查看: 1930|回复: 1
[求助] API Mtext的setField属性没有加入
发表于 2013-11-29 22:47:32 | 显示全部楼层 |阅读模式
setField
Adds pField to this object's field dictionary, using pszPropName as the new entry's key. If successful, the new entry's object ID is returned in fieldId.
Returns Acad::eOk if successful.
Acad::ErrorStatus setField(    const ACHAR* pszPropName,     AcDbField* pField,     AcDbObjectId& fieldId);
Parameters
Parameters
Description
Input string to use as the field's dictionary key
AcDbField* pField
Input pointer to the field object to be added
Output object ID of the added field
Description
发表于 2013-11-30 00:01:21 | 显示全部楼层
Text 直接写 Field 表达式即可
GMT+8, 2026-11-22 09:05 , Processed in 0.236945 second(s), 11 queries , Gzip On, File On.
