查看: 2201|回复: 0
[文件] (XD::XML:SetNodeProperties)设置节点属性
发表于 2014-2-8 09:26:33 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::XML:SetNodeProperties
调用格式: (XD::XML:SetNodeProperties xmlobj lst)
参数说明: xmlobj ---- xml dom
lst ---- 表
返回值: 表
函数简介: 设置节点 attribute text comment cdata
函数来源: 原创
函数作者: st788796
适用版本: 不限
最后更新时间: 2014-02-08
备注: -
演示图片: -
  1. ;|
  2. 2 attribute
  3. 3 "TEXT"
  4. 4 "CDATA"
  5. 8 "COMMENT"
  6. |;
  7. ;;("ATTR" "test") or ("ATTR" ("lang" "en"))
  8. ;;(("ATTR" ("lang" "en")) ("TEXT" "dddde" "ddere") ("COMMENT" "dfafa" "fasfdsa") ("CDATA" "fadsfsa" "fdasfa" "adafa"))
  9. (defun XD::XML:SetNodeProperties
  10.        (xmlobj lst / _getnodeType _setattribute _setproperty doc)
  11.   (defun _getnodeType (str)
  12.     (setq str (strcase str))
  13.     (cond
  14.       ((= str "ATTR") 2)
  15.       ((= str "TEXT") 'createTextNode) ;_
  16.       ((= str "COMMENT") 'createComment) ;_
  17.       ((= str "CDATA") 'createCDATASection) ;_
  18.       (t nil)
  19.     )
  20.   )
  21.   (defun _setattribute (node lst)
  22.     (if        (= (type lst) 'STR)
  23.       (setq lst (list "atttribute" lst))
  24.     )
  25.     (vl-catch-all-apply
  26.       'vlax-invoke-method
  27.       (append (list node "setAttribute") lst)
  28.     )
  29.   )
  30.   (defun _setproperty (node func lst /)
  31.     (setq element (vlax-invoke-method
  32.                     (vlax-get-property node 'ownerDocument)
  33.                     func
  34.                     ""
  35.                   )
  36.     )
  37.     (vlax-put-property element 'text lst)
  38.     (vlax-invoke-method node 'appendChild element)
  39.   )
  40.   (if (= (vlax-get-property xmlobj 'nodeType) 9)
  41.     (setq doc xmlobj)
  42.     (setq doc (vlax-get-property xmlobj 'ownerDocument))
  43.   )
  44.   (mapcar
  45.     '(lambda (x)
  46.        (mapcar '(lambda        (a / typ tag att)
  47.                   (setq typ (_getnodeType (car x)))
  48.                   (if (= typ 2)
  49.                     (_setattribute xmlobj a)
  50.                     (_setproperty xmlobj typ a)
  51.                   )
  52.                 )
  53.                (cdr x)
  54.        )
  55.      )
  56.     lst
  57.   )
  58. )
GMT+8, 2026-11-22 09:51 , Processed in 0.169088 second(s), 10 queries , Gzip On, File On.
