查看: 1883|回复: 2
[求助] 等高线缩放高程不变
发表于 2014-3-6 11:03:00 | 显示全部楼层 |阅读模式
再求大神们赐教。如何能让等高线缩放之后Z值或标高不变!不要用CAD自带分轴缩放的那种我实验了不行。谢谢你们
已领礼包: 1268个
发表于 2014-3-6 11:06:12 | 显示全部楼层
先记录标高,缩放,重新赋标高
发表于 2014-3-6 11:16:14 | 显示全部楼层
  1. (defun c:tt (/ ss el p elevl scl)
  2.   (if (and (setq ss (ssget '((0 . "*Polyline"))))
  3.            (setq p (getpoint "\nbase point: "))
  4.            (setq scl (getreal "\nScaleFactor: "))
  5.       )
  6.     (progn
  7.       (setq el          (fy:cset->objs)
  8.             elevL (mapcar '(lambda (x)
  9.                              (vla-get-elevation x)
  10.                            )
  11.                           el
  12.                   )
  13.       )
  14.       (vl-cmdf ".scale" ss "" p scl)
  15.       (mapcar '(lambda (x y)
  16.                  (vla-put-elevation x y)
  17.                )
  18.               el
  19.               elevL
  20.       )
  21.     )
  22.   )
  23.   (princ)
  24. )
GMT+8, 2026-11-6 12:17 , Processed in 0.434857 second(s), 33 queries , Gzip On.
