查看: 1815|回复: 1
[求助] 初学LISP,希望高手能详解每句语言?语法?
已领礼包: 50个
发表于 2014-3-7 10:35:58 | 显示全部楼层 |阅读模式
(vl-load-com)(setq mspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setvar "cmdecho" 0)
(defun c:tx(/ region  pointregion Moment minp maxp newminp newmaxp Yx Yy )
  (print "Select a region:")
  (setq region  (car (entsel)))
  (while (or (null region)  (/= (cdr (assoc '0 (entget  region)))  "REGION"))
   (print "Select a region:")(setq region  (car (entsel)))
  (command "ucs" "W" )
  (SETQ vlaregion (vlax-ename->vla-object region))
  (setq  pointregion (vlax-safearray->list  (vlax-variant-value  (vla-get-Centroid  vlaregion))))
(command "osnap" "none")
  (command "ucs" "m" pointregion)
  (setq  Moment (vlax-safearray->list  (vlax-variant-value    (vla-get-MomentOfInertia  vlaregion))))
  (vla-getboundingbox vlaregion 'minpoint 'maxpoint )
         (setq minp (vlax-safearray->list  minpoint))
         (setq maxp (vlax-safearray->list  maxpoint))
(setq newminp (list (- (car minp) (car pointregion))(- (cadr minp) (cadr pointregion))))
(setq newmaxp (list (- (car maxp) (car pointregion))(- (cadr maxp) (cadr pointregion))))
(setq Yx (max  (abs (cadr newminp)) (abs (cadr newmaxp)) ))
(setq Yy(max  (abs (car newminp)) (abs (car newmaxp)) ))
   (princ "\n")
(princ "\nArea=:")(princ (vla-get-Area  vlaregion))
(princ "\nIx=:")(princ (car Moment))
(princ "\nIy=:")(princ (cadr Moment))
(princ "\nYx=:")(princ Yx)
(princ "\nYy=:")(princ Yy)
(princ "\nWx=:")(princ (/ (car Moment) Yx))
(princ "\nWy=:")(princ (/ (cadr Moment) Yy))
  (princ "\n")
(command "OSMODE" "16383")
  (command "massprop" region "" )
已领礼包: 1268个
发表于 2014-3-8 10:53:18 | 显示全部楼层
  1. (setvar "cmdecho" 0)
  2. (defun c:tx (/               region         pointregion             Moment
  3.              minp      maxp         newminp   newmaxp   Yx
  4.              Yy
  5.             )
  6.   (print "Select a region:")
  7.   (setq region (car (entsel)));_选择面域
  8.   (while (or (null region);_空选
  9.              (/= (cdr (assoc '0 (entget region))) "REGION");_非面域
  10.          )
  11.     (print "Select a region:")
  12.     (setq region (car (entsel)));_重新点选
  13.   );_循环直至点选的实体为面域
  14.   (command "ucs" "W");_转为世界坐标
  15.   (SETQ vlaregion (vlax-ename->vla-object region));_转化为 Object
  16.   (setq        pointregion
  17.          (vlax-safearray->list
  18.            (vlax-variant-value (vla-get-Centroid vlaregion));_质心
  19.          )
  20.   )
  21.   (command "osnap" "none")
  22.   (command "ucs" "m" pointregion);_设置UCS
  23.   (setq
  24.     Moment (vlax-safearray->list
  25.              (vlax-variant-value (vla-get-MomentOfInertia vlaregion))
  26.            )
  27.   )
  28.   (vla-getboundingbox vlaregion 'minpoint 'maxpoint);_包围盒
  29.   (setq minp (vlax-safearray->list minpoint))
  30.   (setq maxp (vlax-safearray->list maxpoint))
  31.   (setq        newminp        (list (- (car minp) (car pointregion))
  32.                       (- (cadr minp) (cadr pointregion))
  33.                 )
  34.   )
  35.   (setq        newmaxp        (list (- (car maxp) (car pointregion))
  36.                       (- (cadr maxp) (cadr pointregion))
  37.                 )
  38.   )
  39.   (setq Yx (max (abs (cadr newminp)) (abs (cadr newmaxp))))
  40.   (setq Yy (max (abs (car newminp)) (abs (car newmaxp))))
  41.   (princ "\n")
  42.   (princ "\nArea=:")
  43.   (princ (vla-get-Area vlaregion));_面积
  44.   (princ "\nIx=:")
  45.   (princ (car Moment))
  46.   (princ "\nIy=:")
  47.   (princ (cadr Moment))
  48.   (princ "\nYx=:")
  49.   (princ Yx)
  50.   (princ "\nYy=:")
  51.   (princ Yy)
  52.   (princ "\nWx=:")
  53.   (princ (/ (car Moment) Yx))
  54.   (princ "\nWy=:")
  55.   (princ (/ (cadr Moment) Yy))
  56.   (princ "\n")
  57.   (command "OSMODE" "16383")
  58.   (command "massprop" region "")
  59. )
GMT+8, 2026-11-6 12:17 , Processed in 0.363712 second(s), 31 queries , Gzip On.
