查看: 2483|回复: 4
[每日一码] 绑定并另存关闭图形
发表于 2013-11-30 18:53:58 | 显示全部楼层 |阅读模式
(defun C:bd (/ a b)
  (gc)
  (command "-xref" "bind" "*")
  (command "vports" "SI")
  (setq a (getvar "DWGPREFIX"))
  (setq        b
         (vl-string-right-trim
           ".dwg"
           (getvar
             "dwgname"
  (vl-load-com)
  (command "saveas"
           "2004"
           (strcat a
                   b
                   "-绑定.dwg"
           )                                ;strcat
  (command "qsave" "close")
发表于 2016-1-25 17:55:49 | 显示全部楼层
好贴!可以作为协同设计提资的基本操作
已领礼包: 28个
发表于 2016-8-12 22:01:52 | 显示全部楼层
好程序,真好用得着
发表于 2016-9-21 18:48:25 | 显示全部楼层
要是能加上保存路径就更完美了
已领礼包: 1094个
发表于 2021-10-3 00:06:05 | 显示全部楼层
感谢分享绑定并另存关闭图形
GMT+8, 2026-11-3 06:03 , Processed in 0.444637 second(s), 43 queries , Gzip On.
