ent
  (entmod ent)
  (entupd obj)
(defun lyq-EndP (lw-obj)
  (lyq-3d->2d (vlax-curve-getendPoint lw-obj))
(defun lyq-StartP (lw-obj)
  (lyq-3d->2d (vlax-curve-getStartPoint lw-obj))
(defun lyq-3d->2d (3dpoint)
  (list (car 3dpoint) (cadr 3dpoint))
测试图.doc
352.27 KB, 下载次数: 0, 下载积分: D豆 -1 , 活跃度 1
已领礼包: 1268个
发表于 2013-10-31 07:57:24 | 显示全部楼层
大致看了下,先不说哪里错误,首先写的太乱,思路不能这样,要这样写,自己测试下
另外,DWG文件压缩为 RAR 再上传
  1. (defun c:tt (/ ss len fuzz sl i el ll s);_变量一定要回收,否则有构造表的时候下次可
  2.      ;能把上次的表内容加进来
  3.   ;;实体列表转为选择集
  4.   (defun ents->ss (el / ss)
  5.     (setq ss (ssadd))
  6.     (foreach x el
  7.       (ssadd x ss)
  8.     )
  9.     ss
  10.   )
  11.   (if (and (setq ss (ssget '((0 . "LWPOLYLINE") (8 . "DGX"))))
  12.     (> (sslength ss) 1) ;_加个判断,一般不会出现
  13.     (setq len (getdist "\n输入最小阀值: "))
  14.     (setq fuzz (getdist "\n输入最小间隙: "))
  15.       ) ;_一次把条件都输入
  16.     (progn
  17.       (setq sl (sslength ss)
  18.      i  sl
  19.       )
  20.       (repeat sl
  21. (setq el (cons (ssname ss (setq i (1- i))) el))
  22.       ) ;_这里仅构造实体列表
  23.       (setq el (vl-remove-if
  24.    '(lambda (x)
  25.       (< (vlax-curve-getdistatparam
  26.     x
  27.     (vlax-curve-getendparam x)
  28.          )
  29.          len
  30.       );_线长这样求
  31.     )
  32.    el
  33.         ) ;_把短线移出
  34.      el (vl-sort el
  35.    '(lambda (e1 e2)
  36.       (< (cdr (assoc 38 (entget e1)))
  37.          (cdr (assoc 38 (entget e2)))
  38.       )
  39.     )
  40.         ) ;_将pline 按标高排序,这样等高线是相邻的
  41.       )
  42.       ;;接下来按标高分组
  43.       (setq ll (list (list (car el))))
  44.       (foreach x el
  45. (if (equal (cdr (assoc 38 (entget x)))
  46.      (cdr (assoc 38 (entget (caar ll))))
  47.      )
  48.    (setq ll (cons (cons x (car ll)) (cdr ll)))
  49.    (setq ll (cons (list (list x)) ll))
  50. ) ;_按标高分成一个个子表
  51.       )
  52.       (foreach x ll;_依次处理每个标高组
  53. (setq s (ents->ss x))
  54. (command ".pedit" "m" s "" "j" fuzz "" "");_忘了哪个版本起有了这个 J 间隙选项
  55.       )
  56.     )
  57.   )
  58.   (princ)
  59. )
跟原来的作用不一样,麻烦测试下  详情 回复 发表于 2013-10-31 10:12
已领礼包: 1268个
发表于 2013-10-31 09:18:37 | 显示全部楼层
如果用等效的 XDAPI + XD-Lisp-Lib 就像下面的程序
  1. (defun c:tt (/ ss len fuzz el s)
  2.   (if (and (setq ss (ssget '((0 . "LWPOLYLINE") (8 . "DGX"))))
  3.            (> (sslength ss) 1) ;_加个判断,一般不会出现
  4.            (setq len (getdist "\n输入最小阀值: "))
  5.            (setq fuzz (getdist "\n输入最小间隙: "))
  6.       )
  7.     (progn
  8.       (XD::Begin)
  9.       (setq el (mapcar '(lambda (x)
  10.                           (list (xdrx_getpropertyvalue x "Elevation") x)
  11.                         )
  12.                         (xdrx_pickset->ents ss)
  13.                 )
  14.             el (XD::List:GroupByIndex el 0)
  15.       )
  16.       (foreach x el
  17.         (setq s (XD::Entity->Pickset x))
  18.         ;;(command-s ".pedit" "m" s "" "j" fuzz "");_高版本用这个更高效
  19.         (vl-cmdf ".pedit" "m" s "" "j" fuzz "")
  20.       )
  21.     )
  22.     (XD::End)
  23.   )
  24.   (princ)
  25. )
 楼主| 发表于 2013-10-31 10:12:57 | 显示全部楼层
另外,DWG文件压缩为 RA ...
跟原来的作用不一样,麻烦测试下
测试图.rar
5.51 KB, 下载次数: 1, 下载积分: D豆 -1 , 活跃度 1
发表于 2013-10-31 10:53:14 | 显示全部楼层
我分享下,用用,好用会回帖。。。。。
已领礼包: 1268个
发表于 2013-10-31 21:17:20 | 显示全部楼层
 楼主| 发表于 2013-11-1 09:21:00 | 显示全部楼层
(defun c:tt (/ myerr olderr ss len fuzz sl i el ll s ents->ss modpl) ;_变量一定要回收,否则有构造表的时候下次可
                                        ;能把上次的表内容加进来
  (defun myerr ()
    (setq *error* olderr
          myerr          nil
    (princ "\n*Cancel!")
    (command ".undo" "end")
    (princ)
  ;;实体列表转为选择集
    (setq ss (ssadd))
    (foreach x el
      (ssadd x ss)
    ss
  (defun modpl (e p tf / el)
    (setq el (entget e))
    (if        tf
      (entmod (subst (list 10 (car p) (cadr p))
                     (assoc 10 el)
                     el
      (entmod (reverse (subst (list 10 (car p) (cadr p))
                              (assoc 10 (reverse el))
                              (reverse el)
      ) ;_一次把条件都输入
    (progn
      (setq olderr  *error*
            *error* myerr
      (command ".undo" "be")
            i  sl
      (repeat sl
      ) ;_这里仅构造实体列表
                 '(lambda (x)
                         x
                       len
                 el
               ) ;_把短线移出
            el (vl-sort        el
                        '(lambda (e1 e2)
      ;;接下来按标高分组
      (if (cdr el)
        (progn
          (foreach x (cdr el)
              (setq ll (cons (list x) ll))
            ) ;_按标高分成一个个子表
          (setq        ll
                 (mapcar '(lambda (x / a b c sp ep lst p1 p2 xx)
                            (setq xx x)
                            (while x
                              (setq a  (car x)
                                    b  (cdr x)
                                    sp (vlax-curve-getstartpoint a)
                                    ep (vlax-curve-getendpoint a)
                              (while b
                                (setq c          (car b)
                                      lst (list
                                            (vlax-curve-getstartpoint c)
                                            (vlax-curve-getendpoint c)
                                (if (setq p1
                                           (vl-remove-if-not
                                             '(lambda (p) (equal sp p fuzz))
                                             lst
                                  (modpl a (car p1) t)
                                (if (setq p2
                                           (vl-remove-if-not
                                             '(lambda (p) (equal ep p fuzz))
                                             lst
                                  (modpl a (car p2) nil)
                                (setq b (cdr b))
                              (setq x (cdr x))
                            xx
                         (vl-remove-if '(lambda (l) (= (length l) 1)) ll)
          (foreach x ll
            (command ".pedit" "m" s "" "j" 0 "")
      (setq *error* olderr)
  (princ)
 楼主| 发表于 2013-11-1 09:25:20 | 显示全部楼层
通过st788796一天的辛苦帮助,终于成型,嘿嘿,非常感谢
已领礼包: 2个
发表于 2020-12-9 09:08:07 | 显示全部楼层
GMT+8, 2026-11-3 19:17 , Processed in 0.611559 second(s), 51 queries , Gzip On.
