查看: 3265|回复: 12
[求助] 求
已领礼包: 60个
发表于 2014-1-11 16:13:39 | 显示全部楼层 |阅读模式
已领礼包: 12492个
发表于 2014-1-11 16:37:40 | 显示全部楼层
程序未调试
  1. ;矩形四角外画圆 晓东 zxq0220 2014.1.11
  2. (defun c:tt ()
  3. (defun box (e)
  4.   (vla-getboundingbox(vlax-ename->vla-object e)'p1 'p2)
  5.   (list (vlax-safearray->list p1) (vlax-safearray->list p2))
  6. )
  7. (if (setq ss (ssget)) (progn
  8.   (setq p1 (list -1e16 -1e16) p2 (list 1e16 1e16))
  9.   (setq i -1 plst (list))
  10.   (repeat (sslength ss)
  11.    (setq en (ssname ss (setq i (1+ i))))
  12.    (setq plst (append plst (box en)))
  13.   )
  14.   (setq xmin (apply 'min (mapcar 'car plst)))
  15.   (setq ymin (apply 'min (mapcar 'cadr plst)))
  16.   (setq xmax (apply 'max (mapcar 'car plst)))
  17.   (setq ymax (apply 'max (mapcar 'cadr plst)))
  18.   (setq p1 (mapcar '- (list xmin ymin) '(2 2)))
  19.   (setq p2 (mapcar '- (list xmax ymin) '(-2 2)))
  20.   (setq p3 (mapcar '+ (list xmin ymax) '(-2 2)))
  21.   (setq p4 (mapcar '+ (list xmax ymax) '(2 2)))
  22.   (entmake (list '(0 . "CIRCLE") (cons 10 p1) '(40 . 2)))
  23.   (entmake (list '(0 . "CIRCLE") (cons 10 p2) '(40 . 2)))
  24.   (entmake (list '(0 . "CIRCLE") (cons 10 p3) '(40 . 2)))
  25.   (entmake (list '(0 . "CIRCLE") (cons 10 p4) '(40 . 2)))
  26. ))
  27. (princ)
  28. )
[attachimg]8803[/attachimg] ;;; 四个角画2.0的圆孔================================ (defun c:wz() (princ"\n画四周最大外形[4]个角2.0圆:") (defun box (e) (vla-getboundingbox (vlax-ename->vl  详情 回复 发表于 2014-7-17 19:02
zxq 运行出现这问题:选择对象: ; 错误: no function definition: ENTMAK 麻烦再帮忙改下,另外能不能改成什么形状都行,不是4边形,其他形状(比如圆)  详情 回复 发表于 2014-1-12 08:25
已领礼包: 1268个
发表于 2014-1-11 16:56:19 | 显示全部楼层
对照下 API 应用,仅对正放的形状
  1. (defun c:tt (/ ss)
  2.   (if (setq ss (ssget '((0 . "lwpolyline"))))
  3.     (mapcar '(lambda (x / box nbox)
  4.                (setq box  (XD::Pnts:Close (xdrx_entity_box x));_包围盒点封闭
  5.                      nBox (apply 'xdrx_points_offset (cons 2 box));_点集偏移,需要封闭点表
  6.                )
  7.                (mapcar '(lambda        (p)
  8.                           (xdrx_circle_make p 2.)
  9.                         )
  10.                        nBox
  11.                );_新形成的包围盒四个点画圆
  12.              )
  13.             (xdrx_pickset->ents ss);_选择集转图元列表
  14.     )
  15.   )
  16.   (princ)
  17. )
ST788796[attachimg]7557[/attachimg]能不能再帮忙改下,什么形状都能画4个角2.0的圆。  详情 回复 发表于 2014-1-12 08:28
已领礼包: 60个
 楼主| 发表于 2014-1-12 08:25:43 | 显示全部楼层
已领礼包: 60个
 楼主| 发表于 2014-1-12 08:28:57 | 显示全部楼层
st788796 发表于 2014-1-11 16:56
对照下 API 应用,仅对正放的形状
ST788796 QQ图片20140112082811.jpg 能不能再帮忙改下,什么形状都能画4个角2.0的圆。
已领礼包: 1268个
发表于 2014-1-12 09:15:21 来自手机 | 显示全部楼层
两个程序都可以画任意形状的,zxq的应为entmake,第二个程序把原ssget括号内的'((0 . "lwpolyline"))去掉即可
[attachimg]8802[/attachimg] ;;; 四个角画2.0的圆孔================================ (defun c:wz() (princ"\n画四周最大外形[4]个角2.0圆:") (defun box (e) (vla-getboundingbox (vlax-ename->vla-  详情 回复 发表于 2014-7-17 14:24
多谢st788796 ,程序非常好,  详情 回复 发表于 2014-1-12 10:08
已领礼包: 60个
 楼主| 发表于 2014-1-12 10:08:50 | 显示全部楼层
st788796 发表于 2014-1-12 09:15
两个程序都可以画任意形状的,zxq的应为entmake,第二个程序把原ssget括号内的'((0 . "lwpolyline"))去掉即 ...
多谢st788796 ,程序非常好,
已领礼包: 60个
 楼主| 发表于 2014-7-17 14:24:13 | 显示全部楼层
(defun c:wz()
  (defun box (e)
    (vla-getboundingbox (vlax-ename->vla-object e) 'p1 'p2)
    (list (vlax-safearray->list p1) (vlax-safearray->list p2)))
    (progn
        (setq plst (append plst (box en))))
      (setq p1 (mapcar '- (list xmin ymin) '(4 -4)))
      (setq p2 (mapcar '- (list xmax ymin) '(-4 -4)))
      (setq p3 (mapcar '+ (list xmin ymax) '(-4 -4)))
      (setq p4 (mapcar '+ (list xmax ymax) '(-4 4)))
      (entmake (list '(0 . "CIRCLE") (cons 10 p1) '(40 . 1)))
      (entmake (list '(0 . "CIRCLE") (cons 10 p2) '(40 . 1)))
      (entmake (list '(0 . "CIRCLE") (cons 10 p3) '(40 . 1)))
      (entmake (list '(0 . "CIRCLE") (cons 10 p4) '(40 . 1)))
  (princ)
ST请帮忙改改,现在程序可以自动放4个角,麻烦你帮忙修改成上下正中间再多加2个孔,谢谢!
已领礼包: 60个
 楼主| 发表于 2014-7-17 19:02:06 | 显示全部楼层
(defun c:wz()
  (defun box (e)
    (progn
  (princ)
zxq请帮忙改改,现在程序可以自动放4个角,麻烦你帮忙修改成上下正中间再多加2个孔,谢谢!
已领礼包: 12492个
发表于 2014-7-17 19:44:21 | 显示全部楼层
  1. ;矩形四角外画圆 晓东 zxq0220 2014.1.11 2014.7.17
  2. (defun c:tt ()
  3. (defun box (e)
  6. )
  7. (defun mkcir (p r)
  8.   (entmake (list '(0 . "CIRCLE") (cons 10 p) (cons 40 r)))
  9. )
  10. (if (setq ss (ssget)) (progn
  11.   (setq i -1 plst (list))
  12.   (repeat (sslength ss)
  13.    (setq en (ssname ss (setq i (1+ i))))
  14.    (setq plst (append plst (box en)))
  15.   )
  16.   (setq xmin (apply 'min (mapcar 'car plst)))
  17.   (setq ymin (apply 'min (mapcar 'cadr plst)))
  18.   (setq xmax (apply 'max (mapcar 'car plst)))
  19.   (setq ymax (apply 'max (mapcar 'cadr plst)))
  20.   (setq p1 (mapcar '- (list xmin ymin) '(2 2)))
  21.   (setq p2 (mapcar '- (list xmax ymin) '(-2 2)))
  22.   (setq p3 (mapcar '+ (list xmin ymax) '(-2 2)))
  23.   (setq p4 (mapcar '+ (list xmax ymax) '(2 2)))
  24. (mkcir p1 2)
  25. (mkcir p2 2)
  26. (mkcir p3 2)
  27. (mkcir p4 2)
  28. (mkcir (mapcar '(lambda (a b) (/ (+ a b) 2)) p1 p2) 2)
  29. (mkcir (mapcar '(lambda (a b) (/ (+ a b) 2)) p3 p4) 2)
  30. ))
  31. (princ)
  32. )
[attachimg]11377[/attachimg] 还得请ZXQ0220帮忙再加4个圆,注:上面2个是根据中心距离,谢谢!  详情 回复 发表于 2014-11-17 14:39
谢,明天去测试,  详情 回复 发表于 2014-7-17 20:35
已领礼包: 60个
 楼主| 发表于 2014-7-17 20:35:37 | 显示全部楼层
谢,明天去测试,
已领礼包: 60个
 楼主| 发表于 2014-11-17 14:39:57 | 显示全部楼层
已领礼包: 60个
 楼主| 发表于 2014-11-17 14:40:46 | 显示全部楼层
  1. ;-----------进威要求外形点----------
  2. (defun c:ww()
  3. (defun box (e)
  4. (command "layer" "s" "1" "")
  5.   (vla-getboundingbox(vlax-ename->vla-object e)'p1 'p2)
  6.   (list (vlax-safearray->list p1) (vlax-safearray->list p2))
  7. )
  8. (defun mkcir (p r)
  9.   (entmake (list '(0 . "CIRCLE") (cons 10 p) (cons 40 r)))
  10. )
  11. (if (setq ss (ssget)) (progn
  12.   (setq i -1 plst (list))
  13.   (repeat (sslength ss)
  14.    (setq en (ssname ss (setq i (1+ i))))
  15.    (setq plst (append plst (box en)))
  16.   )
  17.   (setq xmin (apply 'min (mapcar 'car plst)))
  18.   (setq ymin (apply 'min (mapcar 'cadr plst)))
  19.   (setq xmax (apply 'max (mapcar 'car plst)))
  20.   (setq ymax (apply 'max (mapcar 'cadr plst)))
  21.   (setq p1 (mapcar '- (list xmin ymin) '(4 -4)))
  22.   (setq p2 (mapcar '- (list xmax ymin) '(-4 -4)))
  23.   (setq p3 (mapcar '+ (list xmin ymax) '(-4 -4)))
  24.   (setq p4 (mapcar '+ (list xmax ymax) '(4 -4)))
  25. (mkcir p1 2.0)
  26. (mkcir p2 2.0)
  27. (mkcir p3 2.0)
  28. (mkcir p4 2.0)
  29. (mkcir (mapcar '(lambda (a b) (/ (+ a b) 2)) p1 p3) 2.0)
  30. (mkcir (mapcar '(lambda (a b) (/ (+ a b) 2)) p2 p4) 2.0)
  31. (mkcir (mapcar '(lambda (a b) (/ (+ a b) 2)) p3 p5) 2.0)
  32. (mkcir (mapcar '(lambda (a b) (/ (+ a b) 2)) p4 p6) 2.0)
  33. ))
  34. (princ)
  35. )
GMT+8, 2026-11-6 07:59 , Processed in 0.565200 second(s), 62 queries , Gzip On.
