查看: 3194|回复: 0
[研讨] 任意Lisp编辑器实现函数自动完成功能(中文注解方法+制作程序+配置文件+模式切换方...
已领礼包: 1742个
财富等级: 堆金积玉
发表于 2013-12-20 16:00:21 | 显示全部楼层 |阅读模式
首选说明:此文大部分源自明经
地址:http://bbs.mjtd.com/thread-108498-1-1.html
附上两个效果图:
下面是用于生成函数词的程序,把生成在D盘的短语放进....(使用方法参见上面的网址)
  1. (setq words '(
  2. abs
  3. acad-pop-dbmod
  4. acad-push-dbmod
  5. acad_colordlg
  6. acad_helpdlg
  7. acad_strlsort
  8. action_tile
  9. add_list
  10. ads
  11. alert
  12. alloc
  13. and
  14. angle
  15. angtof
  16. angtos
  17. append
  18. apply
  19. arx
  20. arxload
  21. arxunload
  22. ascii
  23. assoc
  24. atan
  25. atof
  26. atoi
  27. atom
  28. atoms-family
  29. autoarxload
  30. autoload
  31. autoxload
  32. boole
  33. boundp
  34. caaaar
  35. caaar
  36. caadr
  37. caar
  38. cadar
  39. caddar
  40. cadddr
  41. caddr
  42. cadr
  43. car
  44. cdar
  45. cddddr
  46. cdddr
  47. cddr
  48. cdr
  49. chr
  50. client_data_tile
  51. close
  52. command
  53. cond
  54. cons
  55. cos
  56. cvunit
  57. defun
  58. defun-q
  59. defun-q-List-ref
  60. defun-q-List-set
  61. dictadd
  62. dictnext
  63. dictremove
  64. dictrename
  65. dictsearch
  66. dimx_tile
  67. dimy_tile
  68. distance
  69. distof
  70. done_dialog
  71. end_image
  72. end_list
  73. entdel
  74. entget
  75. entlast
  76. entmake
  77. entmakex
  78. entmod
  79. entnext
  80. entsel
  81. entupd
  82. eq
  83. equal
  84. eval
  85. exit
  86. exp
  87. expand
  88. expt
  89. fill_image
  90. findfile
  91. fix
  92. float
  93. foreach
  94. function
  95. gc
  96. gcd
  97. get_attr
  98. get_tile
  99. getangle
  100. getcfg
  101. getcname
  102. getcorner
  103. getdist
  104. getenv
  105. getfiled
  106. getint
  107. getkword
  108. getorient
  109. getpoint
  110. getreal
  111. getstring
  112. getvar
  113. graphscr
  114. grclear
  115. grdraw
  116. grread
  117. grtext
  118. grvecs
  119. handent
  120. help
  121. if
  122. initget
  123. intdia
  124. inters
  125. itoa
  126. lambda
  127. last
  128. layoutlist
  129. layerstate-addlayers
  130. layerstate-compare
  131. layerstate-delete
  132. layerstate-export
  133. layerstate-getlastrestored
  134. layerstate-getlayers
  135. layerstate-getnames
  136. layerstate-has
  137. layerstate-import
  138. layerstate-importfromdb
  139. layerstate-removelayers
  140. layerstate-rename
  141. layerstate-restore
  142. layerstate-save
  143. length
  144. list
  145. listp
  146. load
  147. load_dialog
  148. log
  149. logand
  150. logior
  151. lsh
  152. mapcar
  153. max
  154. mem
  155. member
  156. menucmd
  157. menugroup
  158. min
  159. minusp
  160. mode_tile
  161. namedobjdict
  162. nentsel
  163. nentselp
  164. new_dialog
  165. nil
  166. not
  167. nth
  168. null
  169. numberp
  170. open
  171. or
  172. osnap
  173. pause
  174. polar
  175. pragma
  176. prin1
  177. princ
  178. print
  179. progn
  180. prompt
  181. quit
  182. quote
  183. read
  184. read-char
  185. read-line
  186. redraw
  187. regapp
  188. rem
  189. repeat
  190. reverse
  191. rtos
  192. set
  193. set_tile
  194. setcfg
  195. setenv
  196. setfunhelp
  197. setq
  198. setvar
  199. setview
  200. sin
  201. slide_image
  202. snvalid
  203. sqrt
  204. ssadd
  205. ssdel
  206. ssget
  207. ssgetfirst
  208. sslength
  209. ssmemb
  210. ssname
  211. ssnamex
  212. sssetfirst
  213. start_dialog
  214. start_image
  215. start_list
  216. startapp
  217. strcase
  218. strcat
  219. strlen
  220. subst
  221. substr
  222. t
  223. tablet
  224. tblnext
  225. tblobjname
  226. tblsearch
  227. term_dialog
  228. terpri
  229. textbox
  230. textpage
  231. textscr
  232. trace
  233. trans
  234. type
  235. unload_dialog
  236. untrace
  237. vector_image
  238. ver
  239. VL-ACAD-DEFUN
  240. VL-ACAD-UNDEFUN
  241. VL-ARX-IMPORT
  242. VL-BB-REF
  243. VL-BB-SET
  244. VL-BT
  245. VL-BT-OFF
  246. VL-BT-ON
  247. VL-CATCH-ALL-APPLY
  248. VL-CATCH-ALL-ERROR-MESSAGE
  249. VL-CATCH-ALL-ERROR-P
  250. VL-CMDF
  251. VL-CONSP
  252. VL-DIRECTORY-FILES
  253. VL-DOC-EXPORT
  254. VL-DOC-IMPORT
  255. VL-DOC-REF
  256. VL-DOC-SET
  257. VL-EVERY
  258. VL-EXIT-WITH-ERROR
  259. VL-EXIT-WITH-VALUE
  260. VL-FILE-COPY
  261. VL-FILE-DELETE
  262. VL-FILE-DIRECTORY-P
  263. VL-FILE-RENAME
  264. VL-FILE-SIZE
  265. VL-FILE-SYSTIME
  266. VL-FILENAME-BASE
  267. VL-FILENAME-DIRECTORY
  268. VL-FILENAME-EXTENSION
  269. VL-FILENAME-MKTEMP
  270. VL-GET-RESOURCE
  271. VL-INFP
  272. VL-INIT
  273. VL-LIST*
  274. VL-LIST->STRING
  275. VL-LIST-EXPORTED-FUNCTIONS
  276. VL-LIST-LENGTH
  277. VL-LIST-LOADED-VLX
  278. VL-LOAD-ALL
  279. VL-LOAD-COM
  280. VL-LOAD-REACTORS
  281. VL-MEMBER-IF
  282. VL-MEMBER-IF-NOT
  283. VL-MKDIR
  284. VL-NANP
  285. VL-POSITION
  286. VL-PRIN1-TO-STRING
  287. VL-PRINC-TO-STRING
  288. VL-PROPAGATE
  289. VL-REGISTRY-DELETE
  290. VL-REGISTRY-DESCENDENTS
  291. VL-REGISTRY-READ
  292. VL-REGISTRY-WRITE
  293. VL-REMOVE
  294. VL-REMOVE-IF
  295. VL-REMOVE-IF-NOT
  296. VL-SOME
  297. VL-SORT
  298. VL-SORT-I
  299. VL-STRING->LIST
  300. VL-STRING-ELT
  301. VL-STRING-LEFT-TRIM
  302. VL-STRING-MISMATCH
  303. VL-STRING-POSITION
  304. VL-STRING-RIGHT-TRIM
  305. VL-STRING-SEARCH
  306. VL-STRING-SUBST
  307. VL-STRING-TRANSLATE
  308. VL-STRING-TRIM
  309. VL-SYMBOL-NAME
  310. VL-SYMBOL-VALUE
  311. VL-SYMBOLP
  312. VL-UNLOAD-VLX
  313. VL-VBALOAD
  314. VL-VBARUN
  315. VL-VLX-LOADED-P
  316. VLA-ACTIVATE
  317. VLA-ADD
  318. VLA-ADD3DFACE
  319. VLA-ADD3DMESH
  320. VLA-ADD3DPOLY
  321. VLA-ADDARC
  322. VLA-ADDATTRIBUTE
  323. VLA-ADDBOX
  324. VLA-ADDCIRCLE
  325. VLA-ADDCONE
  326. VLA-ADDCUSTOMINFO
  327. VLA-ADDCUSTOMOBJECT
  328. VLA-ADDCYLINDER
  329. VLA-ADDDIM3POINTANGULAR
  330. VLA-ADDDIMALIGNED
  331. VLA-ADDDIMANGULAR
  332. VLA-ADDDIMARC
  333. VLA-ADDDIMDIAMETRIC
  334. VLA-ADDDIMORDINATE
  335. VLA-ADDDIMRADIAL
  336. VLA-ADDDIMRADIALLARGE
  337. VLA-ADDDIMROTATED
  338. VLA-ADDELLIPSE
  339. VLA-ADDELLIPTICALCONE
  340. VLA-ADDELLIPTICALCYLINDER
  341. VLA-ADDEXTRUDEDSOLID
  342. VLA-ADDEXTRUDEDSOLIDALONGPATH
  343. VLA-ADDFITPOINT
  344. VLA-ADDHATCH
  345. VLA-ADDITEMS
  346. VLA-ADDLEADER
  347. VLA-ADDLEADERLINE
  348. VLA-ADDLEADERLINEEX
  349. VLA-ADDLIGHTWEIGHTPOLYLINE
  350. VLA-ADDLINE
  351. VLA-ADDMENUITEM
  352. VLA-ADDMINSERTBLOCK
  353. VLA-ADDMLEADER
  354. VLA-ADDMLINE
  355. VLA-ADDMTEXT
  356. VLA-ADDOBJECT
  357. VLA-ADDPOINT
  358. VLA-ADDPOLYFACEMESH
  359. VLA-ADDPOLYLINE
  360. VLA-ADDPVIEWPORT
  361. VLA-ADDRASTER
  362. VLA-ADDRAY
  363. VLA-ADDREGION
  364. VLA-ADDREVOLVEDSOLID
  365. VLA-ADDSECTION
  366. VLA-ADDSEPARATOR
  367. VLA-ADDSHAPE
  368. VLA-ADDSOLID
  369. VLA-ADDSPHERE
  370. VLA-ADDSPLINE
  371. VLA-ADDSUBMENU
  372. VLA-ADDTABLE
  373. VLA-ADDTEXT
  374. VLA-ADDTOLERANCE
  375. VLA-ADDTOOLBARBUTTON
  376. VLA-ADDTORUS
  377. VLA-ADDTRACE
  378. VLA-ADDVERTEX
  379. VLA-ADDWEDGE
  380. VLA-ADDXLINE
  381. VLA-ADDXRECORD
  382. VLA-ANGLEFROMXAXIS
  383. VLA-ANGLETOREAL
  384. VLA-ANGLETOSTRING
  385. VLA-APPENDINNERLOOP
  386. VLA-APPENDITEMS
  387. VLA-APPENDOUTERLOOP
  388. VLA-APPENDVERTEX
  389. VLA-ARRAYPOLAR
  390. VLA-ARRAYRECTANGULAR
  391. VLA-ATTACHEXTERNALREFERENCE
  392. VLA-ATTACHTOOLBARTOFLYOUT
  393. VLA-AUDITINFO
  394. VLA-BIND
  395. VLA-BLOCK
  396. VLA-BOOLEAN
  397. VLA-CHECKINTERFERENCE
  398. VLA-CLEAR
  399. VLA-CLEARSUBSELECTION
  400. VLA-CLEARTABLESTYLEOVERRIDES
  401. VLA-CLIPBOUNDARY
  402. VLA-CLOSE
  403. VLA-CONVERTTOANONYMOUSBLOCK
  404. VLA-CONVERTTOSTATICBLOCK
  405. VLA-COPY
  406. VLA-COPYFROM
  407. VLA-COPYOBJECTS
  408. VLA-COPYPROFILE
  409. VLA-CREATECELLSTYLE
  410. VLA-CREATECELLSTYLEFROMSTYLE
  411. VLA-CREATECONTENT
  412. VLA-CREATEENTRY
  413. VLA-CREATEJOG
  414. VLA-CREATETYPEDARRAY
  415. VLA-DELETE
  416. VLA-DELETECELLCONTENT
  417. VLA-DELETECELLSTYLE
  418. VLA-DELETECOLUMNS
  419. VLA-DELETECONFIGURATION
  420. VLA-DELETECONTENT
  421. VLA-DELETEFITPOINT
  422. VLA-DELETEPROFILE
  423. VLA-DELETEROWS
  424. VLA-DETACH
  425. VLA-DISPLAY
  426. VLA-DISPLAYPLOTPREVIEW
  427. VLA-DISTANCETOREAL
  428. VLA-DOCK
  429. VLA-ELEVATEORDER
  430. VLA-ENABLEMERGEALL
  431. VLA-ENDUNDOMARK
  432. VLA-ERASE
  433. VLA-EVAL
  434. VLA-EVALUATE
  435. VLA-EXPLODE
  436. VLA-EXPORT
  437. VLA-EXPORTPROFILE
  438. VLA-FIELDCODE
  439. VLA-FLOAT
  440. VLA-FORMATVALUE
  441. VLA-GENERATELAYOUT
  442. VLA-GENERATESECTIONGEOMETRY
  443. VLA-GENERATEUSAGEDATA
  444. VLA-GET-ACTION
  445. VLA-GET-ACTIVE
  446. VLA-GET-ACTIVEDIMSTYLE
  447. VLA-GET-ACTIVEDOCUMENT
  448. VLA-GET-ACTIVELAYER
  449. VLA-GET-ACTIVELAYOUT
  450. VLA-GET-ACTIVELINETYPE
  451. VLA-GET-ACTIVEMATERIAL
  452. VLA-GET-ACTIVEPROFILE
  453. VLA-GET-ACTIVEPVIEWPORT
  454. VLA-GET-ACTIVESELECTIONSET
  455. VLA-GET-ACTIVESPACE
  456. VLA-GET-ACTIVETEXTSTYLE
  457. VLA-GET-ACTIVEUCS
  458. VLA-GET-ACTIVEVIEWPORT
  459. VLA-GET-ADCINSERTUNITSDEFAULTSOURCE
  460. VLA-GET-ADCINSERTUNITSDEFAULTTARGET
  461. VLA-GET-ADJUSTFORBACKGROUND
  462. VLA-GET-AFFECTSGRAPHICS
  463. VLA-GET-ALGORITHM
  464. VLA-GET-ALIGNMENT
  465. VLA-GET-ALIGNMENTPOINTACQUISITION
  466. VLA-GET-ALIGNSPACE
  467. VLA-GET-ALLOWEDVALUES
  468. VLA-GET-ALLOWLONGSYMBOLNAMES
  469. VLA-GET-ALLOWMANUALHEIGHTS
  470. VLA-GET-ALLOWMANUALPOSITIONS
  471. VLA-GET-ALTFONTFILE
  472. VLA-GET-ALTROUNDDISTANCE
  473. VLA-GET-ALTSUBUNITSFACTOR
  474. VLA-GET-ALTSUBUNITSSUFFIX
  475. VLA-GET-ALTSUPPRESSLEADINGZEROS
  476. VLA-GET-ALTSUPPRESSTRAILINGZEROS
  477. VLA-GET-ALTSUPPRESSZEROFEET
  478. VLA-GET-ALTSUPPRESSZEROINCHES
  479. VLA-GET-ALTTABLETMENUFILE
  480. VLA-GET-ALTTEXTPREFIX
  481. VLA-GET-ALTTEXTSUFFIX
  482. VLA-GET-ALTTOLERANCEPRECISION
  483. VLA-GET-ALTTOLERANCESUPPRESSLEADINGZEROS
  484. VLA-GET-ALTTOLERANCESUPPRESSTRAILINGZEROS
  485. VLA-GET-ALTTOLERANCESUPPRESSZEROFEET
  486. VLA-GET-ALTTOLERANCESUPPRESSZEROINCHES
  487. VLA-GET-ALTUNITS
  488. VLA-GET-ALTUNITSFORMAT
  489. VLA-GET-ALTUNITSPRECISION
  490. VLA-GET-ALTUNITSSCALE
  491. VLA-GET-ANGLE
  492. VLA-GET-ANGLEFORMAT
  493. VLA-GET-ANGLEVERTEX
  494. VLA-GET-ANNOTATION
  495. VLA-GET-ANNOTATIVE
  496. VLA-GET-APPLICATION
  497. VLA-GET-ARCENDPARAM
  498. VLA-GET-ARCLENGTH
  499. VLA-GET-ARCPOINT
  500. VLA-GET-ARCSMOOTHNESS
  501. VLA-GET-ARCSTARTPARAM
  502. VLA-GET-AREA
  503. VLA-GET-ARROWHEAD1BLOCK
  504. VLA-GET-ARROWHEAD1TYPE
  505. VLA-GET-ARROWHEAD2BLOCK
  506. VLA-GET-ARROWHEAD2TYPE
  507. VLA-GET-ARROWHEADBLOCK
  508. VLA-GET-ARROWHEADSIZE
  509. VLA-GET-ARROWHEADTYPE
  510. VLA-GET-ARROWSIZE
  511. VLA-GET-ARROWSYMBOL
  512. VLA-GET-ASSOCIATIVEHATCH
  513. VLA-GET-ATTACHMENTPOINT
  514. VLA-GET-AUTHOR
  515. VLA-GET-AUTOAUDIT
  516. VLA-GET-AUTOMATICPLOTLOG
  517. VLA-GET-AUTOSAVEINTERVAL
  518. VLA-GET-AUTOSAVEPATH
  519. VLA-GET-AUTOSNAPAPERTURE
  520. VLA-GET-AUTOSNAPAPERTURESIZE
  521. VLA-GET-AUTOSNAPMAGNET
  522. VLA-GET-AUTOSNAPMARKER
  523. VLA-GET-AUTOSNAPMARKERCOLOR
  524. VLA-GET-AUTOSNAPMARKERSIZE
  525. VLA-GET-AUTOSNAPTOOLTIP
  526. VLA-GET-AUTOTRACKINGVECCOLOR
  527. VLA-GET-AUTOTRACKTOOLTIP
  528. VLA-GET-AXISDIRECTION
  529. VLA-GET-AXISPOSITION
  530. VLA-GET-BACKGROUNDFILL
  531. VLA-GET-BACKGROUNDLINESCOLOR
  532. VLA-GET-BACKGROUNDLINESHIDDENLINE
  533. VLA-GET-BACKGROUNDLINESLAYER
  534. VLA-GET-BACKGROUNDLINESLINETYPE
  535. VLA-GET-BACKGROUNDLINESLINETYPESCALE
  536. VLA-GET-BACKGROUNDLINESLINEWEIGHT
  537. VLA-GET-BACKGROUNDLINESPLOTSTYLENAME
  538. VLA-GET-BACKGROUNDLINESVISIBLE
  539. VLA-GET-BACKWARD
  540. VLA-GET-BANK
  541. VLA-GET-BASEPOINT
  542. VLA-GET-BASERADIUS
  543. VLA-GET-BATCHPLOTPROGRESS
  544. VLA-GET-BEEPONERROR
  545. VLA-GET-BIGFONTFILE
  546. VLA-GET-BITFLAGS
  547. VLA-GET-BLOCK
  548. VLA-GET-BLOCKCOLOR
  549. VLA-GET-BLOCKCONNECTIONTYPE
  550. VLA-GET-BLOCKROTATION
  551. VLA-GET-BLOCKS
  552. VLA-GET-BLOCKSCALE
  553. VLA-GET-BLOCKSCALING
  554. VLA-GET-BLUE
  555. VLA-GET-BOOKNAME
  556. VLA-GET-BOTTOMHEIGHT
  557. VLA-GET-BREAKSENABLED
  558. VLA-GET-BREAKSIZE
  559. VLA-GET-BREAKSPACING
  560. VLA-GET-BRIGHTNESS
  561. VLA-GET-CANONICALMEDIANAME
  562. VLA-GET-CAPTION
  563. VLA-GET-CATEGORYNAME
  564. VLA-GET-CENTER
  565. VLA-GET-CENTERMARKSIZE
  566. VLA-GET-CENTERPLOT
  567. VLA-GET-CENTERPOINT
  568. VLA-GET-CENTERTYPE
  569. VLA-GET-CENTROID
  570. VLA-GET-CHECK
  571. VLA-GET-CHORDPOINT
  572. VLA-GET-CIRCUMFERENCE
  573. VLA-GET-CLIPPED
  574. VLA-GET-CLIPPINGENABLED
  575. VLA-GET-CLOSED
  576. VLA-GET-COLOR
  577. VLA-GET-COLORBOOKPATH
  578. VLA-GET-COLORINDEX
  579. VLA-GET-COLORMETHOD
  580. VLA-GET-COLORNAME
  581. VLA-GET-COLUMNS
  582. VLA-GET-COLUMNSPACING
  583. VLA-GET-COMMANDDISPLAYNAME
  584. VLA-GET-COMMENT
  585. VLA-GET-COMMENTS
  586. VLA-GET-CONFIGFILE
  587. VLA-GET-CONFIGNAME
  588. VLA-GET-CONSTANT
  589. VLA-GET-CONSTANTWIDTH
  590. VLA-GET-CONSTRAIN
  591. VLA-GET-CONTENTBLOCKNAME
  592. VLA-GET-CONTENTBLOCKTYPE
  593. VLA-GET-CONTENTTYPE
  594. VLA-GET-CONTINUOUSPLOTLOG
  595. VLA-GET-CONTOURLINESPERSURFACE
  596. VLA-GET-CONTRAST
  597. VLA-GET-CONTROLPOINTS
  598. VLA-GET-COORDINATE
  599. VLA-GET-COORDINATES
  600. VLA-GET-COUNT
  601. VLA-GET-CREASELEVEL
  602. VLA-GET-CREASETYPE
  603. VLA-GET-CREATEBACKUP
  604. VLA-GET-CURRENTSECTIONTYPE
  605. VLA-GET-CURSORSIZE
  606. VLA-GET-CURVETANGENCYLINESCOLOR
  607. VLA-GET-CURVETANGENCYLINESLAYER
  608. VLA-GET-CURVETANGENCYLINESLINETYPE
  609. VLA-GET-CURVETANGENCYLINESLINETYPESCALE
  610. VLA-GET-CURVETANGENCYLINESLINEWEIGHT
  611. VLA-GET-CURVETANGENCYLINESPLOTSTYLENAME
  612. VLA-GET-CURVETANGENCYLINESVISIBLE
  613. VLA-GET-CUSTOMDICTIONARY
  614. VLA-GET-CUSTOMICONPATH
  615. VLA-GET-CUSTOMSCALE
  616. VLA-GET-DATABASE
  617. VLA-GET-DECIMALSEPARATOR
  618. VLA-GET-DEFAULTINTERNETURL
  619. VLA-GET-DEFAULTOUTPUTDEVICE
  620. VLA-GET-DEFAULTPLOTSTYLEFORLAYER
  621. VLA-GET-DEFAULTPLOTSTYLEFOROBJECTS
  622. VLA-GET-DEFAULTPLOTSTYLETABLE
  623. VLA-GET-DEFAULTPLOTTOFILEPATH
  624. VLA-GET-DEGREE
  625. VLA-GET-DELTA
  626. VLA-GET-DEMANDLOADARXAPP
  627. VLA-GET-DESCRIPTION
  628. VLA-GET-DESTINATIONBLOCK
  629. VLA-GET-DESTINATIONFILE
  630. VLA-GET-DIAMETER
  631. VLA-GET-DICTIONARIES
  632. VLA-GET-DIMCONSTRDESC
  633. VLA-GET-DIMCONSTREXPRESSION
  634. VLA-GET-DIMCONSTRFORM
  635. VLA-GET-DIMCONSTRNAME
  636. VLA-GET-DIMCONSTRREFERENCE
  637. VLA-GET-DIMCONSTRVALUE
  638. VLA-GET-DIMENSIONLINECOLOR
  639. VLA-GET-DIMENSIONLINEEXTEND
  640. VLA-GET-DIMENSIONLINETYPE
  641. VLA-GET-DIMENSIONLINEWEIGHT
  642. VLA-GET-DIMLINE1SUPPRESS
  643. VLA-GET-DIMLINE2SUPPRESS
  644. VLA-GET-DIMLINEINSIDE
  645. VLA-GET-DIMLINESUPPRESS
  646. VLA-GET-DIMSTYLES
  647. VLA-GET-DIMTXTDIRECTION
  648. VLA-GET-DIRECTION
  649. VLA-GET-DIRECTIONVECTOR
  650. VLA-GET-DISPLAY
  651. VLA-GET-DISPLAYGRIPS
  652. VLA-GET-DISPLAYGRIPSWITHINBLOCKS
  653. VLA-GET-DISPLAYLAYOUTTABS
  654. VLA-GET-DISPLAYLOCKED
  655. VLA-GET-DISPLAYOLESCALE
  656. VLA-GET-DISPLAYSCREENMENU
  657. VLA-GET-DISPLAYSCROLLBARS
  658. VLA-GET-DISPLAYSILHOUETTE
  659. VLA-GET-DOCKEDVISIBLELINES
  660. VLA-GET-DOCKSTATUS
  661. VLA-GET-DOCUMENT
  662. VLA-GET-DOCUMENTS
  663. VLA-GET-DOGLEGGED
  664. VLA-GET-DOGLEGLENGTH
  665. VLA-GET-DRAFTING
  666. VLA-GET-DRAWINGDIRECTION
  667. VLA-GET-DRAWLEADERORDERTYPE
  668. VLA-GET-DRAWMLEADERORDERTYPE
  669. VLA-GET-DRIVERSPATH
  670. VLA-GET-DWFFORMAT
  671. VLA-GET-EFFECTIVENAME
  672. VLA-GET-ELEVATION
  673. VLA-GET-ELEVATIONMODELSPACE
  674. VLA-GET-ELEVATIONPAPERSPACE
  675. VLA-GET-ENABLE
  676. VLA-GET-ENABLEBLOCKROTATION
  677. VLA-GET-ENABLEBLOCKSCALE
  678. VLA-GET-ENABLEDOGLEG
  679. VLA-GET-ENABLEFRAMETEXT
  680. VLA-GET-ENABLELANDING
  681. VLA-GET-ENABLESTARTUPDIALOG
  682. VLA-GET-ENDANGLE
  683. VLA-GET-ENDDRAFTANGLE
  684. VLA-GET-ENDDRAFTMAGNITUDE
  685. VLA-GET-ENDPARAMETER
  686. VLA-GET-ENDPOINT
  687. VLA-GET-ENDSUBMENULEVEL
  688. VLA-GET-ENDTANGENT
  689. VLA-GET-ENTERPRISEMENUFILE
  690. VLA-GET-ENTITYCOLOR
  691. VLA-GET-EXPLODABLE
  692. VLA-GET-EXTENSIONLINECOLOR
  693. VLA-GET-EXTENSIONLINEEXTEND
  694. VLA-GET-EXTENSIONLINEOFFSET
  695. VLA-GET-EXTENSIONLINEWEIGHT
  696. VLA-GET-EXTLINE1ENDPOINT
  697. VLA-GET-EXTLINE1LINETYPE
  698. VLA-GET-EXTLINE1POINT
  699. VLA-GET-EXTLINE1STARTPOINT
  700. VLA-GET-EXTLINE1SUPPRESS
  701. VLA-GET-EXTLINE2ENDPOINT
  702. VLA-GET-EXTLINE2LINETYPE
  703. VLA-GET-EXTLINE2POINT
  704. VLA-GET-EXTLINE2STARTPOINT
  705. VLA-GET-EXTLINE2SUPPRESS
  706. VLA-GET-EXTLINEFIXEDLEN
  707. VLA-GET-EXTLINEFIXEDLENSUPPRESS
  708. VLA-GET-FACECOUNT
  709. VLA-GET-FADE
  710. VLA-GET-FEATURE
  711. VLA-GET-FIELDLENGTH
  712. VLA-GET-FILE
  713. VLA-GET-FILEDEPENDENCIES
  714. VLA-GET-FILENAME
  715. VLA-GET-FILES
  716. VLA-GET-FILESIZE
  717. VLA-GET-FINGERPRINTGUID
  718. VLA-GET-FIRSTSEGMENTANGLECONSTRAINT
  719. VLA-GET-FIT
  720. VLA-GET-FITPOINTS
  721. VLA-GET-FITTOLERANCE
  722. VLA-GET-FLOATINGROWS
  723. VLA-GET-FLOWDIRECTION
  724. VLA-GET-FLYOUT
  725. VLA-GET-FONTFILE
  726. VLA-GET-FONTFILEMAP
  727. VLA-GET-FORCELINEINSIDE
  728. VLA-GET-FOREGROUNDLINESCOLOR
  729. VLA-GET-FOREGROUNDLINESEDGETRANSPARENCY
  730. VLA-GET-FOREGROUNDLINESFACETRANSPARENCY
  731. VLA-GET-FOREGROUNDLINESHIDDENLINE
  732. VLA-GET-FOREGROUNDLINESLAYER
  733. VLA-GET-FOREGROUNDLINESLINETYPE
  734. VLA-GET-FOREGROUNDLINESLINETYPESCALE
  735. VLA-GET-FOREGROUNDLINESLINEWEIGHT
  736. VLA-GET-FOREGROUNDLINESPLOTSTYLENAME
  737. VLA-GET-FOREGROUNDLINESVISIBLE
  738. VLA-GET-FOUNDPATH
  739. VLA-GET-FRACTIONFORMAT
  740. VLA-GET-FREEZE
  741. VLA-GET-FULLCRCVALIDATION
  742. VLA-GET-FULLFILENAME
  743. VLA-GET-FULLNAME
  744. VLA-GET-FULLSCREENTRACKINGVECTOR
  745. VLA-GET-GENERATIONOPTIONS
  746. VLA-GET-GRADIENTANGLE
  747. VLA-GET-GRADIENTCENTERED
  748. VLA-GET-GRADIENTCOLOR1
  749. VLA-GET-GRADIENTCOLOR2
  750. VLA-GET-GRADIENTNAME
  751. VLA-GET-GRAPHICSWINLAYOUTBACKGRNDCOLOR
  752. VLA-GET-GRAPHICSWINMODELBACKGRNDCOLOR
  753. VLA-GET-GREEN
  754. VLA-GET-GRIDON
  755. VLA-GET-GRIPCOLORSELECTED
  756. VLA-GET-GRIPCOLORUNSELECTED
  757. VLA-GET-GRIPSIZE
  758. VLA-GET-GROUPS
  759. VLA-GET-HANDLE
  760. VLA-GET-HASATTRIBUTES
  761. VLA-GET-HASEXTENSIONDICTIONARY
  762. VLA-GET-HASLEADER
  763. VLA-GET-HASSHEETVIEW
  764. VLA-GET-HASSUBSELECTION
  765. VLA-GET-HASVPASSOCIATION
  766. VLA-GET-HATCHOBJECTTYPE
  767. VLA-GET-HATCHSTYLE
  768. VLA-GET-HEADERSUPPRESSED
  769. VLA-GET-HEIGHT
  770. VLA-GET-HELPFILEPATH
  771. VLA-GET-HELPSTRING
  772. VLA-GET-HISTORY
  773. VLA-GET-HISTORYLINES
  774. VLA-GET-HORIZONTALTEXTPOSITION
  775. VLA-GET-HORZCELLMARGIN
  776. VLA-GET-HWND
  777. VLA-GET-HYPERLINKBASE
  778. VLA-GET-HYPERLINKDISPLAYCURSOR
  779. VLA-GET-HYPERLINKS
  780. VLA-GET-IMAGEFILE
  781. VLA-GET-IMAGEFRAMEHIGHLIGHT
  782. VLA-GET-IMAGEHEIGHT
  783. VLA-GET-IMAGEVISIBILITY
  784. VLA-GET-IMAGEWIDTH
  785. VLA-GET-INCREMENTALSAVEPERCENT
  786. VLA-GET-INDEX
  787. VLA-GET-INDICATORFILLCOLOR
  788. VLA-GET-INDICATORTRANSPARENCY
  789. VLA-GET-INSERTIONPOINT
  790. VLA-GET-INSUNITS
  791. VLA-GET-INSUNITSFACTOR
  792. VLA-GET-INTERSECTIONBOUNDARYCOLOR
  793. VLA-GET-INTERSECTIONBOUNDARYDIVISIONLINES
  794. VLA-GET-INTERSECTIONBOUNDARYLAYER
  795. VLA-GET-INTERSECTIONBOUNDARYLINETYPE
  796. VLA-GET-INTERSECTIONBOUNDARYLINETYPESCALE
  797. VLA-GET-INTERSECTIONBOUNDARYLINEWEIGHT
  798. VLA-GET-INTERSECTIONBOUNDARYPLOTSTYLENAME
  799. VLA-GET-INTERSECTIONBOUNDARYVISIBLE
  800. VLA-GET-INTERSECTIONFILLCOLOR
  801. VLA-GET-INTERSECTIONFILLFACETRANSPARENCY
  802. VLA-GET-INTERSECTIONFILLHATCHANGLE
  803. VLA-GET-INTERSECTIONFILLHATCHPATTERNNAME
  804. VLA-GET-INTERSECTIONFILLHATCHPATTERNTYPE
  805. VLA-GET-INTERSECTIONFILLHATCHSCALE
  806. VLA-GET-INTERSECTIONFILLHATCHSPACING
  807. VLA-GET-INTERSECTIONFILLLAYER
  808. VLA-GET-INTERSECTIONFILLLINETYPE
  809. VLA-GET-INTERSECTIONFILLLINETYPESCALE
  810. VLA-GET-INTERSECTIONFILLLINEWEIGHT
  811. VLA-GET-INTERSECTIONFILLPLOTSTYLENAME
  812. VLA-GET-INTERSECTIONFILLVISIBLE
  813. VLA-GET-INVISIBLE
  814. VLA-GET-ISCLONED
  815. VLA-GET-ISDYNAMICBLOCK
  816. VLA-GET-ISLAYOUT
  817. VLA-GET-ISMODIFIED
  818. VLA-GET-ISOPENWIDTH
  819. VLA-GET-ISOWNERXLATED
  820. VLA-GET-ISPARTIAL
  821. VLA-GET-ISPERIODIC
  822. VLA-GET-ISPLANAR
  823. VLA-GET-ISPRIMARY
  824. VLA-GET-ISQUIESCENT
  825. VLA-GET-ISRATIONAL
  826. VLA-GET-ISSUER
  827. VLA-GET-ISXREF
  828. VLA-GET-ITEMNAME
  829. VLA-GET-JOGANGLE
  830. VLA-GET-JOGLOCATION
  831. VLA-GET-JUSTIFICATION
  832. VLA-GET-KEY
  833. VLA-GET-KEYBOARDACCELERATOR
  834. VLA-GET-KEYBOARDPRIORITY
  835. VLA-GET-KEYLENGTH
  836. VLA-GET-KEYWORDS
  837. VLA-GET-KNOTS
  838. VLA-GET-LABEL
  839. VLA-GET-LABELBLOCKID
  840. VLA-GET-LANDINGGAP
  841. VLA-GET-LARGEBUTTONS
  842. VLA-GET-LASTHEIGHT
  843. VLA-GET-LASTSAVEDBY
  844. VLA-GET-LAYER
  845. VLA-GET-LAYERON
  846. VLA-GET-LAYERPROPERTYOVERRIDES
  847. VLA-GET-LAYERS
  848. VLA-GET-LAYERSTATE
  849. VLA-GET-LAYOUT
  850. VLA-GET-LAYOUTCREATEVIEWPORT
  851. VLA-GET-LAYOUTCROSSHAIRCOLOR
  852. VLA-GET-LAYOUTDISPLAYMARGINS
  853. VLA-GET-LAYOUTDISPLAYPAPER
  854. VLA-GET-LAYOUTDISPLAYPAPERSHADOW
  855. VLA-GET-LAYOUTID
  856. VLA-GET-LAYOUTS
  857. VLA-GET-LAYOUTSHOWPLOTSETUP
  858. VLA-GET-LEADER1POINT
  859. VLA-GET-LEADER2POINT
  860. VLA-GET-LEADERCOUNT
  861. VLA-GET-LEADERLINECOLOR
  862. VLA-GET-LEADERLINETYPE
  863. VLA-GET-LEADERLINETYPEID
  864. VLA-GET-LEADERLINEWEIGHT
  865. VLA-GET-LEADERTYPE
  866. VLA-GET-LEFT
  867. VLA-GET-LENGTH
  868. VLA-GET-LENSLENGTH
  869. VLA-GET-LIMITS
  870. VLA-GET-LINEARSCALEFACTOR
  871. VLA-GET-LINESPACINGDISTANCE
  872. VLA-GET-LINESPACINGFACTOR
  873. VLA-GET-LINESPACINGSTYLE
  874. VLA-GET-LINETYPE
  875. VLA-GET-LINETYPEGENERATION
  876. VLA-GET-LINETYPES
  877. VLA-GET-LINETYPESCALE
  878. VLA-GET-LINEWEIGHT
  879. VLA-GET-LINEWEIGHTDISPLAY
  880. VLA-GET-LIVESECTIONENABLED
  881. VLA-GET-LOADACADLSPINALLDOCUMENTS
  882. VLA-GET-LOCALEID
  883. VLA-GET-LOCK
  884. VLA-GET-LOCKASPECTRATIO
  885. VLA-GET-LOCKPOSITION
  886. VLA-GET-LOGFILEON
  887. VLA-GET-LOGFILEPATH
  888. VLA-GET-LOWERLEFTCORNER
  889. VLA-GET-MACRO
  890. VLA-GET-MAINDICTIONARY
  891. VLA-GET-MAJORAXIS
  892. VLA-GET-MAJORRADIUS
  893. VLA-GET-MASK
  894. VLA-GET-MATERIAL
  895. VLA-GET-MATERIALS
  896. VLA-GET-MAXACTIVEVIEWPORTS
  897. VLA-GET-MAXAUTOCADWINDOW
  898. VLA-GET-MAXLEADERSEGMENTSPOINTS
  899. VLA-GET-MCLOSE
  900. VLA-GET-MDENSITY
  901. VLA-GET-MEASUREMENT
  902. VLA-GET-MENUBAR
  903. VLA-GET-MENUFILE
  904. VLA-GET-MENUFILENAME
  905. VLA-GET-MENUGROUPS
  906. VLA-GET-MENUS
  907. VLA-GET-MINIMUMTABLEHEIGHT
  908. VLA-GET-MINIMUMTABLEWIDTH
  909. VLA-GET-MINORAXIS
  910. VLA-GET-MINORRADIUS
  911. VLA-GET-MLINESCALE
  912. VLA-GET-MODE
  913. VLA-GET-MODELCROSSHAIRCOLOR
  914. VLA-GET-MODELSPACE
  915. VLA-GET-MODELTYPE
  916. VLA-GET-MODELVIEW
  917. VLA-GET-MOMENTOFINERTIA
  918. VLA-GET-MONOCHROME
  919. VLA-GET-MRUNUMBER
  920. VLA-GET-MSPACE
  921. VLA-GET-MTEXTATTRIBUTE
  922. VLA-GET-MTEXTATTRIBUTECONTENT
  923. VLA-GET-MTEXTBOUNDARYWIDTH
  924. VLA-GET-MTEXTDRAWINGDIRECTION
  925. VLA-GET-MVERTEXCOUNT
  926. VLA-GET-NAME
  927. VLA-GET-NAMENOMNEMONIC
  928. VLA-GET-NCLOSE
  929. VLA-GET-NDENSITY
  930. VLA-GET-NORMAL
  931. VLA-GET-NUMBEROFCONTROLPOINTS
  932. VLA-GET-NUMBEROFCOPIES
  933. VLA-GET-NUMBEROFFACES
  934. VLA-GET-NUMBEROFFITPOINTS
  935. VLA-GET-NUMBEROFLOOPS
  936. VLA-GET-NUMBEROFVERTICES
  937. VLA-GET-NUMCELLSTYLES
  938. VLA-GET-NUMCROSSSECTIONS
  939. VLA-GET-NUMGUIDEPATHS
  940. VLA-GET-NUMVERTICES
  941. VLA-GET-NVERTEXCOUNT
  942. VLA-GET-OBJECTID
  943. VLA-GET-OBJECTNAME
  944. VLA-GET-OBJECTSNAPMODE
  945. VLA-GET-OBJECTSORTBYPLOTTING
  946. VLA-GET-OBJECTSORTBYPSOUTPUT
  947. VLA-GET-OBJECTSORTBYREDRAWS
  948. VLA-GET-OBJECTSORTBYREGENS
  949. VLA-GET-OBJECTSORTBYSELECTION
  950. VLA-GET-OBJECTSORTBYSNAP
  951. VLA-GET-OBLIQUEANGLE
  952. VLA-GET-OLEITEMTYPE
  953. VLA-GET-OLELAUNCH
  954. VLA-GET-OLEPLOTQUALITY
  955. VLA-GET-OLEQUALITY
  956. VLA-GET-OLESOURCEAPP
  957. VLA-GET-ONMENUBAR
  958. VLA-GET-OPENSAVE
  959. VLA-GET-ORIGIN
  960. VLA-GET-ORTHOON
  961. VLA-GET-OUTPUT
  962. VLA-GET-OVERRIDECENTER
  963. VLA-GET-OVERWRITEPROPCHANGED
  964. VLA-GET-OWNERID
  965. VLA-GET-PAGESETUPOVERRIDESTEMPLATEFILE
  966. VLA-GET-PAPERSPACE
  967. VLA-GET-PAPERUNITS
  968. VLA-GET-PARENT
  969. VLA-GET-PASSWORD
  970. VLA-GET-PATH
  971. VLA-GET-PATTERNANGLE
  972. VLA-GET-PATTERNDOUBLE
  973. VLA-GET-PATTERNNAME
  974. VLA-GET-PATTERNSCALE
  975. VLA-GET-PATTERNSPACE
  976. VLA-GET-PATTERNTYPE
  977. VLA-GET-PERIMETER
  978. VLA-GET-PICKADD
  979. VLA-GET-PICKAUTO
  980. VLA-GET-PICKBOXSIZE
  981. VLA-GET-PICKDRAG
  982. VLA-GET-PICKFIRST
  983. VLA-GET-PICKFIRSTSELECTIONSET
  984. VLA-GET-PICKGROUP
  985. VLA-GET-PLOT
  986. VLA-GET-PLOTCONFIGURATIONS
  987. VLA-GET-PLOTHIDDEN
  988. VLA-GET-PLOTLEGACY
  989. VLA-GET-PLOTLOGFILEPATH
  990. VLA-GET-PLOTORIGIN
  991. VLA-GET-PLOTPOLICY
  992. VLA-GET-PLOTROTATION
  993. VLA-GET-PLOTSTYLENAME
  994. VLA-GET-PLOTTABLE
  995. VLA-GET-PLOTTYPE
  996. VLA-GET-PLOTVIEWPORTBORDERS
  997. VLA-GET-PLOTVIEWPORTSFIRST
  998. VLA-GET-PLOTWITHLINEWEIGHTS
  999. VLA-GET-PLOTWITHPLOTSTYLES
  1000. VLA-GET-POLARTRACKINGVECTOR
  1001. VLA-GET-POSITION
  1002. VLA-GET-POSTSCRIPTPROLOGFILE
  1003. VLA-GET-PREFERENCES
  1004. VLA-GET-PRESET
  1005. VLA-GET-PRIMARYUNITSPRECISION
  1006. VLA-GET-PRINCIPALDIRECTIONS
  1007. VLA-GET-PRINCIPALMOMENTS
  1008. VLA-GET-PRINTERCONFIGPATH
  1009. VLA-GET-PRINTERDESCPATH
  1010. VLA-GET-PRINTERPAPERSIZEALERT
  1011. VLA-GET-PRINTERSPOOLALERT
  1012. VLA-GET-PRINTERSTYLESHEETPATH
  1013. VLA-GET-PRINTFILE
  1014. VLA-GET-PRINTSPOOLERPATH
  1015. VLA-GET-PRINTSPOOLEXECUTABLE
  1016. VLA-GET-PRODUCTOFINERTIA
  1017. VLA-GET-PROFILEROTATION
  1018. VLA-GET-PROFILES
  1019. VLA-GET-PROMPTSTRING
  1020. VLA-GET-PROPERTYNAME
  1021. VLA-GET-PROVIDERNAME
  1022. VLA-GET-PROVIDERTYPE
  1023. VLA-GET-PROXYIMAGE
  1024. VLA-GET-QNEWTEMPLATEFILE
  1025. VLA-GET-QUIETERRORMODE
  1026. VLA-GET-RADIIOFGYRATION
  1027. VLA-GET-RADIUS
  1028. VLA-GET-RADIUSRATIO
  1029. VLA-GET-READONLY
  1030. VLA-GET-RED
  1031. VLA-GET-REFERENCECOUNT
  1032. VLA-GET-REGENERATETABLESUPPRESSED
  1033. VLA-GET-REGISTEREDAPPLICATIONS
  1034. VLA-GET-RENDERSMOOTHNESS
  1035. VLA-GET-REPEATBOTTOMLABELS
  1036. VLA-GET-REPEATTOPLABELS
  1037. VLA-GET-REVISIONNUMBER
  1038. VLA-GET-REVOLUTIONANGLE
  1039. VLA-GET-ROTATION
  1040. VLA-GET-ROUNDDISTANCE
  1041. VLA-GET-ROWS
  1042. VLA-GET-ROWSPACING
  1043. VLA-GET-SAVEASTYPE
  1044. VLA-GET-SAVED
  1045. VLA-GET-SAVEPREVIEWTHUMBNAIL
  1046. VLA-GET-SCALE
  1047. VLA-GET-SCALEFACTOR
  1048. VLA-GET-SCALEHEIGHT
  1049. VLA-GET-SCALELINEWEIGHTS
  1050. VLA-GET-SCALEWIDTH
  1051. VLA-GET-SCMCOMMANDMODE
  1052. VLA-GET-SCMDEFAULTMODE
  1053. VLA-GET-SCMEDITMODE
  1054. VLA-GET-SCMTIMEMODE
  1055. VLA-GET-SCMTIMEVALUE
  1056. VLA-GET-SECONDPOINT
  1057. VLA-GET-SECONDSEGMENTANGLECONSTRAINT
  1058. VLA-GET-SECTIONMANAGER
  1059. VLA-GET-SEGMENTPERPOLYLINE
  1060. VLA-GET-SELECTION
  1061. VLA-GET-SELECTIONSETS
  1062. VLA-GET-SERIALNUMBER
  1063. VLA-GET-SETTINGS
  1064. VLA-GET-SHADEPLOT
  1065. VLA-GET-SHEETVIEW
  1066. VLA-GET-SHORTCUTMENU
  1067. VLA-GET-SHORTCUTMENUDISPLAY
  1068. VLA-GET-SHOW
  1069. VLA-GET-SHOWHISTORY
  1070. VLA-GET-SHOWPLOTSTYLES
  1071. VLA-GET-SHOWPROXYDIALOGBOX
  1072. VLA-GET-SHOWRASTERIMAGE
  1073. VLA-GET-SHOWROTATION
  1074. VLA-GET-SHOWWARNINGMESSAGES
  1075. VLA-GET-SINGLEDOCUMENTMODE
  1076. VLA-GET-SMOOTHNESS
  1077. VLA-GET-SNAPBASEPOINT
  1078. VLA-GET-SNAPON
  1079. VLA-GET-SNAPROTATIONANGLE
  1080. VLA-GET-SOLIDFILL
  1081. VLA-GET-SOLIDTYPE
  1082. VLA-GET-SOURCEOBJECTS
  1083. VLA-GET-STANDARDSCALE
  1084. VLA-GET-STANDARDSCALE2
  1085. VLA-GET-STARTANGLE
  1086. VLA-GET-STARTDRAFTANGLE
  1087. VLA-GET-STARTDRAFTMAGNITUDE
  1088. VLA-GET-STARTPARAMETER
  1089. VLA-GET-STARTPOINT
  1090. VLA-GET-STARTTANGENT
  1091. VLA-GET-STATE
  1092. VLA-GET-STATUSID
  1093. VLA-GET-STORESQLINDEX
  1094. VLA-GET-STYLENAME
  1095. VLA-GET-STYLESHEET
  1096. VLA-GET-SUBJECT
  1097. VLA-GET-SUBMENU
  1098. VLA-GET-SUBUNITSFACTOR
  1099. VLA-GET-SUBUNITSSUFFIX
  1100. VLA-GET-SUMMARYINFO
  1101. VLA-GET-SUPPORTPATH
  1102. VLA-GET-SUPPRESSLEADINGZEROS
  1103. VLA-GET-SUPPRESSTRAILINGZEROS
  1104. VLA-GET-SUPPRESSZEROFEET
  1105. VLA-GET-SUPPRESSZEROINCHES
  1106. VLA-GET-SURFACENORMALS
  1107. VLA-GET-SURFACETYPE
  1108. VLA-GET-SYMBOLPOSITION
  1109. VLA-GET-SYSTEM
  1110. VLA-GET-TABLEBREAKFLOWDIRECTION
  1111. VLA-GET-TABLEBREAKHEIGHT
  1112. VLA-GET-TABLESREADONLY
  1113. VLA-GET-TABLESTYLEOVERRIDES
  1114. VLA-GET-TABORDER
  1115. VLA-GET-TAGSTRING
  1116. VLA-GET-TAPERANGLE
  1117. VLA-GET-TARGET
  1118. VLA-GET-TEMPFILEEXTENSION
  1119. VLA-GET-TEMPFILEPATH
  1120. VLA-GET-TEMPLATEDWGPATH
  1121. VLA-GET-TEMPLATEID
  1122. VLA-GET-TEMPXREFPATH
  1123. VLA-GET-TEXTALIGNMENTPOINT
  1124. VLA-GET-TEXTALIGNMENTTYPE
  1125. VLA-GET-TEXTANGLETYPE
  1126. VLA-GET-TEXTATTACHMENTDIRECTION
  1127. VLA-GET-TEXTBACKGROUNDFILL
  1128. VLA-GET-TEXTBOTTOMATTACHMENTTYPE
  1129. VLA-GET-TEXTCOLOR
  1130. VLA-GET-TEXTDIRECTION
  1131. VLA-GET-TEXTEDITOR
  1132. VLA-GET-TEXTFILL
  1133. VLA-GET-TEXTFILLCOLOR
  1134. VLA-GET-TEXTFONT
  1135. VLA-GET-TEXTFONTSIZE
  1136. VLA-GET-TEXTFONTSTYLE
  1137. VLA-GET-TEXTFRAMEDISPLAY
  1138. VLA-GET-TEXTGAP
  1139. VLA-GET-TEXTGENERATIONFLAG
  1140. VLA-GET-TEXTHEIGHT
  1141. VLA-GET-TEXTINSIDE
  1142. VLA-GET-TEXTINSIDEALIGN
  1143. VLA-GET-TEXTJUSTIFY
  1144. VLA-GET-TEXTLEFTATTACHMENTTYPE
  1145. VLA-GET-TEXTLINESPACINGDISTANCE
  1146. VLA-GET-TEXTLINESPACINGFACTOR
  1147. VLA-GET-TEXTLINESPACINGSTYLE
  1148. VLA-GET-TEXTMOVEMENT
  1149. VLA-GET-TEXTOUTSIDEALIGN
  1150. VLA-GET-TEXTOVERRIDE
  1151. VLA-GET-TEXTPOSITION
  1152. VLA-GET-TEXTPRECISION
  1153. VLA-GET-TEXTPREFIX
  1154. VLA-GET-TEXTRIGHTATTACHMENTTYPE
  1155. VLA-GET-TEXTROTATION
  1156. VLA-GET-TEXTSTRING
  1157. VLA-GET-TEXTSTYLE
  1158. VLA-GET-TEXTSTYLENAME
  1159. VLA-GET-TEXTSTYLES
  1160. VLA-GET-TEXTSUFFIX
  1161. VLA-GET-TEXTTOPATTACHMENTTYPE
  1162. VLA-GET-TEXTUREMAPPATH
  1163. VLA-GET-TEXTWIDTH
  1164. VLA-GET-TEXTWINBACKGRNDCOLOR
  1165. VLA-GET-TEXTWINTEXTCOLOR
  1166. VLA-GET-THICKNESS
  1167. VLA-GET-TIMESERVER
  1168. VLA-GET-TIMESTAMP
  1169. VLA-GET-TITLE
  1170. VLA-GET-TITLESUPPRESSED
  1171. VLA-GET-TOLERANCEDISPLAY
  1172. VLA-GET-TOLERANCEHEIGHTSCALE
  1173. VLA-GET-TOLERANCEJUSTIFICATION
  1174. VLA-GET-TOLERANCELOWERLIMIT
  1175. VLA-GET-TOLERANCEPRECISION
  1176. VLA-GET-TOLERANCESUPPRESSLEADINGZEROS
  1177. VLA-GET-TOLERANCESUPPRESSTRAILINGZEROS
  1178. VLA-GET-TOLERANCESUPPRESSZEROFEET
  1179. VLA-GET-TOLERANCESUPPRESSZEROINCHES
  1180. VLA-GET-TOLERANCEUPPERLIMIT
  1181. VLA-GET-TOOLBARS
  1182. VLA-GET-TOOLPALETTEPATH
  1183. VLA-GET-TOP
  1184. VLA-GET-TOPHEIGHT
  1185. VLA-GET-TOPRADIUS
  1186. VLA-GET-TOTALANGLE
  1187. VLA-GET-TOTALLENGTH
  1188. VLA-GET-TRANSLATEIDS
  1189. VLA-GET-TRANSPARENCY
  1190. VLA-GET-TRUECOLOR
  1191. VLA-GET-TRUECOLORIMAGES
  1192. VLA-GET-TURNHEIGHT
  1193. VLA-GET-TURNS
  1194. VLA-GET-TURNSLOPE
  1195. VLA-GET-TWIST
  1196. VLA-GET-TWISTANGLE
  1197. VLA-GET-TYPE
  1198. VLA-GET-UCSICONATORIGIN
  1199. VLA-GET-UCSICONON
  1200. VLA-GET-UCSPERVIEWPORT
  1201. VLA-GET-UISOLINEDENSITY
  1202. VLA-GET-UNDERLAYLAYEROVERRIDEAPPLIED
  1203. VLA-GET-UNDERLAYNAME
  1204. VLA-GET-UNDERLAYVISIBILITY
  1205. VLA-GET-UNITS
  1206. VLA-GET-UNITSFORMAT
  1207. VLA-GET-UNITSTYPE
  1208. VLA-GET-UPPERRIGHTCORNER
  1209. VLA-GET-UPSIDEDOWN
  1210. VLA-GET-URL
  1211. VLA-GET-URLDESCRIPTION
  1212. VLA-GET-URLNAMEDLOCATION
  1213. VLA-GET-USED
  1214. VLA-GET-USELASTPLOTSETTINGS
  1215. VLA-GET-USER
  1216. VLA-GET-USERCOORDINATESYSTEMS
  1217. VLA-GET-USESTANDARDSCALE
  1218. VLA-GET-UTILITY
  1219. VLA-GET-VALUE
  1220. VLA-GET-VBE
  1221. VLA-GET-VERIFY
  1222. VLA-GET-VERSION
  1223. VLA-GET-VERSIONGUID
  1224. VLA-GET-VERTCELLMARGIN
  1225. VLA-GET-VERTEXCOUNT
  1226. VLA-GET-VERTICALDIRECTION
  1227. VLA-GET-VERTICALTEXTPOSITION
  1228. VLA-GET-VERTICES
  1229. VLA-GET-VIEWINGDIRECTION
  1230. VLA-GET-VIEWPORTDEFAULT
  1231. VLA-GET-VIEWPORTON
  1232. VLA-GET-VIEWPORTS
  1233. VLA-GET-VIEWS
  1234. VLA-GET-VIEWTOPLOT
  1235. VLA-GET-VISIBILITYEDGE1
  1236. VLA-GET-VISIBILITYEDGE2
  1237. VLA-GET-VISIBILITYEDGE3
  1238. VLA-GET-VISIBILITYEDGE4
  1239. VLA-GET-VISIBLE
  1240. VLA-GET-VISOLINEDENSITY
  1241. VLA-GET-VISUALSTYLE
  1242. VLA-GET-VOLUME
  1243. VLA-GET-WEIGHTS
  1244. VLA-GET-WIDTH
  1245. VLA-GET-WINDOWLEFT
  1246. VLA-GET-WINDOWSTATE
  1247. VLA-GET-WINDOWTITLE
  1248. VLA-GET-WINDOWTOP
  1249. VLA-GET-WORKSPACEPATH
  1250. VLA-GET-XEFFECTIVESCALEFACTOR
  1251. VLA-GET-XREFDATABASE
  1252. VLA-GET-XREFDEMANDLOAD
  1253. VLA-GET-XREFEDIT
  1254. VLA-GET-XREFFADEINTENSITY
  1255. VLA-GET-XREFLAYERVISIBILITY
  1256. VLA-GET-XSCALEFACTOR
  1257. VLA-GET-XVECTOR
  1258. VLA-GET-YEFFECTIVESCALEFACTOR
  1259. VLA-GET-YSCALEFACTOR
  1260. VLA-GET-YVECTOR
  1261. VLA-GET-ZEFFECTIVESCALEFACTOR
  1262. VLA-GET-ZSCALEFACTOR
  1263. VLA-GETACADSTATE
  1264. VLA-GETALIGNMENT
  1265. VLA-GETALIGNMENT2
  1266. VLA-GETALLPROFILENAMES
  1267. VLA-GETANGLE
  1268. VLA-GETATTACHMENTPOINT
  1269. VLA-GETATTRIBUTES
  1270. VLA-GETAUTOSCALE
  1271. VLA-GETAUTOSCALE2
  1272. VLA-GETBACKGROUNDCOLOR
  1273. VLA-GETBACKGROUNDCOLOR2
  1274. VLA-GETBACKGROUNDCOLORNONE
  1275. VLA-GETBITMAPS
  1276. VLA-GETBLOCKATTRIBUTEVALUE
  1277. VLA-GETBLOCKATTRIBUTEVALUE2
  1278. VLA-GETBLOCKROTATION
  1279. VLA-GETBLOCKSCALE
  1280. VLA-GETBLOCKTABLERECORDID
  1281. VLA-GETBLOCKTABLERECORDID2
  1282. VLA-GETBOUNDINGBOX
  1283. VLA-GETBREAKHEIGHT
  1284. VLA-GETBULGE
  1285. VLA-GETCANONICALMEDIANAMES
  1286. VLA-GETCELLALIGNMENT
  1287. VLA-GETCELLBACKGROUNDCOLOR
  1288. VLA-GETCELLBACKGROUNDCOLORNONE
  1289. VLA-GETCELLCLASS
  1290. VLA-GETCELLCONTENTCOLOR
  1291. VLA-GETCELLDATATYPE
  1292. VLA-GETCELLEXTENTS
  1293. VLA-GETCELLFORMAT
  1294. VLA-GETCELLGRIDCOLOR
  1295. VLA-GETCELLGRIDLINEWEIGHT
  1296. VLA-GETCELLGRIDVISIBILITY
  1297. VLA-GETCELLSTATE
  1298. VLA-GETCELLSTYLE
  1299. VLA-GETCELLSTYLEOVERRIDES
  1300. VLA-GETCELLSTYLES
  1301. VLA-GETCELLTEXTHEIGHT
  1302. VLA-GETCELLTEXTSTYLE
  1303. VLA-GETCELLTYPE
  1304. VLA-GETCELLVALUE
  1305. VLA-GETCOLOR
  1306. VLA-GETCOLOR2
  1307. VLA-GETCOLUMNNAME
  1308. VLA-GETCOLUMNWIDTH
  1309. VLA-GETCONSTANTATTRIBUTES
  1310. VLA-GETCONTENTCOLOR
  1311. VLA-GETCONTENTCOLOR2
  1312. VLA-GETCONTENTLAYOUT
  1313. VLA-GETCONTENTTYPE
  1314. VLA-GETCONTROLPOINT
  1315. VLA-GETCORNER
  1316. VLA-GETCUSTOMBYINDEX
  1317. VLA-GETCUSTOMBYKEY
  1318. VLA-GETCUSTOMDATA
  1319. VLA-GETCUSTOMSCALE
  1320. VLA-GETDATAFORMAT
  1321. VLA-GETDATATYPE
  1322. VLA-GETDATATYPE2
  1323. VLA-GETDISTANCE
  1324. VLA-GETDOGLEGDIRECTION
  1325. VLA-GETDYNAMICBLOCKPROPERTIES
  1326. VLA-GETENTITY
  1327. VLA-GETEXTENSIONDICTIONARY
  1328. VLA-GETFIELDID
  1329. VLA-GETFIELDID2
  1330. VLA-GETFITPOINT
  1331. VLA-GETFONT
  1332. VLA-GETFORMAT
  1333. VLA-GETFORMAT2
  1334. VLA-GETFORMULA
  1335. VLA-GETFULLDRAWORDER
  1336. VLA-GETGRIDCOLOR
  1337. VLA-GETGRIDCOLOR2
  1338. VLA-GETGRIDDOUBLELINESPACING
  1339. VLA-GETGRIDLINESTYLE
  1340. VLA-GETGRIDLINETYPE
  1341. VLA-GETGRIDLINEWEIGHT
  1342. VLA-GETGRIDLINEWEIGHT2
  1343. VLA-GETGRIDSPACING
  1344. VLA-GETGRIDVISIBILITY
  1345. VLA-GETGRIDVISIBILITY2
  1346. VLA-GETHASFORMULA
  1347. VLA-GETINPUT
  1348. VLA-GETINTEGER
  1349. VLA-GETINTERFACEOBJECT
  1350. VLA-GETINVISIBLEEDGE
  1351. VLA-GETISCELLSTYLEINUSE
  1352. VLA-GETISMERGEALLENABLED
  1353. VLA-GETKEYWORD
  1354. VLA-GETLEADERINDEX
  1355. VLA-GETLEADERLINEINDEXES
  1356. VLA-GETLEADERLINEVERTICES
  1357. VLA-GETLIVESECTION
  1358. VLA-GETLOCALEMEDIANAME
  1359. VLA-GETLOOPAT
  1360. VLA-GETMARGIN
  1361. VLA-GETMINIMUMCOLUMNWIDTH
  1362. VLA-GETMINIMUMROWHEIGHT
  1363. VLA-GETNAME
  1364. VLA-GETOBJECT
  1365. VLA-GETOBJECTIDSTRING
  1366. VLA-GETORIENTATION
  1367. VLA-GETOVERRIDE
  1368. VLA-GETPAPERMARGINS
  1369. VLA-GETPAPERSIZE
  1370. VLA-GETPLOTDEVICENAMES
  1371. VLA-GETPLOTSTYLETABLENAMES
  1372. VLA-GETPOINT
  1373. VLA-GETPROJECTFILEPATH
  1374. VLA-GETREAL
  1375. VLA-GETRELATIVEDRAWORDER
  1376. VLA-GETREMOTEFILE
  1377. VLA-GETROTATION
  1378. VLA-GETROWHEIGHT
  1379. VLA-GETROWTYPE
  1380. VLA-GETSCALE
  1381. VLA-GETSECTIONTYPESETTINGS
  1382. VLA-GETSNAPSPACING
  1383. VLA-GETSTRING
  1384. VLA-GETSUBENTITY
  1385. VLA-GETSUBSELECTION
  1386. VLA-GETTEXT
  1387. VLA-GETTEXTHEIGHT
  1388. VLA-GETTEXTHEIGHT2
  1389. VLA-GETTEXTROTATION
  1390. VLA-GETTEXTSTRING
  1391. VLA-GETTEXTSTYLE
  1392. VLA-GETTEXTSTYLE2
  1393. VLA-GETTEXTSTYLEID
  1394. VLA-GETUCSMATRIX
  1395. VLA-GETUNIQUECELLSTYLENAME
  1396. VLA-GETUNIQUESECTIONNAME
  1397. VLA-GETVALUE
  1398. VLA-GETVARIABLE
  1399. VLA-GETVERTEXCOUNT
  1400. VLA-GETWEIGHT
  1401. VLA-GETWIDTH
  1402. VLA-GETWINDOWTOPLOT
  1403. VLA-GETXDATA
  1404. VLA-GETXRECORDDATA
  1405. VLA-HANDLETOOBJECT
  1406. VLA-HIGHLIGHT
  1407. VLA-HITTEST
  1408. VLA-IMPORT
  1409. VLA-IMPORTPROFILE
  1410. VLA-INDEXOF
  1411. VLA-INITIALIZEUSERINPUT
  1412. VLA-INSERTBLOCK
  1413. VLA-INSERTCOLUMNS
  1414. VLA-INSERTCOLUMNSANDINHERIT
  1415. VLA-INSERTINMENUBAR
  1416. VLA-INSERTLOOPAT
  1417. VLA-INSERTMENUINMENUBAR
  1418. VLA-INSERTROWS
  1419. VLA-INSERTROWSANDINHERIT
  1420. VLA-INTERSECTWITH
  1421. VLA-ISCONTENTEDITABLE
  1422. VLA-ISEMPTY
  1423. VLA-ISFORMATEDITABLE
  1424. VLA-ISMERGEALLENABLED
  1425. VLA-ISMERGEDCELL
  1426. VLA-ISREMOTEFILE
  1427. VLA-ISURL
  1428. VLA-ITEM
  1429. VLA-LAUNCHBROWSERDIALOG
  1430. VLA-LISTARX
  1431. VLA-LOAD
  1432. VLA-LOADARX
  1433. VLA-LOADDVB
  1434. VLA-LOADSHAPEFILE
  1435. VLA-MERGECELLS
  1436. VLA-MIRROR
  1437. VLA-MIRROR3D
  1438. VLA-MODIFIED
  1439. VLA-MOVE
  1440. VLA-MOVEABOVE
  1441. VLA-MOVEBELOW
  1442. VLA-MOVECONTENT
  1443. VLA-MOVETOBOTTOM
  1444. VLA-MOVETOTOP
  1445. VLA-NEW
  1446. VLA-NUMCUSTOMINFO
  1447. VLA-OBJECTIDTOOBJECT
  1448. VLA-OFFSET
  1449. VLA-ONMODIFIED
  1450. VLA-OPEN
  1451. VLA-PLOTTODEVICE
  1452. VLA-PLOTTOFILE
  1453. VLA-POLARPOINT
  1454. VLA-PROMPT
  1455. VLA-PURGEALL
  1456. VLA-PURGEFITDATA
  1457. VLA-PUT-ACTION
  1458. VLA-PUT-ACTIVEDIMSTYLE
  1459. VLA-PUT-ACTIVEDOCUMENT
  1460. VLA-PUT-ACTIVELAYER
  1461. VLA-PUT-ACTIVELAYOUT
  1462. VLA-PUT-ACTIVELINETYPE
  1463. VLA-PUT-ACTIVEMATERIAL
  1464. VLA-PUT-ACTIVEPROFILE
  1465. VLA-PUT-ACTIVEPVIEWPORT
  1466. VLA-PUT-ACTIVESPACE
  1467. VLA-PUT-ACTIVETEXTSTYLE
  1468. VLA-PUT-ACTIVEUCS
  1469. VLA-PUT-ACTIVEVIEWPORT
  1470. VLA-PUT-ADCINSERTUNITSDEFAULTSOURCE
  1471. VLA-PUT-ADCINSERTUNITSDEFAULTTARGET
  1472. VLA-PUT-ADJUSTFORBACKGROUND
  1473. VLA-PUT-ALGORITHM
  1474. VLA-PUT-ALIGNMENT
  1475. VLA-PUT-ALIGNMENTPOINTACQUISITION
  1476. VLA-PUT-ALIGNSPACE
  1477. VLA-PUT-ALLOWLONGSYMBOLNAMES
  1478. VLA-PUT-ALLOWMANUALHEIGHTS
  1479. VLA-PUT-ALLOWMANUALPOSITIONS
  1480. VLA-PUT-ALTFONTFILE
  1481. VLA-PUT-ALTROUNDDISTANCE
  1482. VLA-PUT-ALTSUBUNITSFACTOR
  1483. VLA-PUT-ALTSUBUNITSSUFFIX
  1484. VLA-PUT-ALTSUPPRESSLEADINGZEROS
  1485. VLA-PUT-ALTSUPPRESSTRAILINGZEROS
  1486. VLA-PUT-ALTSUPPRESSZEROFEET
  1487. VLA-PUT-ALTSUPPRESSZEROINCHES
  1488. VLA-PUT-ALTTABLETMENUFILE
  1489. VLA-PUT-ALTTEXTPREFIX
  1490. VLA-PUT-ALTTEXTSUFFIX
  1491. VLA-PUT-ALTTOLERANCEPRECISION
  1492. VLA-PUT-ALTTOLERANCESUPPRESSLEADINGZEROS
  1493. VLA-PUT-ALTTOLERANCESUPPRESSTRAILINGZEROS
  1494. VLA-PUT-ALTTOLERANCESUPPRESSZEROFEET
  1495. VLA-PUT-ALTTOLERANCESUPPRESSZEROINCHES
  1496. VLA-PUT-ALTUNITS
  1497. VLA-PUT-ALTUNITSFORMAT
  1498. VLA-PUT-ALTUNITSPRECISION
  1499. VLA-PUT-ALTUNITSSCALE
  1500. VLA-PUT-ANGLEFORMAT
  1501. VLA-PUT-ANGLEVERTEX
  1502. VLA-PUT-ANNOTATION
  1503. VLA-PUT-ANNOTATIVE
  1504. VLA-PUT-ARCENDPARAM
  1505. VLA-PUT-ARCPOINT
  1506. VLA-PUT-ARCSMOOTHNESS
  1507. VLA-PUT-ARCSTARTPARAM
  1508. VLA-PUT-AREA
  1509. VLA-PUT-ARROWHEAD1BLOCK
  1510. VLA-PUT-ARROWHEAD1TYPE
  1511. VLA-PUT-ARROWHEAD2BLOCK
  1512. VLA-PUT-ARROWHEAD2TYPE
  1513. VLA-PUT-ARROWHEADBLOCK
  1514. VLA-PUT-ARROWHEADSIZE
  1515. VLA-PUT-ARROWHEADTYPE
  1516. VLA-PUT-ARROWSIZE
  1517. VLA-PUT-ARROWSYMBOL
  1518. VLA-PUT-ASSOCIATIVEHATCH
  1519. VLA-PUT-ATTACHMENTPOINT
  1520. VLA-PUT-AUTHOR
  1521. VLA-PUT-AUTOAUDIT
  1522. VLA-PUT-AUTOMATICPLOTLOG
  1523. VLA-PUT-AUTOSAVEINTERVAL
  1524. VLA-PUT-AUTOSAVEPATH
  1525. VLA-PUT-AUTOSNAPAPERTURE
  1526. VLA-PUT-AUTOSNAPAPERTURESIZE
  1527. VLA-PUT-AUTOSNAPMAGNET
  1528. VLA-PUT-AUTOSNAPMARKER
  1529. VLA-PUT-AUTOSNAPMARKERCOLOR
  1530. VLA-PUT-AUTOSNAPMARKERSIZE
  1531. VLA-PUT-AUTOSNAPTOOLTIP
  1532. VLA-PUT-AUTOTRACKINGVECCOLOR
  1533. VLA-PUT-AUTOTRACKTOOLTIP
  1534. VLA-PUT-AXISPOSITION
  1535. VLA-PUT-BACKGROUNDFILL
  1536. VLA-PUT-BACKGROUNDLINESCOLOR
  1537. VLA-PUT-BACKGROUNDLINESHIDDENLINE
  1538. VLA-PUT-BACKGROUNDLINESLAYER
  1539. VLA-PUT-BACKGROUNDLINESLINETYPE
  1540. VLA-PUT-BACKGROUNDLINESLINETYPESCALE
  1541. VLA-PUT-BACKGROUNDLINESLINEWEIGHT
  1542. VLA-PUT-BACKGROUNDLINESPLOTSTYLENAME
  1543. VLA-PUT-BACKGROUNDLINESVISIBLE
  1544. VLA-PUT-BACKWARD
  1545. VLA-PUT-BANK
  1546. VLA-PUT-BASEPOINT
  1547. VLA-PUT-BASERADIUS
  1548. VLA-PUT-BATCHPLOTPROGRESS
  1549. VLA-PUT-BEEPONERROR
  1550. VLA-PUT-BIGFONTFILE
  1551. VLA-PUT-BITFLAGS
  1552. VLA-PUT-BLOCK
  1553. VLA-PUT-BLOCKCOLOR
  1554. VLA-PUT-BLOCKCONNECTIONTYPE
  1555. VLA-PUT-BLOCKROTATION
  1556. VLA-PUT-BLOCKSCALE
  1557. VLA-PUT-BLOCKSCALING
  1558. VLA-PUT-BOTTOMHEIGHT
  1559. VLA-PUT-BREAKSENABLED
  1560. VLA-PUT-BREAKSIZE
  1561. VLA-PUT-BREAKSPACING
  1562. VLA-PUT-BRIGHTNESS
  1563. VLA-PUT-CANONICALMEDIANAME
  1564. VLA-PUT-CATEGORYNAME
  1565. VLA-PUT-CENTER
  1566. VLA-PUT-CENTERMARKSIZE
  1567. VLA-PUT-CENTERPLOT
  1568. VLA-PUT-CENTERPOINT
  1569. VLA-PUT-CENTERTYPE
  1570. VLA-PUT-CHECK
  1571. VLA-PUT-CHORDPOINT
  1572. VLA-PUT-CIRCUMFERENCE
  1573. VLA-PUT-CLIPPINGENABLED
  1574. VLA-PUT-CLOSED
  1575. VLA-PUT-COLOR
  1576. VLA-PUT-COLORBOOKPATH
  1577. VLA-PUT-COLORINDEX
  1578. VLA-PUT-COLORMETHOD
  1579. VLA-PUT-COLUMNS
  1580. VLA-PUT-COLUMNSPACING
  1581. VLA-PUT-COLUMNWIDTH
  1582. VLA-PUT-COMMANDDISPLAYNAME
  1583. VLA-PUT-COMMENT
  1584. VLA-PUT-COMMENTS
  1585. VLA-PUT-CONFIGNAME
  1586. VLA-PUT-CONSTANT
  1587. VLA-PUT-CONSTANTWIDTH
  1588. VLA-PUT-CONSTRAIN
  1589. VLA-PUT-CONTENTBLOCKNAME
  1590. VLA-PUT-CONTENTBLOCKTYPE
  1591. VLA-PUT-CONTENTTYPE
  1592. VLA-PUT-CONTINUOUSPLOTLOG
  1593. VLA-PUT-CONTOURLINESPERSURFACE
  1594. VLA-PUT-CONTRAST
  1595. VLA-PUT-CONTROLPOINTS
  1596. VLA-PUT-COORDINATE
  1597. VLA-PUT-COORDINATES
  1598. VLA-PUT-CREASELEVEL
  1599. VLA-PUT-CREASETYPE
  1600. VLA-PUT-CREATEBACKUP
  1601. VLA-PUT-CURRENTSECTIONTYPE
  1602. VLA-PUT-CURSORSIZE
  1603. VLA-PUT-CURVETANGENCYLINESCOLOR
  1604. VLA-PUT-CURVETANGENCYLINESLAYER
  1605. VLA-PUT-CURVETANGENCYLINESLINETYPE
  1606. VLA-PUT-CURVETANGENCYLINESLINETYPESCALE
  1607. VLA-PUT-CURVETANGENCYLINESLINEWEIGHT
  1608. VLA-PUT-CURVETANGENCYLINESPLOTSTYLENAME
  1609. VLA-PUT-CURVETANGENCYLINESVISIBLE
  1610. VLA-PUT-CUSTOMDICTIONARY
  1611. VLA-PUT-CUSTOMICONPATH
  1612. VLA-PUT-CUSTOMSCALE
  1613. VLA-PUT-DECIMALSEPARATOR
  1614. VLA-PUT-DEFAULTINTERNETURL
  1615. VLA-PUT-DEFAULTOUTPUTDEVICE
  1616. VLA-PUT-DEFAULTPLOTSTYLEFORLAYER
  1617. VLA-PUT-DEFAULTPLOTSTYLEFOROBJECTS
  1618. VLA-PUT-DEFAULTPLOTSTYLETABLE
  1619. VLA-PUT-DEFAULTPLOTTOFILEPATH
  1620. VLA-PUT-DEMANDLOADARXAPP
  1621. VLA-PUT-DESCRIPTION
  1622. VLA-PUT-DESTINATIONBLOCK
  1623. VLA-PUT-DESTINATIONFILE
  1624. VLA-PUT-DIAMETER
  1625. VLA-PUT-DIMCONSTRDESC
  1626. VLA-PUT-DIMCONSTREXPRESSION
  1627. VLA-PUT-DIMCONSTRFORM
  1628. VLA-PUT-DIMCONSTRNAME
  1629. VLA-PUT-DIMCONSTRREFERENCE
  1630. VLA-PUT-DIMCONSTRVALUE
  1631. VLA-PUT-DIMENSIONLINECOLOR
  1632. VLA-PUT-DIMENSIONLINEEXTEND
  1633. VLA-PUT-DIMENSIONLINETYPE
  1634. VLA-PUT-DIMENSIONLINEWEIGHT
  1635. VLA-PUT-DIMLINE1SUPPRESS
  1636. VLA-PUT-DIMLINE2SUPPRESS
  1637. VLA-PUT-DIMLINEINSIDE
  1638. VLA-PUT-DIMLINESUPPRESS
  1639. VLA-PUT-DIMTXTDIRECTION
  1640. VLA-PUT-DIRECTION
  1641. VLA-PUT-DIRECTIONVECTOR
  1642. VLA-PUT-DISPLAYGRIPS
  1643. VLA-PUT-DISPLAYGRIPSWITHINBLOCKS
  1644. VLA-PUT-DISPLAYLAYOUTTABS
  1645. VLA-PUT-DISPLAYLOCKED
  1646. VLA-PUT-DISPLAYOLESCALE
  1647. VLA-PUT-DISPLAYSCREENMENU
  1648. VLA-PUT-DISPLAYSCROLLBARS
  1649. VLA-PUT-DISPLAYSILHOUETTE
  1650. VLA-PUT-DOCKEDVISIBLELINES
  1651. VLA-PUT-DOGLEGGED
  1652. VLA-PUT-DOGLEGLENGTH
  1653. VLA-PUT-DRAWINGDIRECTION
  1654. VLA-PUT-DRAWLEADERORDERTYPE
  1655. VLA-PUT-DRAWMLEADERORDERTYPE
  1656. VLA-PUT-DRIVERSPATH
  1657. VLA-PUT-DWFFORMAT
  1658. VLA-PUT-ELEVATION
  1659. VLA-PUT-ELEVATIONMODELSPACE
  1660. VLA-PUT-ELEVATIONPAPERSPACE
  1661. VLA-PUT-ENABLE
  1662. VLA-PUT-ENABLEBLOCKROTATION
  1663. VLA-PUT-ENABLEBLOCKSCALE
  1664. VLA-PUT-ENABLEBREAK
  1665. VLA-PUT-ENABLEDOGLEG
  1666. VLA-PUT-ENABLEFRAMETEXT
  1667. VLA-PUT-ENABLELANDING
  1668. VLA-PUT-ENABLESTARTUPDIALOG
  1669. VLA-PUT-ENDANGLE
  1670. VLA-PUT-ENDDRAFTANGLE
  1671. VLA-PUT-ENDDRAFTMAGNITUDE
  1672. VLA-PUT-ENDPARAMETER
  1673. VLA-PUT-ENDPOINT
  1674. VLA-PUT-ENDSUBMENULEVEL
  1675. VLA-PUT-ENDTANGENT
  1676. VLA-PUT-ENTERPRISEMENUFILE
  1677. VLA-PUT-ENTITYCOLOR
  1678. VLA-PUT-EXPLODABLE
  1679. VLA-PUT-EXTENSIONLINECOLOR
  1680. VLA-PUT-EXTENSIONLINEEXTEND
  1681. VLA-PUT-EXTENSIONLINEOFFSET
  1682. VLA-PUT-EXTENSIONLINEWEIGHT
  1683. VLA-PUT-EXTLINE1ENDPOINT
  1684. VLA-PUT-EXTLINE1LINETYPE
  1685. VLA-PUT-EXTLINE1POINT
  1686. VLA-PUT-EXTLINE1STARTPOINT
  1687. VLA-PUT-EXTLINE1SUPPRESS
  1688. VLA-PUT-EXTLINE2ENDPOINT
  1689. VLA-PUT-EXTLINE2LINETYPE
  1690. VLA-PUT-EXTLINE2POINT
  1691. VLA-PUT-EXTLINE2STARTPOINT
  1692. VLA-PUT-EXTLINE2SUPPRESS
  1693. VLA-PUT-EXTLINEFIXEDLEN
  1694. VLA-PUT-EXTLINEFIXEDLENSUPPRESS
  1695. VLA-PUT-FADE
  1696. VLA-PUT-FIELDLENGTH
  1697. VLA-PUT-FILE
  1698. VLA-PUT-FIRSTSEGMENTANGLECONSTRAINT
  1699. VLA-PUT-FIT
  1700. VLA-PUT-FITPOINTS
  1701. VLA-PUT-FITTOLERANCE
  1702. VLA-PUT-FLOATINGROWS
  1703. VLA-PUT-FLOWDIRECTION
  1704. VLA-PUT-FONTFILE
  1705. VLA-PUT-FONTFILEMAP
  1706. VLA-PUT-FORCELINEINSIDE
  1707. VLA-PUT-FOREGROUNDLINESCOLOR
  1708. VLA-PUT-FOREGROUNDLINESEDGETRANSPARENCY
  1709. VLA-PUT-FOREGROUNDLINESFACETRANSPARENCY
  1710. VLA-PUT-FOREGROUNDLINESHIDDENLINE
  1711. VLA-PUT-FOREGROUNDLINESLAYER
  1712. VLA-PUT-FOREGROUNDLINESLINETYPE
  1713. VLA-PUT-FOREGROUNDLINESLINETYPESCALE
  1714. VLA-PUT-FOREGROUNDLINESLINEWEIGHT
  1715. VLA-PUT-FOREGROUNDLINESPLOTSTYLENAME
  1716. VLA-PUT-FOREGROUNDLINESVISIBLE
  1717. VLA-PUT-FRACTIONFORMAT
  1718. VLA-PUT-FREEZE
  1719. VLA-PUT-FULLCRCVALIDATION
  1720. VLA-PUT-FULLSCREENTRACKINGVECTOR
  1721. VLA-PUT-GENERATIONOPTIONS
  1722. VLA-PUT-GRADIENTANGLE
  1723. VLA-PUT-GRADIENTCENTERED
  1724. VLA-PUT-GRADIENTCOLOR1
  1725. VLA-PUT-GRADIENTCOLOR2
  1726. VLA-PUT-GRADIENTNAME
  1727. VLA-PUT-GRAPHICSWINLAYOUTBACKGRNDCOLOR
  1728. VLA-PUT-GRAPHICSWINMODELBACKGRNDCOLOR
  1729. VLA-PUT-GRIDON
  1730. VLA-PUT-GRIPCOLORSELECTED
  1731. VLA-PUT-GRIPCOLORUNSELECTED
  1732. VLA-PUT-GRIPSIZE
  1733. VLA-PUT-HASLEADER
  1734. VLA-PUT-HASVPASSOCIATION
  1735. VLA-PUT-HATCHOBJECTTYPE
  1736. VLA-PUT-HATCHSTYLE
  1737. VLA-PUT-HEADERSUPPRESSED
  1738. VLA-PUT-HEIGHT
  1739. VLA-PUT-HELPFILEPATH
  1740. VLA-PUT-HELPSTRING
  1741. VLA-PUT-HISTORY
  1742. VLA-PUT-HISTORYLINES
  1743. VLA-PUT-HORIZONTALTEXTPOSITION
  1744. VLA-PUT-HORZCELLMARGIN
  1745. VLA-PUT-HYPERLINKBASE
  1746. VLA-PUT-HYPERLINKDISPLAYCURSOR
  1747. VLA-PUT-IMAGEFILE
  1748. VLA-PUT-IMAGEFRAMEHIGHLIGHT
  1749. VLA-PUT-IMAGEHEIGHT
  1750. VLA-PUT-IMAGEVISIBILITY
  1751. VLA-PUT-IMAGEWIDTH
  1752. VLA-PUT-INCREMENTALSAVEPERCENT
  1753. VLA-PUT-INDICATORFILLCOLOR
  1754. VLA-PUT-INDICATORTRANSPARENCY
  1755. VLA-PUT-INSERTIONPOINT
  1756. VLA-PUT-INTERSECTIONBOUNDARYCOLOR
  1757. VLA-PUT-INTERSECTIONBOUNDARYDIVISIONLINES
  1758. VLA-PUT-INTERSECTIONBOUNDARYLAYER
  1759. VLA-PUT-INTERSECTIONBOUNDARYLINETYPE
  1760. VLA-PUT-INTERSECTIONBOUNDARYLINETYPESCALE
  1761. VLA-PUT-INTERSECTIONBOUNDARYLINEWEIGHT
  1762. VLA-PUT-INTERSECTIONBOUNDARYPLOTSTYLENAME
  1763. VLA-PUT-INTERSECTIONBOUNDARYVISIBLE
  1764. VLA-PUT-INTERSECTIONFILLCOLOR
  1765. VLA-PUT-INTERSECTIONFILLFACETRANSPARENCY
  1766. VLA-PUT-INTERSECTIONFILLHATCHANGLE
  1767. VLA-PUT-INTERSECTIONFILLHATCHPATTERNNAME
  1768. VLA-PUT-INTERSECTIONFILLHATCHPATTERNTYPE
  1769. VLA-PUT-INTERSECTIONFILLHATCHSCALE
  1770. VLA-PUT-INTERSECTIONFILLHATCHSPACING
  1771. VLA-PUT-INTERSECTIONFILLLAYER
  1772. VLA-PUT-INTERSECTIONFILLLINETYPE
  1773. VLA-PUT-INTERSECTIONFILLLINETYPESCALE
  1774. VLA-PUT-INTERSECTIONFILLLINEWEIGHT
  1775. VLA-PUT-INTERSECTIONFILLPLOTSTYLENAME
  1776. VLA-PUT-INTERSECTIONFILLVISIBLE
  1777. VLA-PUT-INVISIBLE
  1778. VLA-PUT-ISOPENWIDTH
  1779. VLA-PUT-ISPARTIAL
  1780. VLA-PUT-ISSUER
  1781. VLA-PUT-ITEMNAME
  1782. VLA-PUT-JOGANGLE
  1783. VLA-PUT-JOGLOCATION
  1784. VLA-PUT-JUSTIFICATION
  1785. VLA-PUT-KEYBOARDACCELERATOR
  1786. VLA-PUT-KEYBOARDPRIORITY
  1787. VLA-PUT-KEYLENGTH
  1788. VLA-PUT-KEYWORDS
  1789. VLA-PUT-KNOTS
  1790. VLA-PUT-LABEL
  1791. VLA-PUT-LABELBLOCKID
  1792. VLA-PUT-LANDINGGAP
  1793. VLA-PUT-LARGEBUTTONS
  1794. VLA-PUT-LASTHEIGHT
  1795. VLA-PUT-LASTSAVEDBY
  1796. VLA-PUT-LAYER
  1797. VLA-PUT-LAYERON
  1798. VLA-PUT-LAYERSTATE
  1799. VLA-PUT-LAYOUTCREATEVIEWPORT
  1800. VLA-PUT-LAYOUTCROSSHAIRCOLOR
  1801. VLA-PUT-LAYOUTDISPLAYMARGINS
  1802. VLA-PUT-LAYOUTDISPLAYPAPER
  1803. VLA-PUT-LAYOUTDISPLAYPAPERSHADOW
  1804. VLA-PUT-LAYOUTID
  1805. VLA-PUT-LAYOUTSHOWPLOTSETUP
  1806. VLA-PUT-LEADER1POINT
  1807. VLA-PUT-LEADER2POINT
  1808. VLA-PUT-LEADERLENGTH
  1809. VLA-PUT-LEADERLINECOLOR
  1810. VLA-PUT-LEADERLINETYPE
  1811. VLA-PUT-LEADERLINETYPEID
  1812. VLA-PUT-LEADERLINEWEIGHT
  1813. VLA-PUT-LEADERTYPE
  1814. VLA-PUT-LEFT
  1815. VLA-PUT-LENSLENGTH
  1816. VLA-PUT-LIMITS
  1817. VLA-PUT-LINEARSCALEFACTOR
  1818. VLA-PUT-LINESPACINGDISTANCE
  1819. VLA-PUT-LINESPACINGFACTOR
  1820. VLA-PUT-LINESPACINGSTYLE
  1821. VLA-PUT-LINETYPE
  1822. VLA-PUT-LINETYPEGENERATION
  1823. VLA-PUT-LINETYPESCALE
  1824. VLA-PUT-LINEWEIGHT
  1825. VLA-PUT-LINEWEIGHTDISPLAY
  1826. VLA-PUT-LIVESECTIONENABLED
  1827. VLA-PUT-LOADACADLSPINALLDOCUMENTS
  1828. VLA-PUT-LOCK
  1829. VLA-PUT-LOCKASPECTRATIO
  1830. VLA-PUT-LOCKPOSITION
  1831. VLA-PUT-LOGFILEON
  1832. VLA-PUT-LOGFILEPATH
  1833. VLA-PUT-MACRO
  1834. VLA-PUT-MAINDICTIONARY
  1835. VLA-PUT-MAJORAXIS
  1836. VLA-PUT-MAJORRADIUS
  1837. VLA-PUT-MASK
  1838. VLA-PUT-MATERIAL
  1839. VLA-PUT-MAXACTIVEVIEWPORTS
  1840. VLA-PUT-MAXAUTOCADWINDOW
  1841. VLA-PUT-MAXLEADERSEGMENTSPOINTS
  1842. VLA-PUT-MCLOSE
  1843. VLA-PUT-MDENSITY
  1844. VLA-PUT-MENUFILE
  1845. VLA-PUT-MINORRADIUS
  1846. VLA-PUT-MLINESCALE
  1847. VLA-PUT-MODE
  1848. VLA-PUT-MODELCROSSHAIRCOLOR
  1849. VLA-PUT-MODELVIEW
  1850. VLA-PUT-MONOCHROME
  1851. VLA-PUT-MSPACE
  1852. VLA-PUT-MTEXTATTRIBUTE
  1853. VLA-PUT-MTEXTATTRIBUTECONTENT
  1854. VLA-PUT-MTEXTBOUNDARYWIDTH
  1855. VLA-PUT-MTEXTDRAWINGDIRECTION
  1856. VLA-PUT-NAME
  1857. VLA-PUT-NCLOSE
  1858. VLA-PUT-NDENSITY
  1859. VLA-PUT-NORMAL
  1860. VLA-PUT-NUMBEROFCOPIES
  1861. VLA-PUT-OBJECTSNAPMODE
  1862. VLA-PUT-OBJECTSORTBYPLOTTING
  1863. VLA-PUT-OBJECTSORTBYPSOUTPUT
  1864. VLA-PUT-OBJECTSORTBYREDRAWS
  1865. VLA-PUT-OBJECTSORTBYREGENS
  1866. VLA-PUT-OBJECTSORTBYSELECTION
  1867. VLA-PUT-OBJECTSORTBYSNAP
  1868. VLA-PUT-OBLIQUEANGLE
  1869. VLA-PUT-OLEITEMTYPE
  1870. VLA-PUT-OLELAUNCH
  1871. VLA-PUT-OLEPLOTQUALITY
  1872. VLA-PUT-OLEQUALITY
  1873. VLA-PUT-OLESOURCEAPP
  1874. VLA-PUT-ORIGIN
  1875. VLA-PUT-ORTHOON
  1876. VLA-PUT-OVERRIDECENTER
  1877. VLA-PUT-PAGESETUPOVERRIDESTEMPLATEFILE
  1878. VLA-PUT-PAPERUNITS
  1879. VLA-PUT-PASSWORD
  1880. VLA-PUT-PATH
  1881. VLA-PUT-PATTERNANGLE
  1882. VLA-PUT-PATTERNDOUBLE
  1883. VLA-PUT-PATTERNSCALE
  1884. VLA-PUT-PATTERNSPACE
  1885. VLA-PUT-PICKADD
  1886. VLA-PUT-PICKAUTO
  1887. VLA-PUT-PICKBOXSIZE
  1888. VLA-PUT-PICKDRAG
  1889. VLA-PUT-PICKFIRST
  1890. VLA-PUT-PICKGROUP
  1891. VLA-PUT-PLOTHIDDEN
  1892. VLA-PUT-PLOTLEGACY
  1893. VLA-PUT-PLOTLOGFILEPATH
  1894. VLA-PUT-PLOTORIGIN
  1895. VLA-PUT-PLOTPOLICY
  1896. VLA-PUT-PLOTROTATION
  1897. VLA-PUT-PLOTSTYLENAME
  1898. VLA-PUT-PLOTTABLE
  1899. VLA-PUT-PLOTTYPE
  1900. VLA-PUT-PLOTVIEWPORTBORDERS
  1901. VLA-PUT-PLOTVIEWPORTSFIRST
  1902. VLA-PUT-PLOTWITHLINEWEIGHTS
  1903. VLA-PUT-PLOTWITHPLOTSTYLES
  1904. VLA-PUT-POLARTRACKINGVECTOR
  1905. VLA-PUT-POSITION
  1906. VLA-PUT-POSTSCRIPTPROLOGFILE
  1907. VLA-PUT-PRESET
  1908. VLA-PUT-PRIMARYUNITSPRECISION
  1909. VLA-PUT-PRINTERCONFIGPATH
  1910. VLA-PUT-PRINTERDESCPATH
  1911. VLA-PUT-PRINTERPAPERSIZEALERT
  1912. VLA-PUT-PRINTERSPOOLALERT
  1913. VLA-PUT-PRINTERSTYLESHEETPATH
  1914. VLA-PUT-PRINTFILE
  1915. VLA-PUT-PRINTSPOOLERPATH
  1916. VLA-PUT-PRINTSPOOLEXECUTABLE
  1917. VLA-PUT-PROFILEROTATION
  1918. VLA-PUT-PROMPTSTRING
  1919. VLA-PUT-PROVIDERNAME
  1920. VLA-PUT-PROVIDERTYPE
  1921. VLA-PUT-PROXYIMAGE
  1922. VLA-PUT-QNEWTEMPLATEFILE
  1923. VLA-PUT-QUIETERRORMODE
  1924. VLA-PUT-RADIUS
  1925. VLA-PUT-RADIUSRATIO
  1926. VLA-PUT-REGENERATETABLESUPPRESSED
  1927. VLA-PUT-RENDERSMOOTHNESS
  1928. VLA-PUT-REPEATBOTTOMLABELS
  1929. VLA-PUT-REPEATTOPLABELS
  1930. VLA-PUT-REVISIONNUMBER
  1931. VLA-PUT-REVOLUTIONANGLE
  1932. VLA-PUT-ROTATION
  1933. VLA-PUT-ROUNDDISTANCE
  1934. VLA-PUT-ROWHEIGHT
  1935. VLA-PUT-ROWS
  1936. VLA-PUT-ROWSPACING
  1937. VLA-PUT-SAVEASTYPE
  1938. VLA-PUT-SAVEPREVIEWTHUMBNAIL
  1939. VLA-PUT-SCALE
  1940. VLA-PUT-SCALEFACTOR
  1941. VLA-PUT-SCALEHEIGHT
  1942. VLA-PUT-SCALELINEWEIGHTS
  1943. VLA-PUT-SCALEWIDTH
  1944. VLA-PUT-SCMCOMMANDMODE
  1945. VLA-PUT-SCMDEFAULTMODE
  1946. VLA-PUT-SCMEDITMODE
  1947. VLA-PUT-SCMTIMEMODE
  1948. VLA-PUT-SCMTIMEVALUE
  1949. VLA-PUT-SECONDPOINT
  1950. VLA-PUT-SECONDSEGMENTANGLECONSTRAINT
  1951. VLA-PUT-SEGMENTPERPOLYLINE
  1952. VLA-PUT-SERIALNUMBER
  1953. VLA-PUT-SHADEPLOT
  1954. VLA-PUT-SHEETVIEW
  1955. VLA-PUT-SHORTCUTMENUDISPLAY
  1956. VLA-PUT-SHOWHISTORY
  1957. VLA-PUT-SHOWPLOTSTYLES
  1958. VLA-PUT-SHOWPROXYDIALOGBOX
  1959. VLA-PUT-SHOWRASTERIMAGE
  1960. VLA-PUT-SHOWROTATION
  1961. VLA-PUT-SHOWWARNINGMESSAGES
  1962. VLA-PUT-SINGLEDOCUMENTMODE
  1963. VLA-PUT-SMOOTHNESS
  1964. VLA-PUT-SNAPBASEPOINT
  1965. VLA-PUT-SNAPON
  1966. VLA-PUT-SNAPROTATIONANGLE
  1967. VLA-PUT-SOLIDFILL
  1968. VLA-PUT-SOURCEOBJECTS
  1969. VLA-PUT-STANDARDSCALE
  1970. VLA-PUT-STANDARDSCALE2
  1971. VLA-PUT-STARTANGLE
  1972. VLA-PUT-STARTDRAFTANGLE
  1973. VLA-PUT-STARTDRAFTMAGNITUDE
  1974. VLA-PUT-STARTPARAMETER
  1975. VLA-PUT-STARTPOINT
  1976. VLA-PUT-STARTTANGENT
  1977. VLA-PUT-STATE
  1978. VLA-PUT-STORESQLINDEX
  1979. VLA-PUT-STYLENAME
  1980. VLA-PUT-STYLESHEET
  1981. VLA-PUT-SUBJECT
  1982. VLA-PUT-SUBUNITSFACTOR
  1983. VLA-PUT-SUBUNITSSUFFIX
  1984. VLA-PUT-SUPPORTPATH
  1985. VLA-PUT-SUPPRESSLEADINGZEROS
  1986. VLA-PUT-SUPPRESSTRAILINGZEROS
  1987. VLA-PUT-SUPPRESSZEROFEET
  1988. VLA-PUT-SUPPRESSZEROINCHES
  1989. VLA-PUT-SURFACENORMALS
  1990. VLA-PUT-SYMBOLPOSITION
  1991. VLA-PUT-TABLEBREAKFLOWDIRECTION
  1992. VLA-PUT-TABLEBREAKHEIGHT
  1993. VLA-PUT-TABLESREADONLY
  1994. VLA-PUT-TABORDER
  1995. VLA-PUT-TAGSTRING
  1996. VLA-PUT-TAPERANGLE
  1997. VLA-PUT-TARGET
  1998. VLA-PUT-TEMPFILEEXTENSION
  1999. VLA-PUT-TEMPFILEPATH
  2000. VLA-PUT-TEMPLATEDWGPATH
  2001. VLA-PUT-TEMPLATEID
  2002. VLA-PUT-TEMPXREFPATH
  2003. VLA-PUT-TEXTALIGNMENTPOINT
  2004. VLA-PUT-TEXTALIGNMENTTYPE
  2005. VLA-PUT-TEXTANGLETYPE
  2006. VLA-PUT-TEXTATTACHMENTDIRECTION
  2007. VLA-PUT-TEXTBACKGROUNDFILL
  2008. VLA-PUT-TEXTBOTTOMATTACHMENTTYPE
  2009. VLA-PUT-TEXTCOLOR
  2010. VLA-PUT-TEXTDIRECTION
  2011. VLA-PUT-TEXTEDITOR
  2012. VLA-PUT-TEXTFILL
  2013. VLA-PUT-TEXTFILLCOLOR
  2014. VLA-PUT-TEXTFONT
  2015. VLA-PUT-TEXTFONTSIZE
  2016. VLA-PUT-TEXTFONTSTYLE
  2017. VLA-PUT-TEXTFRAMEDISPLAY
  2018. VLA-PUT-TEXTGAP
  2019. VLA-PUT-TEXTGENERATIONFLAG
  2020. VLA-PUT-TEXTHEIGHT
  2021. VLA-PUT-TEXTINSIDE
  2022. VLA-PUT-TEXTINSIDEALIGN
  2023. VLA-PUT-TEXTJUSTIFY
  2024. VLA-PUT-TEXTLEFTATTACHMENTTYPE
  2025. VLA-PUT-TEXTLINESPACINGDISTANCE
  2026. VLA-PUT-TEXTLINESPACINGFACTOR
  2027. VLA-PUT-TEXTLINESPACINGSTYLE
  2028. VLA-PUT-TEXTMOVEMENT
  2029. VLA-PUT-TEXTOUTSIDEALIGN
  2030. VLA-PUT-TEXTOVERRIDE
  2031. VLA-PUT-TEXTPOSITION
  2032. VLA-PUT-TEXTPRECISION
  2033. VLA-PUT-TEXTPREFIX
  2034. VLA-PUT-TEXTRIGHTATTACHMENTTYPE
  2035. VLA-PUT-TEXTROTATION
  2036. VLA-PUT-TEXTSTRING
  2037. VLA-PUT-TEXTSTYLE
  2038. VLA-PUT-TEXTSTYLENAME
  2039. VLA-PUT-TEXTSUFFIX
  2040. VLA-PUT-TEXTTOPATTACHMENTTYPE
  2041. VLA-PUT-TEXTUREMAPPATH
  2042. VLA-PUT-TEXTWIDTH
  2043. VLA-PUT-TEXTWINBACKGRNDCOLOR
  2044. VLA-PUT-TEXTWINTEXTCOLOR
  2045. VLA-PUT-THICKNESS
  2046. VLA-PUT-TIMESERVER
  2047. VLA-PUT-TITLE
  2048. VLA-PUT-TITLESUPPRESSED
  2049. VLA-PUT-TOLERANCEDISPLAY
  2050. VLA-PUT-TOLERANCEHEIGHTSCALE
  2051. VLA-PUT-TOLERANCEJUSTIFICATION
  2052. VLA-PUT-TOLERANCELOWERLIMIT
  2053. VLA-PUT-TOLERANCEPRECISION
  2054. VLA-PUT-TOLERANCESUPPRESSLEADINGZEROS
  2055. VLA-PUT-TOLERANCESUPPRESSTRAILINGZEROS
  2056. VLA-PUT-TOLERANCESUPPRESSZEROFEET
  2057. VLA-PUT-TOLERANCESUPPRESSZEROINCHES
  2058. VLA-PUT-TOLERANCEUPPERLIMIT
  2059. VLA-PUT-TOOLPALETTEPATH
  2060. VLA-PUT-TOP
  2061. VLA-PUT-TOPHEIGHT
  2062. VLA-PUT-TOPRADIUS
  2063. VLA-PUT-TRANSLATEIDS
  2064. VLA-PUT-TRANSPARENCY
  2065. VLA-PUT-TRUECOLOR
  2066. VLA-PUT-TRUECOLORIMAGES
  2067. VLA-PUT-TURNHEIGHT
  2068. VLA-PUT-TURNS
  2069. VLA-PUT-TWIST
  2070. VLA-PUT-TWISTANGLE
  2071. VLA-PUT-TYPE
  2072. VLA-PUT-UCSICONATORIGIN
  2073. VLA-PUT-UCSICONON
  2074. VLA-PUT-UCSPERVIEWPORT
  2075. VLA-PUT-UISOLINEDENSITY
  2076. VLA-PUT-UNDERLAYLAYEROVERRIDEAPPLIED
  2077. VLA-PUT-UNDERLAYNAME
  2078. VLA-PUT-UNDERLAYVISIBILITY
  2079. VLA-PUT-UNITS
  2080. VLA-PUT-UNITSFORMAT
  2081. VLA-PUT-UPSIDEDOWN
  2082. VLA-PUT-URL
  2083. VLA-PUT-URLDESCRIPTION
  2084. VLA-PUT-URLNAMEDLOCATION
  2085. VLA-PUT-USELASTPLOTSETTINGS
  2086. VLA-PUT-USESTANDARDSCALE
  2087. VLA-PUT-VALUE
  2088. VLA-PUT-VERIFY
  2089. VLA-PUT-VERTCELLMARGIN
  2090. VLA-PUT-VERTICALDIRECTION
  2091. VLA-PUT-VERTICALTEXTPOSITION
  2092. VLA-PUT-VERTICES
  2093. VLA-PUT-VIEWINGDIRECTION
  2094. VLA-PUT-VIEWPORTDEFAULT
  2095. VLA-PUT-VIEWPORTON
  2096. VLA-PUT-VIEWTOPLOT
  2097. VLA-PUT-VISIBILITYEDGE1
  2098. VLA-PUT-VISIBILITYEDGE2
  2099. VLA-PUT-VISIBILITYEDGE3
  2100. VLA-PUT-VISIBILITYEDGE4
  2101. VLA-PUT-VISIBLE
  2102. VLA-PUT-VISOLINEDENSITY
  2103. VLA-PUT-VISUALSTYLE
  2104. VLA-PUT-WEIGHTS
  2105. VLA-PUT-WIDTH
  2106. VLA-PUT-WINDOWLEFT
  2107. VLA-PUT-WINDOWSTATE
  2108. VLA-PUT-WINDOWTOP
  2109. VLA-PUT-WORKSPACEPATH
  2110. VLA-PUT-XEFFECTIVESCALEFACTOR
  2111. VLA-PUT-XREFDEMANDLOAD
  2112. VLA-PUT-XREFEDIT
  2113. VLA-PUT-XREFFADEINTENSITY
  2114. VLA-PUT-XREFLAYERVISIBILITY
  2115. VLA-PUT-XSCALEFACTOR
  2116. VLA-PUT-XVECTOR
  2117. VLA-PUT-YEFFECTIVESCALEFACTOR
  2118. VLA-PUT-YSCALEFACTOR
  2119. VLA-PUT-YVECTOR
  2120. VLA-PUT-ZEFFECTIVESCALEFACTOR
  2121. VLA-PUT-ZSCALEFACTOR
  2122. VLA-PUTREMOTEFILE
  2123. VLA-QUIT
  2124. VLA-REALTOSTRING
  2125. VLA-RECOMPUTETABLEBLOCK
  2126. VLA-REFRESHPLOTDEVICEINFO
  2127. VLA-REGEN
  2128. VLA-RELOAD
  2129. VLA-REMOVE
  2130. VLA-REMOVEALLOVERRIDES
  2131. VLA-REMOVECUSTOMBYINDEX
  2132. VLA-REMOVECUSTOMBYKEY
  2133. VLA-REMOVEENTRY
  2134. VLA-REMOVEFROMMENUBAR
  2135. VLA-REMOVEITEMS
  2136. VLA-REMOVELEADER
  2137. VLA-REMOVELEADERLINE
  2138. VLA-REMOVEMENUFROMMENUBAR
  2139. VLA-REMOVEVERTEX
  2140. VLA-RENAME
  2141. VLA-RENAMECELLSTYLE
  2142. VLA-RENAMEPROFILE
  2143. VLA-REPLACE
  2144. VLA-RESELECTSUBREGION
  2145. VLA-RESETBLOCK
  2146. VLA-RESETCELLVALUE
  2147. VLA-RESETPROFILE
  2148. VLA-RESTORE
  2149. VLA-REVERSE
  2150. VLA-ROTATE
  2151. VLA-ROTATE3D
  2152. VLA-RUNMACRO
  2153. VLA-SAVE
  2154. VLA-SAVEAS
  2155. VLA-SCALEENTITY
  2156. VLA-SECTIONSOLID
  2157. VLA-SELECT
  2158. VLA-SELECTATPOINT
  2159. VLA-SELECTBYPOLYGON
  2160. VLA-SELECTONSCREEN
  2161. VLA-SELECTSUBREGION
  2162. VLA-SENDCOMMAND
  2163. VLA-SENDMODELESSOPERATIONENDED
  2164. VLA-SENDMODELESSOPERATIONSTART
  2165. VLA-SETALIGNMENT
  2166. VLA-SETALIGNMENT2
  2167. VLA-SETAUTOSCALE
  2168. VLA-SETAUTOSCALE2
  2169. VLA-SETBACKGROUNDCOLOR
  2170. VLA-SETBACKGROUNDCOLOR2
  2171. VLA-SETBACKGROUNDCOLORNONE
  2172. VLA-SETBITMAPS
  2173. VLA-SETBLOCKATTRIBUTEVALUE
  2174. VLA-SETBLOCKATTRIBUTEVALUE2
  2175. VLA-SETBLOCKROTATION
  2176. VLA-SETBLOCKSCALE
  2177. VLA-SETBLOCKTABLERECORDID
  2178. VLA-SETBLOCKTABLERECORDID2
  2179. VLA-SETBREAKHEIGHT
  2180. VLA-SETBULGE
  2181. VLA-SETCELLALIGNMENT
  2182. VLA-SETCELLBACKGROUNDCOLOR
  2183. VLA-SETCELLBACKGROUNDCOLORNONE
  2184. VLA-SETCELLCLASS
  2185. VLA-SETCELLCONTENTCOLOR
  2186. VLA-SETCELLDATATYPE
  2187. VLA-SETCELLFORMAT
  2188. VLA-SETCELLGRIDCOLOR
  2189. VLA-SETCELLGRIDLINEWEIGHT
  2190. VLA-SETCELLGRIDVISIBILITY
  2191. VLA-SETCELLSTATE
  2192. VLA-SETCELLSTYLE
  2193. VLA-SETCELLTEXTHEIGHT
  2194. VLA-SETCELLTEXTSTYLE
  2195. VLA-SETCELLTYPE
  2196. VLA-SETCELLVALUE
  2197. VLA-SETCELLVALUEFROMTEXT
  2198. VLA-SETCOLOR
  2199. VLA-SETCOLOR2
  2200. VLA-SETCOLORBOOKCOLOR
  2201. VLA-SETCOLUMNNAME
  2202. VLA-SETCOLUMNWIDTH
  2203. VLA-SETCONTENTCOLOR
  2204. VLA-SETCONTENTCOLOR2
  2205. VLA-SETCONTENTLAYOUT
  2206. VLA-SETCONTROLPOINT
  2207. VLA-SETCUSTOMBYINDEX
  2208. VLA-SETCUSTOMBYKEY
  2209. VLA-SETCUSTOMDATA
  2210. VLA-SETCUSTOMSCALE
  2211. VLA-SETDATABASE
  2212. VLA-SETDATAFORMAT
  2213. VLA-SETDATATYPE
  2214. VLA-SETDATATYPE2
  2215. VLA-SETDOGLEGDIRECTION
  2216. VLA-SETFIELDID
  2217. VLA-SETFIELDID2
  2218. VLA-SETFITPOINT
  2219. VLA-SETFONT
  2220. VLA-SETFORMAT
  2221. VLA-SETFORMAT2
  2222. VLA-SETFORMULA
  2223. VLA-SETGRIDCOLOR
  2224. VLA-SETGRIDCOLOR2
  2225. VLA-SETGRIDDOUBLELINESPACING
  2226. VLA-SETGRIDLINESTYLE
  2227. VLA-SETGRIDLINETYPE
  2228. VLA-SETGRIDLINEWEIGHT
  2229. VLA-SETGRIDLINEWEIGHT2
  2230. VLA-SETGRIDSPACING
  2231. VLA-SETGRIDVISIBILITY
  2232. VLA-SETGRIDVISIBILITY2
  2233. VLA-SETINVISIBLEEDGE
  2234. VLA-SETLAYOUTSTOPLOT
  2235. VLA-SETLEADERLINEVERTICES
  2236. VLA-SETMARGIN
  2237. VLA-SETNAMES
  2238. VLA-SETOVERRIDE
  2239. VLA-SETPATTERN
  2240. VLA-SETPROJECTFILEPATH
  2241. VLA-SETRELATIVEDRAWORDER
  2242. VLA-SETRGB
  2243. VLA-SETROTATION
  2244. VLA-SETROWHEIGHT
  2245. VLA-SETSCALE
  2246. VLA-SETSNAPSPACING
  2247. VLA-SETSUBSELECTION
  2248. VLA-SETTEMPLATEID
  2249. VLA-SETTEXT
  2250. VLA-SETTEXTHEIGHT
  2251. VLA-SETTEXTHEIGHT2
  2252. VLA-SETTEXTROTATION
  2253. VLA-SETTEXTSTRING
  2254. VLA-SETTEXTSTYLE
  2255. VLA-SETTEXTSTYLE2
  2256. VLA-SETTEXTSTYLEID
  2257. VLA-SETTOOLTIP
  2258. VLA-SETVALUE
  2259. VLA-SETVALUEFROMTEXT
  2260. VLA-SETVARIABLE
  2261. VLA-SETVIEW
  2262. VLA-SETWEIGHT
  2263. VLA-SETWIDTH
  2264. VLA-SETWINDOWTOPLOT
  2265. VLA-SETXDATA
  2266. VLA-SETXRECORDDATA
  2267. VLA-SLICESOLID
  2268. VLA-SPLIT
  2269. VLA-STARTBATCHMODE
  2270. VLA-STARTUNDOMARK
  2271. VLA-SWAPORDER
  2272. VLA-SYNCMODELVIEW
  2273. VLA-TRANSFORMBY
  2274. VLA-TRANSLATECOORDINATES
  2275. VLA-UNLOAD
  2276. VLA-UNLOADARX
  2277. VLA-UNLOADDVB
  2278. VLA-UNMERGECELLS
  2279. VLA-UPDATE
  2280. VLA-UPDATEENTRY
  2281. VLA-UPDATEMTEXTATTRIBUTE
  2282. VLA-WBLOCK
  2283. VLA-ZOOMALL
  2284. VLA-ZOOMCENTER
  2285. VLA-ZOOMEXTENTS
  2286. VLA-ZOOMPICKWINDOW
  2287. VLA-ZOOMPREVIOUS
  2288. VLA-ZOOMSCALED
  2289. VLA-ZOOMWINDOW
  2290. VLARTS-INIT
  2291. VLAX-3D-POINT
  2292. VLAX-ADD-CMD
  2293. VLAX-CREATE-OBJECT
  2294. VLAX-CURVE-GETAREA
  2295. VLAX-CURVE-GETCLOSESTPOINTTO
  2296. VLAX-CURVE-GETCLOSESTPOINTTOPROJECTION
  2297. VLAX-CURVE-GETDISTATPARAM
  2298. VLAX-CURVE-GETDISTATPOINT
  2299. VLAX-CURVE-GETENDPARAM
  2300. VLAX-CURVE-GETENDPOINT
  2301. VLAX-CURVE-GETFIRSTDERIV
  2302. VLAX-CURVE-GETPARAMATDIST
  2303. VLAX-CURVE-GETPARAMATPOINT
  2304. VLAX-CURVE-GETPOINTATDIST
  2305. VLAX-CURVE-GETPOINTATPARAM
  2306. VLAX-CURVE-GETSECONDDERIV
  2307. VLAX-CURVE-GETSTARTPARAM
  2308. VLAX-CURVE-GETSTARTPOINT
  2309. VLAX-CURVE-ISCLOSED
  2310. VLAX-CURVE-ISPERIODIC
  2311. VLAX-CURVE-ISPLANAR
  2312. VLAX-DUMP-OBJECT
  2313. VLAX-ENAME->VLA-OBJECT
  2314. VLAX-ERASED-P
  2315. VLAX-FOR
  2316. VLAX-GET
  2317. VLAX-GET-ACAD-OBJECT
  2318. VLAX-GET-OBJECT
  2319. VLAX-GET-OR-CREATE-OBJECT
  2320. VLAX-GET-PROPERTY
  2321. VLAX-IMPORT-TYPE-LIBRARY
  2322. VLAX-INVOKE
  2323. VLAX-INVOKE-METHOD
  2324. VLAX-LDATA-DELETE
  2325. VLAX-LDATA-GET
  2326. VLAX-LDATA-LIST
  2327. VLAX-LDATA-PUT
  2328. VLAX-LDATA-TEST
  2329. VLAX-MAKE-SAFEARRAY
  2330. VLAX-MAKE-VARIANT
  2331. VLAX-MAP-COLLECTION
  2332. VLAX-METHOD-APPLICABLE-P
  2333. VLAX-OBJECT-RELEASED-P
  2334. VLAX-PRODUCT-KEY
  2335. VLAX-PROPERTY-AVAILABLE-P
  2336. VLAX-PUT
  2337. VLAX-PUT-PROPERTY
  2338. VLAX-QUEUEEXPR
  2339. VLAX-READ-ENABLED-P
  2340. VLAX-REG-APP
  2341. VLAX-RELEASE-OBJECT
  2342. VLAX-REMOVE-CMD
  2343. VLAX-SAFEARRAY->LIST
  2344. VLAX-SAFEARRAY-FILL
  2345. VLAX-SAFEARRAY-GET-DIM
  2346. VLAX-SAFEARRAY-GET-ELEMENT
  2347. VLAX-SAFEARRAY-GET-L-BOUND
  2348. VLAX-SAFEARRAY-GET-U-BOUND
  2349. VLAX-SAFEARRAY-PUT-ELEMENT
  2350. VLAX-SAFEARRAY-TYPE
  2351. VLAX-TMATRIX
  2352. VLAX-TYPEINFO-AVAILABLE-P
  2353. VLAX-VARIANT-CHANGE-TYPE
  2354. VLAX-VARIANT-TYPE
  2355. VLAX-VARIANT-VALUE
  2356. VLAX-VBABORT
  2357. VLAX-VBABORTRETRYIGNORE
  2358. VLAX-VBAPPLICATIONMODAL
  2359. VLAX-VBARCHIVE
  2360. VLAX-VBARRAY
  2361. VLAX-VBBOOLEAN
  2362. VLAX-VBCANCEL
  2363. VLAX-VBCRITICAL
  2364. VLAX-VBCURRENCY
  2365. VLAX-VBDATAOBJECT
  2366. VLAX-VBDATE
  2367. VLAX-VBDECIMAL
  2368. VLAX-VBDEFAULTBUTTON1
  2369. VLAX-VBDEFAULTBUTTON2
  2370. VLAX-VBDEFAULTBUTTON3
  2371. VLAX-VBDIRECTORY
  2372. VLAX-VBDOUBLE
  2373. VLAX-VBEMPTY
  2374. VLAX-VBERROR
  2375. VLAX-VBEXCLAMATION
  2376. VLAX-VBHIDDEN
  2377. VLAX-VBHIRAGANA
  2378. VLAX-VBIGNORE
  2379. VLAX-VBINFORMATION
  2380. VLAX-VBINTEGER
  2381. VLAX-VBKATAKANA
  2382. VLAX-VBLONG
  2383. VLAX-VBLOWERCASE
  2384. VLAX-VBNARROW
  2385. VLAX-VBNO
  2386. VLAX-VBNORMAL
  2387. VLAX-VBNULL
  2388. VLAX-VBOBJECT
  2389. VLAX-VBOK
  2390. VLAX-VBOKCANCEL
  2391. VLAX-VBOKONLY
  2392. VLAX-VBPROPERCASE
  2393. VLAX-VBQUESTION
  2394. VLAX-VBREADONLY
  2395. VLAX-VBRETRY
  2396. VLAX-VBRETRYCANCEL
  2397. VLAX-VBSINGLE
  2398. VLAX-VBSTRING
  2399. VLAX-VBSYSTEM
  2400. VLAX-VBSYSTEMMODAL
  2401. VLAX-VBUPPERCASE
  2402. VLAX-VBVARIANT
  2403. VLAX-VBVOLUME
  2404. VLAX-VBWIDE
  2405. VLAX-VBYES
  2406. VLAX-VBYESNO
  2407. VLAX-VBYESNOCANCEL
  2408. VLAX-VLA-OBJECT->ENAME
  2409. VLAX-WRITE-ENABLED-P
  2410. VLISP-DCLRES-LIST
  2411. VLISP-DCLRES-LOAD-DIALOG
  2412. VLISP-EXPORT-SYMBOL
  2413. VLISP-FASRES-LIST
  2414. VLISP-FASRES-LOAD
  2415. VLISP-IMPORT-EXSUBRS
  2416. VLISP-IMPORT-SYMBOL
  2417. VLISP-INIRES-LIST
  2418. VLR-ACDB-REACTOR
  2419. VLR-ADD
  2420. VLR-ADDED-P
  2421. VLR-BEEP-REACTION
  2422. VLR-COMMAND-REACTOR
  2423. VLR-CURRENT-REACTION-NAME
  2424. VLR-DATA
  2425. VLR-DATA-SET
  2426. VLR-DEEPCLONE-REACTOR
  2427. VLR-DOCMANAGER-REACTOR
  2428. VLR-DOCUMENT
  2429. VLR-DWG-REACTOR
  2430. VLR-DXF-REACTOR
  2431. VLR-EDITOR-REACTOR
  2432. VLR-INSERT-REACTOR
  2433. VLR-LINKER-REACTOR
  2434. VLR-LISP-REACTOR
  2435. VLR-MISCELLANEOUS-REACTOR
  2436. VLR-MOUSE-REACTOR
  2437. VLR-NOTIFICATION
  2438. VLR-OBJECT-REACTOR
  2439. VLR-OWNER-ADD
  2440. VLR-OWNER-REMOVE
  2441. VLR-OWNERS
  2442. VLR-PERS
  2443. VLR-PERS-ACTIVATE
  2444. VLR-PERS-DICTNAME
  2445. VLR-PERS-LIST
  2446. VLR-PERS-P
  2447. VLR-PERS-RELEASE
  2448. VLR-REACTION-NAMES
  2449. VLR-REACTION-SET
  2450. VLR-REACTIONS
  2451. VLR-REACTOR.GETDICTKEY
  2452. VLR-REACTORS
  2453. VLR-REMOVE
  2454. VLR-REMOVE-ALL
  2455. VLR-SET-NOTIFICATION
  2456. VLR-SYSVAR-REACTOR
  2457. VLR-TOOLBAR-REACTOR
  2458. VLR-TRACE-REACTION
  2459. VLR-TYPE
  2460. VLR-TYPES
  2461. VLR-UNDO-REACTOR
  2462. VLR-WBLOCK-REACTOR
  2463. VLR-WINDOW-REACTOR
  2464. VLR-XREF-REACTOR
  2465. vports
  2466. wcmatch
  2467. while
  2468. write-char
  2469. write-line
  2470. xdroom
  2471. xdsize
  2472. xload
  2473. xstrcase
  2474. xunload
  2475. zerop
  2476. comA
  2477. xx-setv
  2478. *x-r*
  2479. *error*
  2480. *x-er*
  2481. *syl*
  2482. comB
  2483. xx-princA
  2484. xx-princB
  2485. xx-princ
  2486. xx-VlaPu
  2487. xx-StartUndo
  2488. xx-unsetvars
  2489. xx-EndUndo
  2490. xx-c-ssget
  2491. pi-s
  2492. pi-x
  2493. pi-z
  2494. pi-y
  2495. pi-ys
  2496. pi-zs
  2497. pi-zx
  2498. pi-yx
  2499. xx-new-lay
  2500. xx-new-txt
  2501. xx-new-lts
  2502. xx-dist
  2503. xx-int
  2504. xx-str
  2505. xx-real
  2506. xx-angle
  2507. xx-kword
  2508. xx-point
  2509. xx-acad
  2510. xx-doc
  2511. xx-docs
  2512. xx-menus
  2513. xx-menubar
  2514. xx-cset
  2515. xx-ms
  2516. xx-blks
  2517. xx-dics
  2518. xx-dims
  2519. xx-grps
  2520. xx-lays
  2521. xx-luts
  2522. xx-lts
  2523. xx-pots
  2524. xx-regs
  2525. xx-acSSsets
  2526. xx-txts
  2527. xx-ucss
  2528. xx-vs
  2529. xx-ps
  2530. xx-pces
  2531. xx-uy
  2532. xx-ax-EnLst
  2533. xx-ax-NameLst
  2534. xx-ax-lisp2value
  2535. xx-ax-list2VlaAy
  2536. xx-ax-add-region
  2537. xx-ax-add-text
  2538. xx-ax-CopyProp
  2539. xx-ax-del-obj
  2540. xx-ax-pu-lay
  2541. xx-ax-load-Ltypes
  2542. xx-ax-load-txtsty
  2543. xx-ax-Style
  2544. xx-ax-SendKeys
  2545. xx-ax-Pu
  2546. xx-ax-pu-x
  2547. xx-ax-save-x
  2548. xx-ax-SaveAs
  2549. xx-ax-Close-NotDoc
  2550. xx-ar-c
  2551. xx-ar-rec
  2552. xx-break
  2553. xx-boy
  2554. xx-cha
  2555. xx-change
  2556. xx-co
  2557. xx-co-m
  2558. xx-co-ro
  2559. xx-e
  2560. xx-export
  2561. xx-f
  2562. xx-grdraw
  2563. xx-grdraw-p
  2564. xx-hatch-p
  2565. xx-hatch-ss
  2566. xx-m
  2567. xx-mi
  2568. xx-mi-e
  2569. xx-o
  2570. xx-o-e
  2571. xx-pedit
  2572. xx-pickbox
  2573. xx-re
  2574. xx-rec-text
  2575. xx-redraw
  2576. xx-ro
  2577. xx-region2PL
  2578. xx-sc
  2579. xx-sssetfirst
  2580. xx-Text
  2581. xx-x
  2582. xx-zoom
  2583. get-utime
  2584. xx-mk-arc
  2585. xx-ar-rec
  2586. xx-break
  2587. xx-boy
  2588. xx-cha
  2589. xx-change
  2590. xx-co
  2591. xx-co-m
  2592. xx-co-ro
  2593. xx-e
  2594. xx-export
  2595. xx-f
  2596. xx-grdraw
  2597. xx-grdraw-p
  2598. xx-hatch-p
  2599. xx-hatch-ss
  2600. xx-m
  2601. xx-mi
  2602. xx-o
  2603. xx-o-e
  2604. xx-pedit
  2605. xx-pickbox
  2606. xx-re
  2607. xx-rec-text
  2608. xx-redraw
  2609. xx-ro
  2610. xx-region2PL
  2611. xx-sc
  2612. xx-sssetfirst
  2613. xx-Text
  2614. xx-x
  2615. xx-zoom
  2616. get-utime
  2617. xx-mk-arc
  2618. xx-mk-block
  2619. xx-mk-block-insert
  2620. xx-mk-block-insert-move
  2621. xx-mk-center
  2622. xx-mk-circle
  2623. xx-mk-dimD
  2624. xx-mk-dimDal
  2625. xx-mk-dimDliH
  2626. xx-mk-dimDliV
  2627. xx-mk-dimR
  2628. xx-mk-dimstyle
  2629. xx-mk-Donut
  2630. xx-mk-hatch
  2631. xx-mk-insert
  2632. xx-mk-layer
  2633. xx-mk-line
  2634. xx-mk-line-PPts
  2635. xx-mk-line-pts
  2636. xx-mk-line-PtsP
  2637. xx-mk-line-PtsPts
  2638. xx-mk-ltype
  2639. xx-mk-mtext
  2640. xx-mk-pline2
  2641. xx-mk-pline-pts
  2642. xx-mk-point
  2643. xx-mk-Qleader
  2644. xx-mk-Ray
  2645. xx-mk-rectang
  2646. xx-mk-Solid
  2647. xx-mk-spline
  2648. xx-mk-text-9pt
  2649. xx-mk-text-9pt-pts
  2650. xx-mk-text
  2651. xx-mk-textstyle
  2652. xx-mk-wm-block-insert
  2653. xx-mk-wm-block-insert-move
  2654. xx-mk-xline
  2655. xx-mk-xline-ang
  2656. xx-9pt
  2657. xx-9pt1
  2658. xx-entsel
  2659. xx-get-dxf
  2660. xx-put-dxf
  2661. xx-entlast2
  2662. xx-get-color
  2663. xx-get-linetype
  2664. xx-etype
  2665. xx-curve-Len
  2666. xx-Curve-Mid
  2667. xx-curve-get-3pt
  2668. xx-curve12-inters
  2669. xx-Curve-div
  2670. xx-curve-Div-bk
  2671. xx-curve-lst-div
  2672. xx-Curve-pts-sort
  2673. xx-curve-PtSdAng
  2674. xx-curve-PtFtAng
  2675. xx-curve-PrmSdAng
  2676. xx-curve-PrmFtAng
  2677. xx-Curve-PtToParam
  2678. xx-Curve-ParamTopt
  2679. xx-Curve-pd-PtOnCurve
  2680. xx-curve-pd-Closed
  2681. xx-curve-getperpline
  2682. xx-L-put-s
  2683. xx-L-put-x
  2684. xx-L-put-z
  2685. xx-L-put-y
  2686. xx-l-break-ss
  2687. xx-L-ang-br
  2688. xx-L-Offset
  2689. xx-L-pd-vh
  2690. xx-L-X-ang
  2691. xx-pl-get-pts
  2692. xx-pl-get-PdPts
  2693. xx-pl-pp-pts
  2694. xx-pl-p-reverse
  2695. xx-pl-19-pline
  2696. xx-pl-p-remove
  2697. xx-pl-put-pt
  2698. xx-pl-cp
  2699. xx-pl-Cen
  2700. xx-pl-num
  2701. xx-pl-Area
  2702. xx-pl-PtsArea
  2703. xx-pl-pts-len
  2704. xx-pl-get-Infomation
  2705. xx-pl-pd-3dPL
  2706. xx-pl-pd-ccw
  2707. xx-pl-pd-xyz
  2708. xx-pl-ArcCo
  2709. xx-pl-get-ArcIn
  2710. xx-pl-getCenter
  2711. xx-pl-pd-ArcIn
  2712. xx-pl-PickArc
  2713. xx-pl-polytoarc
  2714. xx-pl-Inters
  2715. xx-pl-pd-Closed
  2716. xx-pl-pd-check
  2717. xx-pl-put-Closed
  2718. xx-pl-PickToStart
  2719. xx-pl-PickSegStratPt
  2720. xx-pl-PickSegIndex
  2721. xx-pl-PickSegEndPt
  2722. xx-pl-PickClosePt
  2723. xx-pl-GetSegStratPt
  2724. xx-pl-GetSegEndPt
  2725. xx-pl-GetSegAt
  2726. xx-mt-Box
  2727. xx-mt-Box1
  2728. xx-tmt-get-box
  2729. xx-mt-TsPutTs
  2730. xx-mt-IsBigFont
  2731. xx-mt-change
  2732. xx-d-sj
  2733. xx-d-qhz
  2734. xx-d-sjqhz
  2735. xx-d-txt-sc
  2736. xx-d-txt-zj
  2737. xx-d-zjwk
  2738. xx-d-txt-data
  2739. xx-tk-9pt
  2740. xx-tk-NameLst
  2741. xx-tk-put
  2742. xx-tk-bks
  2743. xx-tk-put-name
  2744. xx-tk-put-s1-name
  2745. xx-tk-Wm2Insert
  2746. xx-tk-pd-InBk
  2747. xx-tk-del-name-X
  2748. xx-pl3-3b3Ang
  2749. xx-pl3-3P-9P-C
  2750. xx-pl3-Area3b
  2751. xx-pl3-Area3P-2
  2752. xx-pl3-Area3P
  2753. xx-pl3-CimCo
  2754. xx-pl3-co
  2755. xx-pl3-InCo
  2756. xx-pl3-OrthoCo
  2757. xx-pl3-InfoBy3Sides
  2758. xx-pl3-pd-mk
  2759. xx-pl3-TCS2WCS
  2760. xx-arc-2-pl
  2761. xx-arc-3p2arc
  2762. xx-arc-get-3pt
  2763. xx-el-GetParam
  2764. xx-el-Update
  2765. xx-lst-23div
  2766. xx-lst-append-x
  2767. xx-lst-append-xx
  2768. xx-lst-AtomCons
  2769. xx-lst-AtomsCons
  2770. xx-lst-AtomTyp
  2771. xx-lst-cons-11
  2772. xx-lst-cons-11-append
  2773. xx-lst-cons-123
  2774. xx-lst-cons-1223
  2775. xx-lst-cons-123234
  2776. xx-lst-cons-DF
  2777. xx-Lst-cons-lst12
  2778. xx-lst-div
  2779. xx-lst-LengthS
  2780. xx-lst-TongJi
  2781. xx-lst-TongJi-atom
  2782. xx-lst-TypTyp
  2783. xx-lst-Compress
  2784. xx-lst-uncompress
  2785. xx-dxf
  2786. xx-lst-massoc
  2787. xx-lst-cdr-assoc
  2788. xx-lst-cdr-assocfuzz
  2789. xx-lst-EnLastLst
  2790. xx-lst-BingJi
  2791. xx-lst-JianJi
  2792. xx-lst-JiaoJi
  2793. xx-lst-MaxMin-num
  2794. xx-lst-position
  2795. xx-lst-TypLst
  2796. xx-lst-mapcdr
  2797. xx-lst-NewIntLst
  2798. xx-lst-Even
  2799. xx-lst-ODD
  2800. xx-lst-Make
  2801. xx-lst-1To9
  2802. xx-lst-9To1
  2803. xx-Lst-atom-RetNum
  2804. xx-lst-del-atom-lst
  2805. xx-lst-del-last
  2806. xx-lst-del-position
  2807. xx-lst-del-RetAtom
  2808. xx-lst-del-x-RetAtom
  2809. xx-lst-get-i-lst
  2810. xx-lst-RetAtomLst
  2811. xx-lst-Ret-cdr
  2812. xx-lst-Subi-1
  2813. xx-lst-Subi-x
  2814. xx-lst-2str
  2815. xx-lst-EnLst-2-ss
  2816. xx-lst-EntLst-2-ss
  2817. xx-lst-NumStr2Lst
  2818. xx-lst-StrLst-Tye2Str
  2819. xx-lst-pd-AtomInLst
  2820. xx-lst-pd-consp
  2821. xx-lst-pd-consp-tnil
  2822. xx-p-2pMid
  2823. xx-p-2pMidDN
  2824. xx-p-2pMidUP
  2825. xx-p-list2
  2826. xx-p-2ptXYDist
  2827. xx-p-2p-Offset
  2828. xx-p-EqXYPts-sort
  2829. xx-p-pts-P1P9
  2830. xx-p-pts-P11P99
  2831. xx-p-pts-P11SP99S
  2832. xx-p-PtsPMax
  2833. xx-p-PtsPMin
  2834. xx-p-PtsPMinS
  2835. xx-p-3PAng
  2836. xx-p-CenPt
  2837. xx-p-PAngArea
  2838. xx-p-PtsBox
  2839. xx-p-Mi-2p
  2840. xx-p-Mi-3D-2p
  2841. xx-p-Mi-PAng
  2842. xx-p-offset1
  2843. xx-p-offset
  2844. xx-p-ro90
  2845. xx-p-ro
  2846. xx-p-sc2
  2847. xx-p-sc
  2848. xx-p-ucs-obj2w
  2849. xx-p-ucs-w2obj
  2850. xx-p-pts2ucs
  2851. xx-p-pts2wcs
  2852. xx-p-2p3p
  2853. xx-p-3p2p
  2854. xx-p-2PDiv
  2855. xx-p-DivNumBy
  2856. xx-p-del-RetPt
  2857. xx-p-del-RetPt1
  2858. xx-p-Close
  2859. xx-p-pd-pInS1
  2860. xx-p-pd-pInCircle
  2861. xx-p-pd-2pToL-InSS
  2862. xx-p-pd-InView
  2863. xx-p-pd-P2PL
  2864. xx-p-pd-p
  2865. xx-p-pd-PInC
  2866. xx-p-pd-ppp
  2867. xx-p-pd-p-pts
  2868. xx-p-pd-P-ToEn
  2869. xx-p-pd-PtsInC
  2870. xx-p-P2L-dist
  2871. xx-p-P2L-Foot-p
  2872. xx-p-pd-pToS1
  2873. xx-p-pd-PtsIsOffscr
  2874. xx-str-2-lst
  2875. xx-str-2-strlst
  2876. xx-str-2-tye-strst
  2877. xx-str-2-tye-strst2
  2878. xx-str-get-Numbersm
  2879. xx-str-HGStr2NumLst
  2880. xx-str-StrsLst
  2881. xx-str-Width
  2882. xx-str-2-SutSearch
  2883. xx-str-substr
  2884. xx-str-subst
  2885. xx-str-del-Nth
  2886. xx-str-reverse
  2887. xx-str-expe2
  2888. xx-str-expe
  2889. xx-str-FG
  2890. xx-str-FG-HzText
  2891. xx-str-fg-text
  2892. xx-str-FG-SzText
  2893. xx-str-StrLst-expe
  2894. xx-str-StrPad
  2895. xx-str-TrStr
  2896. xx-str-StrTr
  2897. xx-str-1-num-get
  2898. xx-str-1-num-put
  2899. xx-str-9-num-get
  2900. xx-str-9-num-put
  2901. xx-str-InStr1
  2902. xx-str-InStr9
  2903. xx-str-del-1
  2904. xx-str-del-9
  2905. xx-str-GetClipTxt
  2906. xx-str-SetClipTxt
  2907. xx-str-new-NilLst
  2908. xx-str-load-NilLst
  2909. xx-str-del-NilStr
  2910. xx-str-pd-isnum
  2911. xx-str-search
  2912. xx-str-zeropad
  2913. xx-str-RandStr
  2914. xx-str-nstr
  2915. xx-str-strconv
  2916. xx-ss-9pt
  2917. xx-ss-9pt1
  2918. xx-ss-DxfLst
  2919. xx-ss-Dxf12Lst
  2920. xx-ss-dxf-TyEnLst
  2921. xx-ss-dxf-TongJi
  2922. xx-ss-EnLastSs
  2923. xx-ss-EnLst
  2924. xx-ss-EntLst
  2925. xx-ss-inters
  2926. xx-ss-del
  2927. xx-ss-BingJi
  2928. xx-ss-JianJi
  2929. xx-ss-JiaoJi
  2930. xx-ss-apply-lst
  2931. xx-ss-MinBox
  2932. xx-ss-bo
  2933. xx-Ss-CenPt
  2934. xx-lay-S1ToLay
  2935. xx-lay-lay1to2
  2936. xx-lay-put-col
  2937. xx-lay-new-dq
  2938. xx-lay-mk-Layer
  2939. xx-lay-jz-hatch
  2940. xx-lay-jz-text
  2941. xx-lay-sd-lst
  2942. xx-lay-gb-lst
  2943. xx-lay-dj-lst
  2944. xx-lay-Plot-lst
  2945. xx-lay-NotPlot-lst
  2946. xx-lay-sd-name
  2947. xx-lay-sd-x
  2948. xx-lay-js-name
  2949. xx-lay-js-x
  2950. xx-lay-dj-name
  2951. xx-lay-dj-x
  2952. xx-lay-jd-name
  2953. xx-lay-jd-x
  2954. xx-lay-gb-name
  2955. xx-lay-gb-x
  2956. xx-lay-dk-name
  2957. xx-lay-dk-x
  2958. xx-lay-sd-dj-gb-name
  2959. xx-lay-sd-dj-gb-x
  2960. xx-lay-js-dk-jd-name
  2961. xx-lay-js-jd-dk-x
  2962. xx-lay-sd-p
  2963. xx-lay-gb-p
  2964. xx-lay-dj-p
  2965. xx-sort-lst
  2966. xx-sort-vl
  2967. xx-sort-str
  2968. xx-sort-StrLst
  2969. xx-sort-LstSub-i
  2970. xx-sort-LstSub-atom
  2971. xx-Sort-PtsToCurve
  2972. xx-sort-table
  2973. xx-dcl-CheckIn
  2974. xx-dcl-RsError
  2975. xx-dcl-doseterror
  2976. xx-dcl-ImageCrlDisable
  2977. xx-dcl-ImageFillColor
  2978. xx-dcl-CtrlDisable
  2979. xx-dcl-CtrlEnable
  2980. xx-dcl-add-lst
  2981. xx-dcl-show-sld
  2982. xx-table
  2983. xx-tb-str-MaxLen
  2984. xx-txt-lj-new
  2985. xx-txt-lj-rename
  2986. xx-txt-lj-get-File-x
  2987. xx-txt-lj-get-FName
  2988. xx-txt-lj-get-Path
  2989. xx-txt-lj-get-path-x
  2990. xx-txt-lj-get-Stem
  2991. xx-txt-lj-put-format
  2992. xx-txt-lj-m
  2993. xx-txt-lj-co-m
  2994. xx-txt-lj-del-lj
  2995. xx-txt-drive-x
  2996. xx-txt-lj-get-Drive
  2997. xx-txt-lj-get-Ext
  2998. xx-txt-lj-addSupportPath
  2999. xx-txt-2-FileLst
  3000. xx-txt-2-FileStr
  3001. xx-txt-file-2-lst
  3002. xx-txt-file-2-StrLst
  3003. xx-txt-del-line
  3004. xx-txt-HS-txt
  3005. xx-txt-HS
  3006. xx-txt-HSS
  3007. xx-txt-pd-FileNot
  3008. xx-txt-m
  3009. xx-txt-co-m
  3010. xx-txt-rename
  3011. xx-js-rtos
  3012. xx-js-fix-45
  3013. xx-js-fix
  3014. xx-js-LF
  3015. xx-js-LFG
  3016. xx-js-Lst
  3017. xx-js-NCF
  3018. xx-js-Pf
  3019. xx-js-Pfg
  3020. xx-js-PtsArea
  3021. xx-js-txt
  3022. xx-csc
  3023. xx-sec
  3024. xx-tan
  3025. xx-ctg
  3026. xx-cot
  3027. xx-cosh
  3028. xx-sinh
  3029. xx-tanh
  3030. xx-lg
  3031. xx-Asin
  3032. xx-Acos
  3033. xx-yxdl
  3034. xx-js-En2OPtDist
  3035. xx-group-new
  3036. xx-group-MkGroup
  3037. xx-group-AddGroup
  3038. xx-group-explode
  3039. xx-group-EnLst
  3040. xx-group-name
  3041. xx-group-NameLst
  3042. xx-group-NameEnLst
  3043. xx-group-NameLst-x
  3044. xx-group-x-muns
  3045. xx-group-GroupEnLst
  3046. xx-group-ent
  3047. xx-group-ents
  3048. xx-group-ent-x
  3049. xx-group-del-01
  3050. xx-group-del-mun
  3051. xx-group-del-wm
  3052. xx-group-del-x
  3053. xx-group-del-CarName
  3054. xx-group-join
  3055. xx-group-pd-OffOn
  3056. xx-Ang2Rad
  3057. xx-Rad2Ang
  3058. xx-block2group
  3059. xx-group2block
  3060. xx-E2O
  3061. xx-O2E
  3062. xx-Ess2Oss
  3063. xx-Oss2Ess
  3064. 16to10
  3065. 10to123
  3066. xx-num2hz
  3067. xx-hz2num
  3068. xx-RGB2Number
  3069. xx-RGB2HSL
  3070. xx-Number2RGB
  3071. xx-Hsl2rgb
  3072. xx-sxk-mk
  3073. xx-sxk-put-text-lst
  3074. xx-sxk-get-text
  3075. xx-sxk-put-text
  3076. xx-sxk-get-text-lst
  3077. xx-sxk-get-tag-lst
  3078. xx-sxk-put-TagHeight
  3079. xx-sxk-put-TagWidth
  3080. xx-sxk-put-TagIns
  3081. xx-sxk-put-visible
  3082. xx-sxk-BnEnt-get-ss
  3083. xx-vp-dj-Lay
  3084. xx-vp-jd-lay
  3085. xx-vp-dj-x
  3086. xx-vp-jd-x
  3087. xx-vp-get-dj-Lays
  3088. xx-vp-DrawVpBorder
  3089. xx-vp-HasLayoutName
  3090. xx-vp-ListLayouts
  3091. xx-vp-RenameLayout
  3092. xx-vp-ToggleLayouts
  3093. xx-ChangeBitmap
  3094. xx-ListToolbars
  3095. xx-mat-co-m
  3096. xx-Catch-Apply
  3097. xx-grread
  3098. xx-InPutBox
  3099. ))
  3100. ;a,1=abs
  3101. ;a,1=acad_colordlg
  3102. ;a,1=action_tile
  3103. ;a,1=add_list
  3104. ;a,1=alert
  3105. ;a,1=alloc
  3106. ;a,1=and
  3107. (setq newlst niL)
  3108. (foreach word words
  3109.         (setq word (strcase (vl-princ-to-string word) 1))
  3110.   (setq i 1)
  3111.   (repeat (strlen word)
  3112.     (setq re (strcat (substr (vl-string-subst "" "-" word) 1 i) ",3=" word))
  3113.     (setq newlst (cons re newlst))
  3114.     (setq i (1+ i))
  3115.   )
  3116. )
  3117. (setq file "d:\\1.txt")
  3118. (setq f (open file "w"))
  3119. (foreach x newlst
  3120.   (write-line x f)
  3121. )
  3122. (close f)
GMT+8, 2026-11-6 15:50 , Processed in 0.731079 second(s), 32 queries , Gzip On.
