查看: 2157|回复: 5
[求助] 求改进代码
发表于 2013-12-16 10:11:41 | 显示全部楼层 |阅读模式
以下代码为网上寻得,麻烦大侠们帮忙改进下,谢谢!
要求:将选择后的表中重复项保留一项,并在面积后添加一项“数量”
(defun c:qq (/ appxls col ent ent1 f i lst m2 newbook newitem newsheet numrow pt ss txt value xlscells xlsworkbooks)
  (defun initexcel ()
    (setq appxls (vlax-get-or-create-object "excel.application")
          xlsworkbooks (vlax-get-property appxls "workbooks")
          newbook (vlax-invoke-method xlsworkbooks "add")
          newsheet (vlax-get-property newbook "sheets")
          newitem (vlax-get-property newsheet "item" 1)
          xlscells (vlax-get-property newitem "cells")
    (vla-put-visible appxls :vlax-true)
  (defun endexcel ()
    (vlax-release-object xlscells)
    (vlax-release-object newitem)
    (vlax-release-object newsheet)
    (vlax-release-object newbook)
    (vlax-release-object xlsworkbooks)
    (vlax-release-object appxls)
  (defun datacell (nurow col value)
    (vlax-put-property xlscells "item" numrow col (vl-princ-to-string value))
  (setvar "cmdecho" 0)
  (vl-load-com)
  (if (setq ss (ssget '((0 . "*TEXT"))))
    (progn
      (= lst nil)
      (repeat (setq i (sslength ss))
        (setq ent (entget (ssname ss (setq i (1- i))))
              pt (cdr (assoc 10 ent))
              txt (cdr (assoc 1 ent))
        (command "-boundary" pt "")
        (command ".region" (entlast) "")
        (setq ent1 (entlast))
        (if (= (cdr (assoc 0 (entget ent1))) "REGION")
          (setq ent (vlax-ename->vla-object ent1)
                m2 (rtos (vla-get-area ent))
                lst (cons (list txt m2) lst)
                f (entdel ent1)
      (setq lst (vl-sort lst (function (lambda (x y)
                                           (< (car x) (car y))
      (setq lst (cons (list "版号" "面积") lst))
      (initexcel)
      (setq numrow 1)
      (foreach f lst
        (datacell numrow 1 (car f))
        (datacell numrow 2 (cadr f))
        (setq numrow (1+ numrow))
      (endexcel)
  (princ)
新建文件夹.rar
18.33 KB, 下载次数: 5
对应文件
已领礼包: 1268个
发表于 2013-12-16 10:25:06 来自手机 | 显示全部楼层
文字处保证能生成闭合线?
是在已有表增加?还是新建表?
论坛里找的,很多看都看不懂所以自己改不了,来求救来了。。。。。。。。。  详情 回复 发表于 2013-12-16 10:28
 楼主| 发表于 2013-12-16 10:28:34 | 显示全部楼层
st788796 发表于 2013-12-16 10:25
文字处保证能生成闭合线?
是在已有表增加?还是新建表?
{:soso_e117:}论坛里找的,很多看都看不懂所以自己改不了,来求救来了。。。。。。。。。
你得说清楚要做什么才好有针对性修改,另外这个程序能不能运行,运行结果哪里和你的要求有差距,这些要让别人明白了才好帮你  详情 回复 发表于 2013-12-16 10:36
已领礼包: 1268个
发表于 2013-12-16 10:36:26 来自手机 | 显示全部楼层
已领礼包: 1268个
发表于 2013-12-16 17:11:58 | 显示全部楼层
  1. (defun c:tt (/ ss strl)
  2.   (if (setq ss (ssget '((0 . "*text"))))
  3.     (progn
  4.       (setq strl (mapcar '(lambda (x / pt str e a)
  5.                             (setq pt  (xdrx_getpropertyvalue x "Position")
  6.                                   str (xdrx_getpropertyvalue x "Textstring")
  7.                             )
  8.                             (if        (setq e (xdrx_geom_bpoly pt))
  9.                               (progn
  10.                                 (setq a (car (xdrx_getarea e)))
  11.                                 (xdrx_entity_delete e)
  12.                                 (list str a)
  13.                               )
  14.                             )
  15.                           )
  16.                          (xdrx_pickset->ents ss)
  17.                  )
  18.             strl (XD::List:GroupByIndex strl 0)
  19.             strl (mapcar '(lambda (x)
  20.                             (strcat (car x)
  21.                                     " "
  22.                                     (rtos (cadr x) 2 3)
  23.                                     " "
  24.                                     (itoa (length (cdr x)))
  25.                             )
  26.                           )
  27.                          strl
  28.                  )
  29.             strl (cons "型号 面积 数量" strl)
  30.       )
  31.       (XD::List:Tofile "d:\\area.csv" strl);_文件名自己修改
  32.     )
  33.   )
  34.   (princ)
  35. )
谢谢!!!!!!!  详情 回复 发表于 2013-12-16 17:45
 楼主| 发表于 2013-12-16 17:45:07 | 显示全部楼层
谢谢!!!!!!!
GMT+8, 2026-11-6 15:50 , Processed in 0.424880 second(s), 43 queries , Gzip On.
