查看: 2049|回复: 1
[求助] cad文本导出到excel里的函数,怎么使输出的文本为列输出??
发表于 2013-12-16 09:26:45 | 显示全部楼层 |阅读模式
(defun c:tqwz()
   (if (= (setq n (getint "\n保存文字时每行的个数<5>:")) niL)
       (setq n 5)
   (princ "\n请选择单行文字:")
   (if (setq ssa (ssget '((0 . "text"))))
       (if (setq wjm  (getfiled "请指定提取结果存盘文件" "d://" "csv" 1))
           (progn
               (setq m (sslength ssa)
                     i 0
                     zfc ""
                     ff (open wjm "w")
                     j 0
               (repeat m
                   (setq dxf (entget (ssname ssa i))
                         i   (1+ i)
                         wz  (cdr (assoc 1 dxf))
                         j   (1+ j)
                   (if (= j n)
                       (progn
                           (setq zfc (strcat zfc wz "\n"))
                           (princ zfc ff)
                           (princ zfc)
                           (setq zfc "" j 0)
                       (setq zfc (strcat zfc wz ","))
              (if (< 0 j n)
                  (progn
                      (setq zfc (substr zfc 1 (1- (strlen zfc)))
                            zfc (strcat zfc "\n")
                      (princ zfc ff)
                      (princ zfc)
              (close ff)
           (princ "\n没有指定提取结果存盘文件")
       (princ "\n没有选取任何单行文字!")
    (princ)
已领礼包: 1268个
发表于 2013-12-16 10:19:53 来自手机 | 显示全部楼层
先构造表,最后再写文件,这样可以按要求处理表
GMT+8, 2026-11-6 15:49 , Processed in 0.367717 second(s), 35 queries , Gzip On.
