查看: 2041|回复: 4
将框选所有图元中的文字小写改为大写
发表于 2013-11-25 20:17:24 | 显示全部楼层 |阅读模式
;命令将框选所有图元中的文字小写改为大写.lsp
(defun c:TT( / n textn textnlst textss)
  ; (command "-style" "方正细等线体" "FZXDXJW.TTF" "1.0" "1.0" "0" "N" "N")
  (setq textss (ssget '((0 . "*text"))))
  (setq n 0)
  (repeat (sslength textss)
    (setq textn (ssname textss n))
    (setq textnlst (entget textn))
    (setq textnlst (subst (cons  1  (strcase (CDR(assoc 1 textnlst)) ))(assoc 1 textnlst) textnlst))
    (entmod textnlst)                                                        `
    (setq n (1+ n))
(princ)
已领礼包: 1268个
发表于 2013-11-25 20:55:40 | 显示全部楼层
对照着普及下API
  1. (defun c:tt (/ ss)
  2.   (if (setq ss (ssget '((0 . "*text"))))
  3.     (mapcar '(lambda (x)
  4.                (xdrx_setpropertyvalue
  5.                  x
  6.                  "Textstring"
  7.                  (strcase (xdrx_getpropertyvalue x "Textstring"))
  8.                )
  9.              )
  10.             (xdrx_pickset->ents ss)
  11.     )
  12.   )
  13.   (princ)
  14. )
已领礼包: 1268个
发表于 2013-11-25 20:58:42 | 显示全部楼层
再借用一个
  1. (defun c:tt ()
  2.   (fy:clearcset)
  3.   (if (ssget '((0 . "*text")))
  4.     (mapcar '(lambda (x)
  5.                (vla-put-textstring x (strcase (vla-get-textstring x)))
  6.              )
  7.             (fy:cset->objs)
  8.     )
  9.   )
  10.   (princ)
  11. )
已领礼包: 1268个
发表于 2013-11-26 07:57:02 来自手机 | 显示全部楼层
更正下,mtext非textstring
已领礼包: 48个
发表于 2020-8-30 20:16:36 | 显示全部楼层
多年前的老帖子,被强大的搜索功能找出来;非常欣慰的是老程序还能使用。
光大写没意思,借花献佛,增加一个开关,可自由设置大、小写。
(defun c:tt1 (/ is is_dx_tt1 note ss)
  (xdrx_begin)
  (setq is t)
  (while is
    (setq note (strcat "\n大写or小写:"
                       (if is_dx_tt1         "小写"         "大写"  )
                       "\n选择文字改大小写[切换(D)] <退出>:"
    ;;不能使用的关键字 A C F G L M P R U W
    (Xdrx_initget "D")
    (Xdrx_initssget Note "D" "" "" "")
    (Setq Ss (Xdrx_ssget ":s" '((0 . "*text"))))
    (cond
      ((null ss) (SETQ is NIL))
      ((= "D" SS) (setq is_dx_tt1 (not is_dx_tt1)))
      (ss
                  (Xdrx_SetpropertyValue
                    x    "TextString"
                    (if is_dx_tt1
                      (strcase (Xdrx_GetpropertyValue x "TextString") t)
                      (strcase (Xdrx_GetpropertyValue x "TextString"))
  (xdrx_end)
  (princ)
GMT+8, 2026-11-3 01:41 , Processed in 0.416401 second(s), 36 queries , Gzip On.
