查看: 2263|回复: 0
[发布] API应用 不同属性块间相同属性匹配
发表于 2014-2-14 20:42:39 | 显示全部楼层 |阅读模式
  1. (defun c:tt (/ e lst ss)
  2.   (if (setq e (car (xdrx_entsel "\n点选源属性块: " '((66 . 1)))))
  3.     (progn
  4.       (setq
  5.         lst (mapcar '(lambda (x)
  6.                        (list (xdrx_getpropertyvalue x "Tag")
  7.                              (xdrx_getpropertyvalue x "Textstring")
  8.                        )
  9.                      )
  10.                     (xdrx_insert_getattribs e)
  11.             )
  12.       )
  13.       (while (progn
  14.                (princ "\n选择目标属性块.....")
  15.                (setq ss (ssget '((66 . 1))))
  16.              )
  17.         (mapcar
  18.           '(lambda (x)
  19.              (mapcar
  20.                '(lambda        (a / var)
  21.                   (if (setq
  22.                         var (assoc (xdrx_getpropertyvalue a "Tag") lst)
  23.                       )
  24.                     (xdrx_setpropertyvalue a "Textstring" (cadr var))
  25.                   )
  26.                 )
  27.                (xdrx_insert_getattribs x)
  28.              )
  29.            )
  30.           (xdrx_pickset->ents ss)
  31.         )
  32.       )
  33.     )
  34.   )
  35.   (princ)
  36. )
GMT+8, 2026-11-22 11:07 , Processed in 0.278810 second(s), 9 queries , Gzip On, File On.
