查看: 1229|回复: 0
[求助] 帮忙看看这个动态坐标 !
已领礼包: 127个
发表于 2014-1-4 21:49:40 | 显示全部楼层 |阅读模式
  1. (VL-LOAD-COM)
  2. (or copy_reactor (setq copy_reactor (vlr-command-reactor "copy_reactor" '((:vlr-commandEnded . copy_1)))))
  3. (setvar "copymode" 1)
  4. (defun C:dtbz2 (/ p1 p2 pt1 pt2 pts mSpace Mtextobj )
  5.   (setq mSpace (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
  6.   (setq p1 (getpoint "\n选择要标注的点:"))
  7.   (setq p2 (getpoint p1 "\n选择标注文字位置:"))
  8.   (setq pt2 (vlax-3D-point p2))
  9.   (setq  Mtextobj (vla-addMtext mSpace pt2 0.0 (strcat "X="(rtos (car p1) 2 4) "\nY="(rtos (cadr p1) 2 4))))
  10. (setq MtextH (*(getvar "DIMSCALE")  (getvar "DIMTXT")));文字高度为当前标柱样式文字高度*全局比例
  11.   (vlax-put-property Mtextobj 'Height MtextH)
  12.   (vlax-put-property Mtextobj 'LineSpacingDistance (+ MtextH 1))
  13.   (if (> (car p1) (car p2))
  14.     (vlax-put-property Mtextobj 'AttachmentPoint 9)
  15.     (vlax-put-property Mtextobj 'AttachmentPoint 7)
  16.   )
  17.   (vlax-put-property Mtextobj 'InsertionPoint pt2)
  18.   (setq pts (vlax-make-safearray vlax-vbDouble '(0 . 5)))
  19.   (vlax-safearray-fill pts (list (car p1)(cadr p1)(caddr p1)(car p2)(cadr p2)(caddr p2)))
  20.   (setq leaderobj (vla-Addleader mSpace pts Mtextobj acLineWithArrow))
  21.   (setq vlr-objgx (vlr-object-reactor (list leaderobj) "" '((:vlr-modified . gx))))
  22.   (setq vlr-objcopy (vlr-object-reactor (list leaderobj) "" '((:vlr-copied . copy_2))))
  23.   (princ))
  24. (defun copy_2 (obj vlrobj data)
  25.   (if (/= (car data) 0)
  26.     (setq newename (car data))))
  27. (defun copy_1 (vlrobj data)
  28.   (if (wcmatch (strcase (car data)) "*COPY*")
  29.     (progn (setq newobj (vlax-ename->vla-object newename))
  30.       (setq vlr-objgx  (vlr-object-reactor (list newobj) "" '((:vlr-modified . gx))))
  31.       (setq vlr-objcopy  (vlr-object-reactor (list newobj) "" '((:vlr-copied . copy_2))))
  32.       (princ))))
  33. (defun gx (obj vlrobj data / p1 pt1 Aobj)
  34.   (if (and (not(vlax-erased-p obj)) (setq Aobj (vlax-get-property obj 'Annotation)));判断对象是否被删除
  35.   (progn  (setq pt1 (vlax-get-property obj 'Coordinate 0))
  36.   (setq p1 (vlax-safearray->list (vlax-variant-value pt1)))
  37.   (vlax-put-property Aobj 'TextString (strcat  "X=" (rtos (car p1) 2 4) "\nY="(rtos (cadr p1) 2 4))))));小数保持4位
  • 现在是 x y 轴的坐标都在引线上面  怎么改成引线在两个坐标中间呢!是不是能批量标在多段线端点处?
GMT+8, 2026-11-6 15:48 , Processed in 0.391694 second(s), 29 queries , Gzip On.
