查看: 2089|回复: 2
[教学] API应用 折线模拟斜线
发表于 2013-12-1 00:21:01 | 显示全部楼层 |阅读模式
  1. (defun c:tt (/ e n v ptl sp0)
  2.   (if (and (setq e (car (xdrx_entsel "\nPick line: " '((0 . "line")))))
  3.            (not
  4.              (zerop (rem (xdrx_getpropertyvalue e "Angle") (* pi 2)))
  5.            )
  6.            (setq n (getint "\Divid Num: "))
  7.       )
  8.     (progn
  9.       (mapcar 'set '(sp ep) (xdrx_entity_getstretchpoint e))
  10.       (setq v        (mapcar '(lambda (x) (/ x n)) (mapcar '- ep sp))
  11.             sp0        sp
  12.       )
  13.       (repeat n
  14.         (setq ptl (cons (setq sp (mapcar '+ sp (list (car v) 0. 0.))) ptl)
  15.               ptl (cons (setq sp (mapcar '+ sp (list 0. (cadr v) 0.))) ptl)
  16.         )
  17.       )
  18.       (apply 'xdrx_polyline_make (cons sp0 (reverse ptl)))
  19.     )
  20.     (princ "\nNot need Simulation or Not Slash!")
  21.   )
  22.   (princ)
  23. )
 楼主| 发表于 2013-12-1 08:08:29 | 显示全部楼层
往上偏移一半
  1. (defun c:tt (/ e n v ptl v v+ v- nsp nep i dis )
  3.            (not
  5.            )
  6.            (setq n (getint "\nDivid Num: "))
  7.       )
  8.     (progn
  11.             v+        (list 0. (* (cadr v) 0.5) 0.)
  12.             v-        (list 0. (- (* (cadr v) 0.5)) 0.)
  13.             nsp        (mapcar '+ sp v+)
  14.             nep        (mapcar '+ ep v-)
  15.             i        1
  16.             dis        (/ (distance sp ep) n)
  17.             an        (angle sp ep)
  18.       )
  19.       (repeat (1- n)
  20.         (setq ptl (cons (polar sp an (* i dis)) ptl)
  21.               i          (1+ i)
  22.         )
  23.       )
  24.       (setq ptl        (mapcar        '(lambda (x)
  25.                            (list (mapcar '+ x v+)
  26.                                  (mapcar '+ x v-)
  27.                            )
  28.                          )
  29.                         ptl
  30.                 )
  31.             ptl        (apply 'append ptl)
  32.       )
  33.       (apply 'xdrx_polyline_make
  34.              (cons sp (cons nsp (reverse (cons ep (cons nep ptl)))))
  35.       )
  36.     )
  37.     (princ "\nNot need Simulation or Not Slash!")
  38.   )
  39.   (princ)
  40. )
发表于 2013-12-1 11:14:21 | 显示全部楼层
哦,画台阶啊,每步的踏步高怎么定的呢?
GMT+8, 2026-11-22 11:08 , Processed in 0.428739 second(s), 14 queries , Gzip On, File On.
