查看: 2194|回复: 3
[每日一码] 线长统计
发表于 2013-11-30 18:54:47 | 显示全部楼层 |阅读模式
; (c) Chris Hardwicke 1996
(DEFUN C:xctj ()
  (setq tot_len 0)
  (prompt "\n(c) Chris Hardwicke 1996 ")
  (prompt "\nSelect all objects to count: ")
  (setq ss (ssget))
  (while (> (sslength ss) 0)
    (setq en (ssname ss 0))
    (setq ed (entget en))
    (setq e_type (cdr (assoc '0 ed)))
    (cond
      ((= e_type "LINE") (add_lines))
      ((= e_type "ARC") (add_arcs))
      ((= e_type "POLYLINE") (add_poly))
      ((= e_type "LWPOLYLINE") (add_poly))
      ((or
         (/= e_type "LINE")
         (/= e_type "ARC")
         (/= e_type "POLYLINE")
       (ssdel en ss)
  (prompt (strcat "\nTotal length is: " (rtos tot_len 2 1)))
  (setq txtPt (getpoint "\nInsertion point for total value: "))
  (command "._text" "middle" txtpt)
  (if (= 0.0 (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))))
           (command "" "" (rtos tot_len 2 1))
           (command "" (rtos tot_len 2 1))
(defun add_lines ()
  (setq pt1 (cdr (assoc '10 ed)))
  (setq pt2 (cdr (assoc '11 ed)))
  (setq line_len (distance pt1 pt2))
  (setq tot_len (+ tot_len line_len))
  (ssdel en ss)
(defun add_arcs ()
  (SETQ CEN (CDR (ASSOC '10 Ed))
        RAD (CDR (ASSOC '40 Ed))
        DIA (* RAD 2.0)
        CIRCUM (* (* RAD PI) 2.0)
        S_ANG (CDR (ASSOC '50 Ed))
        E_ANG (CDR (ASSOC '51 Ed))
  (IF (< E_ANG S_ANG)
    (SETQ E_ANG (+ E_ANG (* PI 2.0)))
  (SETQ
        N_ANG (- E_ANG S_ANG)
        N_ANG_1 (* (/ N_ANG PI) 180.0)
        PART_CIRC (/ N_ANG_1 360.0)
        A_LEN (* PART_CIRC CIRCUM)
  (setq tot_len (+ tot_len a_len))
  (PRIN1)
  (SSDEL EN SS)
(defun add_poly ()
  (command "area" "e" en)
  (setq tot_len (+ tot_len (getvar "perimeter")))
  (ssdel en ss)
发表于 2018-1-25 16:24:13 | 显示全部楼层
谢谢分享谢谢分享谢谢分享谢谢分享
发表于 2018-1-31 16:39:01 | 显示全部楼层
很好的插件
已领礼包: 7214个
发表于 2018-2-4 11:06:56 | 显示全部楼层
谢谢分享!
GMT+8, 2026-11-5 08:54 , Processed in 0.444487 second(s), 35 queries , Gzip On.
