查看: 2720|回复: 1
[他山之石] 找到最少entmake关键元素 ;作者:不死猫
发表于 2014-4-12 23:59:47 | 显示全部楼层 |阅读模式
  1. ;找到最少entmake关键元素   ;作者:不死猫
  2. (defun c:tt( / del_ent ele ent i must new_ent)
  3.   (setq ent (entget (car (entsel "\n请选择一个图元"))));得到组码
  4.   (setq i 0 must '());初始化
  5.   (repeat (length ent)
  6.     (setq del_ent (vl-remove (nth i ent) ent));测试删除
  7.     (setq new_ent (entmake del_ent));测试生成
  8.     (if (= 10 (car (nth i ent)))
  9.       (progn
  10.         (setq must (append must (list (nth i ent))))
  11.         (if new_ent
  12.           (entdel (entlast))
  13.         )
  14.       )
  15.       (if new_ent;如果生成新图元则删除否则认为该元素为关键元素
  16.         (entdel (entlast))
  17.         (setq must (append must (list (nth i ent))))
  18.       )
  19.     )
  20.     (setq i (1+ i))
  21.   );end repeat
  22.
  23.   (cond
  24.     ((= "LWPOLYLINE" (cdr (assoc 0 ent)))
  25.       (setq must (append must (list (assoc 90 ent))))
  26.     )
  27.     ((= "SPLINE" (cdr (assoc 0 ent)))
  28.       (setq must (append must (list (assoc 74 ent))))
  29.       (foreach ele ent
  30.         (if (= 11 (car ele))
  31.           (setq must (append must (list ele)))
  32.         )
  33.       )
  34.     )
  35.     ((= "DIMENSION" (cdr (assoc 0 ent)))
  36.       (foreach ele ent
  37.         (if (or (= 11 (car ele))
  38.             (= 21 (car ele))
  39.             (= 31 (car ele))
  40.             (= 70 (car ele))
  41.             (= 71 (car ele))
  42.             (= 1 (car ele))
  43.             (= 3 (car ele))
  44.           )
  45.           (setq must (append must (list ele)))
  46.         )
  47.       )
  48.     )
  49.   )
  50.   (print must)
  51.   (princ)
  52. )
来晓东也有一段时间了...
在这也学了不少东西..也得到了很多大师们的帮助
现在分享一点小代码给大家参考一下
评分
参与人数 1D豆 +10 收起 理由
XDSoft + 10 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2014-4-13 11:33:48 | 显示全部楼层
可以查看 ActiveX 帮助,那些参数应该也是 Entmake 所必需参数,DXF 不能少的还有
(0 . "Line");_实体类型
(100 . "AcDbEntity");_AcDbEnity Class
(100 . "AcDbLine");_ ObjectName
GMT+8, 2026-11-22 09:06 , Processed in 0.330321 second(s), 11 queries , Gzip On, File On.
