查看: 1763|回复: 0
[他山之石] 使用LISP过滤指定的扩展数据XDATA
发表于 2013-11-24 18:19:30 | 显示全部楼层 |阅读模式
Using AutoLISP to filter specific extended entity xdata
Issue
How do I create a selection set filter in AutoLISP for a specific xdata value ?
Solution
A wiki help introduces in details on how to manipulate xdata by LISP:
Following is a small code demo. It assumes some entities have been added the xdata named “TEST_APP”. The code wants to filter the entities with the xdata and the data contains one value whose type is 1070 and value is 44.
(defun GetSpecificXdata (appName XdataType XdataValue / ss1 ssr indx sl entLst
theXdata i xl xdatav xdatal)
(setq ss1 (ssget "X" (list (cons -
3 (list (list appName))))))
(if ss1
   (progn
     (setq ssr (ssadd))
     (setq indx 0 sl (sslength ss1))
     (princ (strcat "\nOriginal Xdata Selection Set Length: " (itoasl)))
     (while (< indx sl)
    (setq entLst (entget (ssname ss1 indx) (list appName)))
    (setq theXdata (cdr (assoc '-3 entLst)))
    (setq  i 0 xl (length (setq xdatal (car theXdata))))
    (while (< i xl)
        (if (= (type (setq xdatav (car xdatal))) 'LIST)
         (if (= (car xdatav) XdataType)
              (if (= (cdr xdatav) XdataValue)
               (ssadd (ssname ss1 indx) ssr)
        (setq i (1+ i) xdatal (cdr xdatal) )
      (setq indx (1+ indx))
ssr
(defun TestXdataSelection (/ ss2)
(setq ss2 (GetSpecificXdata "TEST_APP" 1070  44))
(if ss2
     (progn
    (princ (strcat "\nSearched for Application: " "TEST_APP" ",
XData Type: " (itoa 1070) ", XData Value: " (itoa 44)))
    (princ (strcat "\nResultant Selection Set Length: " (itoa (sslength
ss2))))
(princ)
(princ "\nTestXdataSelection loaded, type (TestXdataSelection) to run.")
(princ)
GMT+8, 2026-11-6 15:47 , Processed in 0.400262 second(s), 29 queries , Gzip On.
