查看: 1623|回复: 3
[API建议] 增加(AcDbCurve::Extend)
发表于 2013-11-7 22:10:45 来自手机 | 显示全部楼层 |阅读模式
AcDbCurve::extend (Adesk::Boolean, AcGePoint3d&)
This function extends the curve to the pointtoPoint(in WCS coordinates).
IfextendStart==Adesk::kTrue, then the curve's beginning is extended.
IfextendStart==Adesk::kFalse, then the curve's end is extended.
toPointmust be on the path of the curve,
orAcad::eInvalidInputis returned.ReturnsAcad::eOkif successful.
If not implemented, thenAcad::eNotImplementedis returned.
Otherwise,Acad::eInvalidInputis returned.
In derived classes, this function should be able to determine from theextendStartargument whether to extend the start or end of the curve.
The function must be able to determine if thetoPointpoint is valid to...
发表于 2013-11-7 22:59:59 | 显示全部楼层
已加入,下载试试。
Ok了,有个调试信息没有去掉 选择对象: int 于 es=0T  详情 回复 发表于 2013-11-7 23:15
 楼主| 发表于 2013-11-7 23:15:47 | 显示全部楼层
XDSoft 发表于 2013-11-7 22:59
已加入,下载试试。
Ok了,有个调试信息没有去掉
选择对象: int 于
es=0T
先用吧,下次更新去掉。  详情 回复 发表于 2013-11-7 23:23
发表于 2013-11-7 23:23:15 | 显示全部楼层
st788796 发表于 2013-11-7 23:15
Ok了,有个调试信息没有去掉
选择对象: int 于
es=0T
先用吧,下次更新去掉。
GMT+8, 2026-11-22 09:13 , Processed in 0.311490 second(s), 14 queries , Gzip On, File On.
