查看: 3273|回复: 2
[分享] 对任意平面的镜像
发表于 2013-12-21 16:43:36 | 显示全部楼层 |阅读模式
http://379910987.blog.163.com/blog/static/33523797201011306586296/?suggestedreading&wumii
对任意平面的镜像
数学基础
如果向量n为平面P的单位法向量,即有:
则实体关于该平面的变换矩阵为:
AutoCAD环境下的实现
下面是测试代码,我们用三个点构建一个平面,平面的Normal返回一个Vector3d对象,该对象是该平面的单位法向量。
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
namespace CADTest
    public class Class1
        #region实体镜像
        [CommandMethod("MP")]//Mirror Entity
        public void MirrorEntity()
Database db = Application.DocumentManager.MdiActiveDocument.Database;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            //对称平面
Plane mp = new Plane(new Point3d(1, 0, 0), new Point3d(0, 1, 0), new Point3d(0, 0, 1));
            double x = mp.Normal.X;
            double y = mp.Normal.Y;
double z = mp.Normal.Z;
double[] dm = new double[16];
            dm[0] = 1 - 2 * x * x;
dm[5] = 1 - 2 * y * y;
            dm[10] = 1 - 2 * z * z;
            dm[15]=1;
            dm[1] = dm[4] = -2*x * y;
            dm[2] = dm[8] = -2*x * z;
            dm[6] = dm[9] = -2*y * z;
Matrix3d Tm = new Matrix3d(dm);
using (Transaction trans = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
Solid3d sld = new Solid3d();
                sld.SetDatabaseDefaults();
                sld.CreateBox(100, 150, 200);
                sld.ColorIndex = 1;//red
                btr.AppendEntity(sld);
                trans.AddNewlyCreatedDBObject(sld, true);
Solid3d sldClone = sld.Clone() as Solid3d;
                sldClone.ColorIndex = 3;//green
                sldClone.TransformBy(Tm);
                btr.AppendEntity(sldClone);
                trans.AddNewlyCreatedDBObject(sldClone, true);
                trans.Commit();
        #endregion
评分
参与人数 1D豆 +3 收起 理由
ScmTools + 3 出题引导交流奖!
查看全部评分
发表于 2013-12-22 14:57:35 | 显示全部楼层
不错的例子
发表于 2014-5-5 21:15:20 来自手机 | 显示全部楼层
Mark
1 new plan (p1,p2,p3)
2 new Matrix3d (new Double[16])
3 clone transformby
GMT+8, 2026-11-22 07:47 , Processed in 0.321192 second(s), 15 queries , Gzip On, File On.
