查看: 1737|回复: 6
[求助] 新人菜鸟求助 这个程序怎么给图形上黑色??大神快来吧
发表于 2013-11-18 18:51:01 | 显示全部楼层 |阅读模式
如题  不会填充函数 求大神解救
(defun c:spade ()
     (setq pt(getpoint "请输入绘图基点:")
           r(getdist "请输入绘图尺寸:")
     (setq p1(polar pt(- 0 pi) r)
           p2(polar p1 0 (* 2 r))
           p3(polar p2(* 0.5 pi) r)
           p4(polar p3(- 0 pi) (* 2 r))
           p5(polar pt(* 0.5 pi) (* 2 r))
           p6(polar pt(/(* 255 pi) 180) (/ r 2))
           p7(polar pt(/(* 285 pi) 180) (/ r 2))
           p8(polar pt(/(* 240 pi) 180) r)
           p9(polar pt(/(* 300 pi) 180) r)
     (command "pline" p5 p4 "arc" pt "")
     (command "mirror" (entlast) "" p5 pt "n")
     (command "arc" pt p6 p8"")
     (command "arc" pt p7 p9"")
     (command "line" p8 p9"")
已领礼包: 12493个
发表于 2013-11-18 20:53:48 | 显示全部楼层
  1. ;黑桃
  2. (defun c:spade ()
  3. (setvar "CMDECHO" 0)
  4. (setq oldos (getvar "OSMODE"))
  5. (setq pt (getpoint "请输入绘图基点:")
  6.        r (getdist "请输入绘图尺寸:"))
  7. (setq p1 (polar pt pi r) p10 (polar pt 0 (* r 0.02))
  8.        p2 (polar p1 0 (* 2 r)) p11 (polar pt pi (* r 0.02))
  9.        p3 (polar p2 (* 0.5 pi) r)
  10.        p4 (polar p3 pi (* 2 r))
  11.        p5 (polar pt (* 0.5 pi) (* 2 r))
  12.        p6 (polar pt (/ (* 17 pi) 12) (/ r 2))
  13.        p7 (polar pt (/ (* 19 pi) 12) (/ r 2))
  14.        p8 (polar pt (/ (* 4 pi) 3) r)
  15.        p9 (polar pt (/ (* 5 pi) 3) r))
  16. (setvar "OSMODE" 0)
  17. (setq ss (ssadd))
  18. (command "pline" p5 p4 "arc" p11 "")
  19. (ssadd (entlast) ss)
  20. (command "mirror" ss "" p5 pt "n")
  21. (ssadd (entlast) ss)
  22. (command "arc" p11 p6 p8 "")
  23. (ssadd (entlast) ss)
  24. (command "arc" p10 p7 p9 "")
  25. (ssadd (entlast) ss)
  26. (command "line" p8 p9 "")
  27. (ssadd (entlast) ss)
  28. (command "HATCH" "SOLID" ss "")
  29. (setvar "OSMODE" oldos)
  30. (setvar "CMDECHO" 0)
  31. (princ)
  32. )
感谢大神帮助 给跪 回答得很及时 谢谢了  详情 回复 发表于 2013-11-18 21:07
评分
参与人数 1D豆 +5 收起 理由
炫翔 + 5 技术引导讨论和指点奖!
查看全部评分
回复 支持 1 反对 0
已领礼包: 1268个
发表于 2013-11-18 20:16:52 | 显示全部楼层
  1. (defun c:spade (/ pt r p1 p2 p3 p4 p5 p6 p7 p8 p9 ss ss1)
  2.   (if (and (setq pt (getpoint "请输入绘图基点:"))
  3.            (setq r (getdist pt "请输入绘图尺寸:"))
  4.       )
  5.     (progn
  6.       (setq p1 (polar pt (- 0 pi) r)
  7.             p2 (polar p1 0 (* 2 r))
  8.             p3 (polar p2 (* 0.5 pi) r)
  9.             p4 (polar p3 (- 0 pi) (* 2 r))
  10.             p5 (polar pt (* 0.5 pi) (* 2 r))
  11.             p6 (polar pt (/ (* 255 pi) 180) (/ r 2))
  12.             p7 (polar pt (/ (* 285 pi) 180) (/ r 2))
  13.             p8 (polar pt (/ (* 240 pi) 180) r)
  14.             p9 (polar pt (/ (* 300 pi) 180) r)
  15.             ss (ssadd)
  16.             ss1 (ssadd)
  17.       )
  18.       (command "pline" "_none" p5 "_none" p4 "arc" "_none" pt "")
  20.       (command "mirror" (entlast) "" "_none" p5 "_none" pt "n")
  22.       (command "arc" "_none" pt "_none" p6 "_none" p8)
  23.       (ssadd (entlast) ss1)
  24.       (command "arc" "_none" pt "_none" p7 "_none" p9)
  25.       (ssadd (entlast) ss1)
  26.       (command "line" "_none" p8 "_none" p9 "")
  27.       (ssadd (entlast) ss1)
  28.       (command ".-hatch" "P" "Solid" "s" ss "" "")
  29.       (command ".-hatch" "P" "Solid" "s" ss1 "" "")
  30.     )
  31.   )
  32.   (princ)
  33. )
感谢大神 回帖好及时啊 感动  详情 回复 发表于 2013-11-18 20:46
回复 支持 1 反对 0
已领礼包: 1268个
发表于 2013-11-18 19:58:35 | 显示全部楼层
贴图示做什么
已领礼包: 12493个
发表于 2013-11-18 20:11:57 | 显示全部楼层
画的扑克牌的“黑桃”。可ACAD的黑色显示时就是白的。在白底的情况下显示是黑的。
 楼主| 发表于 2013-11-18 20:46:23 | 显示全部楼层
感谢大神 回帖好及时啊 感动
 楼主| 发表于 2013-11-18 21:07:14 | 显示全部楼层
感谢大神帮助  给跪  回答得很及时 谢谢了{:soso_e152:}
GMT+8, 2026-11-6 16:48 , Processed in 0.452245 second(s), 46 queries , Gzip On.
