查看: 1777|回复: 1
[研讨] 复制部分多段线
已领礼包: 604个
发表于 2013-12-6 08:26:19 | 显示全部楼层 |阅读模式
  1. (defun c:fff (/ CMDECHO1 N OSMODE1 P2 PET SS SS1 SS2)
  2.   (defun GetTwoPts (ss / XY)
  3.     (setq xy (last (ssnamex ss 0)))
  4.     (list (last (cadr xy)) (last (cadddr xy)))
  5.   )
  6.   (setq CMDECHO1 (getvar "CMDECHO"))
  7.   (setq osmode1 (getvar "osmode"))
  8.   (setq pet (getvar "PEDITACCEPT"))
  9.   (Setvar "CMDECHO" 0)
  10.   (Setvar "osmode" 0)
  11.   (setvar "PEDITACCEPT" 1)
  12.   (if (setq ss (ssget '((0 . "LWPOLYLINE"))))
  13.     (progn (setq p2 (GetTwoPts ss))
  14.     (repeat (setq n (sslength ss))
  15.       (vl-cmdf "_.explode" (ssname ss (setq n (1- n))))
  16.       (setq ss1 (ssget "_P"))
  17.       (setq ss2 (ssget "W" (car p2) (cadr p2)))
  18.       (if (and ss1 ss2)
  19.         (progn
  20.    (vl-cmdf "_.Select" ss1 "_Remove" ss2 "")
  21.    (setq ss1 (ssget "_P"))
  22.         )
  23.       )
  24.       (if ss1
  25.         (command "_pedit" "_M" ss1 "" "_j" "" "")
  26.       )
  27.       (if ss2
  28.         (command "_pedit" "_M" ss2 "" "_j" "" "")
  29.       )
  30.     )
  31.     )
  32.   )
  33.   (Setvar "CMDECHO" CMDECHO1)
  34.   (Setvar "osmode" osmode1)
  35.   (setvar "PEDITACCEPT" pet)
  36.   (princ)
  37. )
已领礼包: 6468个
发表于 2013-12-18 22:13:32 | 显示全部楼层
看动画没看明白,怎么叫复制部分多段线?
GMT+8, 2026-11-6 15:48 , Processed in 0.398564 second(s), 34 queries , Gzip On.
