查看: 1525|回复: 0
[原创] 练习 Lisp定义Split支持多个分隔符
已领礼包: 859个
发表于 2014-4-28 07:27:41 | 显示全部楼层 |阅读模式
[ 本帖最后由 csharp 于 2014-4-28 07:36 编辑 ]\n\n[ 本帖最后由 csharp 于 2014-4-28 07:34 编辑 ]\n\n
  1.         [LispFunction("String_Split")]
  2.         public static ResultBuffer StringSplit(ResultBuffer rb)
  3.         {
  4.             ResultBuffer  result = new ResultBuffer();
  5.             if (rb != null)
  6.             {
  7.                 TypedValue[] values = rb.AsArray();
  8.                 if (values.Count() >= 2 && values[0].TypeCode == (int)LispDataType.Text)
  9.                 {
  10.                     ArrayList strArrayList = new ArrayList();
  11.                     for (int i = 1; i < values .Count( ); i++)
  12.                         {
  13.                         if (values[i].TypeCode == (int) LispDataType.Text)
  14.                             {
  15.                             strArrayList.Add(values[i].Value.ToString());
  16.                             }
  17.                         }
  18.                     string[] splitStrings = new string[strArrayList.Count];
  19.                     if (strArrayList.Count != 0)
  20.                     {
  21.                         for (int i = 0; i < strArrayList.Count; i++)
  22.                         {
  23.                             splitStrings[i] = strArrayList[i].ToString() ;
  24.                         }
  25.                     }
  26.                     String str = values[0].Value.ToString();
  27.                     String[] strings = str.Split(splitStrings , StringSplitOptions.RemoveEmptyEntries);
  28.                     foreach (string st in strings)
  29.                         {
  30.                             result.Add(new TypedValue((int)LispDataType.Text, st));
  31.                         }
  32.                     }
  33.                     else
  34.                     {
  35.                         return null;
  36.                     }
  37.                 }
  38.             return result;
  39.         }
命令: (string_split "123a12312a12b1312" "a" "b")
("123" "12312" "12" "1312")
命令: (string_split "123a12312a12b1312" "a")
("123" "12312" "12b1312")
命令: 指定对角点或 [栏选(F)/圈围(WP)/圈交(CP)]:
命令: (string_split "123a12312a12b1312" "")
("123a12312a12b1312")
命令: (string_split "123a12312a12b1312" )
nil
这个比Lisp弄的循环好用多了,如果不考虑错误处理代码要简单的多
GMT+8, 2026-11-3 07:41 , Processed in 0.414760 second(s), 28 queries , Gzip On.
