查看: 1477|回复: 1
[他山之石] api-error
已领礼包: 1268个
发表于 2014-2-21 19:56:13 | 显示全部楼层 |阅读模式
  1. ;;;***********************************************************************
  2. ;;; MODULE: api-error
  3. ;;; DESCRIPTION: wraps a function to trap Active-X errors - if error is found
  4. ;;; DESCRIPTION: function returns nil.
  5. ;;; ARGS: function to check, list of arguments, boolean (return error message?) T or nil
  6. ;;; EXAMPLE: (api-error '/ (list 50 0) T) displays "VLISP Error: divide by zero" & returns 'nil'
  7. ;;;***********************************************************************
  8. (defun api-error (func lst bool / trap)
  9.   (cond
  10.     ((vl-catch-all-error-p
  11.        (setq trap (vl-catch-all-apply func lst))
  12.      )
  13.      (if bool
  14.        (princ (strcat "\nVLISP XML Error: "
  15.                       (vl-catch-all-error-message trap)
  16.               )
  17.        )
  18.      )
  19.      (setq trap nil)
  20.     )
  21.   )
  22.   trap
  23. )
发表于 2014-4-16 15:23:15 | 显示全部楼层
学习是美德,回复是习惯
GMT+8, 2026-11-6 12:17 , Processed in 0.501918 second(s), 31 queries , Gzip On.
