查看: 2235|回复: 2
[API建议] 增加Layout属性
发表于 2013-11-27 16:50:57 | 显示全部楼层 |阅读模式
getTabOrder
getLayoutName
现在遍历遇到不方便了,还得用 setenttodb + getentdxf
一个 (layoutlist) 函数目前用 API 实现好麻烦
 楼主| 发表于 2013-11-27 21:21:51 | 显示全部楼层
addToLayoutDict
This method adds the layout to the specified database's layout dictionary, and specifies the block table record to use.
getLayoutName
This method gets the user-friendly layout name that is displayed in the tab control. Currently there is no restriction on the name except that the length of the name is limited to 256 characters.
Warning: The caller should not free the returned string.
annoAllVisible
Returns the current ANNOALLVISIBLE value for the database
See the System Variables section of the AutoCAD Command Reference for information on ANNOALLVISIBLE.
This is an AcDbDatabase Header Variable Query Function.
getBlockTableRecordId
This method gets a back pointer to the AcDbLayout's associated AcDbBlockTableRecord. Corresponding methods in AcDbBlockTableRecord implement a forward pointer to the AcDbLayout.
getPreviewImage
This function provides Atil::Image thumbnail of layout as output.
getTabOrder
This method gets the tab order field, which controls the order in which the layouts are displayed in the tab control that is docked to the bottom of the viewport. The tab order should be unique and sequential for each layout in the database.
getTabSelected
This method indicates whether the layout tab is included in the selection set for operations that affect multiple tabs. The user can perform multiple selection via the user interface using shift-click.
getThumbnail
This function provides BITMAP thumbnail of layout as output. Returns Acad::eOk, if thumbnail is successfully set. else error status.
getViewportArray
This function returns an array of AcDbObjectIds of all the AcDbViewports that exist in the AcDbLayout's paperspace. The first ID in the list will be the paperspace viewport. If the list returned is empty, then this AcDbLayout has never been switched to (activated). The list is updated each time a layout is activated, and kept up-to-date while that layout is active (whenever viewports are added or deleted).
initialize
This method will do the behind the scenes work to establish a Paper Space viewport for the layout. This allows a layout to be set up and made ready for other viewports and entities to be put into the layout as well as to set various layout properties.
Returns Acad::eOk if successful; otherwise, returns an AutoCAD error status.
 楼主| 发表于 2013-11-27 21:26:39 | 显示全部楼层
addToLayoutDict
getLayoutName
annoAllVisible
getExtents
getLimits
getPreviewImage
getTabOrder
getTabSelected
getThumbnail
getViewportArray
initialize
GMT+8, 2026-11-22 09:09 , Processed in 0.301992 second(s), 13 queries , Gzip On, File On.
