查看: 1899|回复: 3
[求助] OBJECTARX添加的 C++类
发表于 2014-3-20 22:28:16 | 显示全部楼层 |阅读模式
这个问题 有些纠结 各位有没有试过啊!
这是新建的类的源码
  1. #pragma once
  2. #include "StdAfx.h"
  3. class Myclass
  4. {
  5. public:
  6.   Myclass(void);
  7.   ~Myclass(void);
  8. public:
  9.   static AcDbObjectId creatline();
  10. };
  11. AcDbObjectId Myclass::creatline()
  12. {
  13.   AcGePoint3d ptStart(0,0,0);
  14.   AcGePoint3d ptEnd(100,100,0);
  15.   AcDbLine *pLine=new AcDbLine(ptStart,ptEnd);
  16.   //获取块表
  17.   AcDbBlockTable *pBloTbl;
  18.   acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBloTbl,AcDb::kForRead);
  19.   //获取块表记录
  20.   AcDbBlockTableRecord *pBloTblRcd;
  21.   pBloTbl->getAt(ACDB_MODEL_SPACE,pBloTblRcd,kForWrite);
  22.   AcDbObjectId entId;
  23.   pBloTblRcd->appendAcDbEntity(entId,pLine);
  24.   pBloTbl->close();
  25.   pBloTblRcd->close();
  26.   pLine->close();
  27.   return entId;
  28. }
复制代码
入口点文件中代码如下:
  1. // (C) Copyright 2002-2007 by Autodesk, Inc.
  2. //
  3. // Permission to use, copy, modify, and distribute this software in
  4. // object code form for any purpose and without fee is hereby granted,
  5. // provided that the above copyright notice appears in all copies and
  6. // that both that copyright notice and the limited warranty and
  7. // restricted rights notice below appear in all supporting
  8. // documentation.
  9. //
  10. // AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
  11. // AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
  12. // MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  AUTODESK, INC.
  13. // DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
  14. // UNINTERRUPTED OR ERROR FREE.
  15. //
  16. // Use, duplication, or disclosure by the U.S. Government is subject to
  17. // restrictions set forth in FAR 52.227-19 (Commercial Computer
  18. // Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
  19. // (Rights in Technical Data and Computer Software), as applicable.
  20. //
  21. //-----------------------------------------------------------------------------
  22. //----- acrxEntryPoint.cpp
  23. //-----------------------------------------------------------------------------
  24. #include "StdAfx.h"
  25. #include "resource.h"
  26. #include "Myclass.h"
  27. //-----------------------------------------------------------------------------
  28. #define szRDS _RXST("YS")
  29. //-----------------------------------------------------------------------------
  30. //----- ObjectARX EntryPoint
  31. class CArxProject3App : public AcRxArxApp {
  32. public:
  33.   CArxProject3App () : AcRxArxApp () {}
  34.   virtual AcRx::AppRetCode On_kInitAppMsg (void *pkt) {
  35.     // TODO: Load dependencies here
  36.     // You *must* call On_kInitAppMsg here
  37.     AcRx::AppRetCode retCode =AcRxArxApp::On_kInitAppMsg (pkt) ;
  38.
  39.     // TODO: Add your initialization code here
  40.     return (retCode) ;
  41.   }
  42.   virtual AcRx::AppRetCode On_kUnloadAppMsg (void *pkt) {
  43.     // TODO: Add your code here
  44.     // You *must* call On_kUnloadAppMsg here
  45.     AcRx::AppRetCode retCode =AcRxArxApp::On_kUnloadAppMsg (pkt) ;
  46.     // TODO: Unload dependencies here
  47.     return (retCode) ;
  48.   }
  49.   virtual void RegisterServerComponents () {
  50.   }
  51.   // - YSArxProject3._MyCommand1 command (do not rename)
  52.   static void YSArxProject3_MyCommand1(void)
  53.   {
  54.     // Add your code for command YSArxProject3._MyCommand1 here
  55.     Myclass::creatline();
  56.   }
  57. } ;
  58. //-----------------------------------------------------------------------------
  59. IMPLEMENT_ARX_ENTRYPOINT(CArxProject3App)
  60. ACED_ARXCOMMAND_ENTRY_AUTO(CArxProject3App, YSArxProject3, _MyCommand1, MyCommand1, ACRX_CMD_TRANSPARENT, NULL)
复制代码
报错消息如下:
错误        1        error LNK2005: "public: static class AcDbObjectId __cdecl Myclass::creatline(void)" (?creatline@Myclass@@SA?AVAcDbObjectId@@XZ) 已经在 acrxEntryPoint.obj 中定义        Myclass.obj        ArxProject3
错误        2        fatal error LNK1169: 找到一个或多个多重定义的符号        E:\VS_CAD\ArxProject3\Win32\Debug/YSArxProject3.arx        ArxProject3
 楼主| 发表于 2014-4-10 22:37:20 | 显示全部楼层
汗居然没有人回  我已经搞定 了
你怎么搞定的?  详情 回复 发表于 2014-4-10 22:55
已领礼包: 145个
发表于 2014-4-10 22:55:45 | 显示全部楼层
小妖妖 发表于 2014-4-10 22:37
汗居然没有人回  我已经搞定 了
你怎么搞定的?
 楼主| 发表于 2014-4-11 23:52:54 | 显示全部楼层
在入口点文件中添加#INCLUDE即可
GMT+8, 2026-11-3 19:27 , Processed in 0.749882 second(s), 35 queries , Gzip On.
