查看: 1764|回复: 1
[分享] Copy From Groups
已领礼包: 859个
发表于 2014-5-1 22:58:54 | 显示全部楼层 |阅读模式
  1. using System;
  2. using System.Globalization;
  3. using System.Runtime.InteropServices;
  4. using Autodesk.AutoCAD.ApplicationServices;
  5. using Autodesk.AutoCAD.EditorInput;
  6. using Autodesk.AutoCAD.Runtime;
  7. using Autodesk.AutoCAD.Geometry;
  8. using Autodesk.AutoCAD.DatabaseServices;
  9. using Autodesk.AutoCAD.Interop.Common;
  10. using AcadApp = Autodesk.AutoCAD.Interop.AcadApplication;
  11. using Autodesk.AutoCAD.Interop;
  12. namespace PartGroupsMonitor
  13. {
  14.     class CopyGroupFromExisting
  15.     {
  16.         public void CreateGroup()
  17.         {
  18.             Document document = Application.DocumentManager.MdiActiveDocument;
  19.             Editor editor = document.Editor;
  20.             Database database = Application.DocumentManager.MdiActiveDocument.Database;
  21.             Matrix3d MoveMat = new Matrix3d();
  22.             string NewNam = "";
  23.
  24.             using (document.LockDocument())
  25.             {
  26.                 PromptEntityOptions options = new PromptEntityOptions("\nSelect part of Group: < pick > ");
  27.                 options.SetRejectMessage("\nMust be Group related. ");
  28.                 options.AddAllowedClass(typeof(Arc), false);
  29.                 options.AddAllowedClass(typeof(Line), false);
  30.                 options.AddAllowedClass(typeof(Circle), false);
  31.                 options.AddAllowedClass(typeof(Polyline), false);
  32.                 PaletteUtils.ActivateEditor();
  33.                 PromptEntityResult selection = editor.GetEntity(options);
  34.                 if (selection.Status == PromptStatus.OK)
  35.                 {
  36.                     Object MvePnt = GroupDisplacementPoint();
  37.                     if (MvePnt is Point3d)
  38.                     {
  39.                         Point3d p1 = (Point3d)MvePnt;
  40.                         using (Transaction trans = database.TransactionManager.StartTransaction())
  41.                         {
  42.                             Entity obj = (Entity)trans.GetObject(selection.ObjectId, OpenMode.ForRead);
  43.                             if (obj != null)
  44.                             {
  45.                                 Point3d basePt = obj.GeomExtents.MaxPoint;
  46.                                 MoveMat = Matrix3d.Displacement(p1.GetVectorTo(basePt));
  47.                                 ResultBuffer rbf = SafeNativeMethods.EntGet(obj.ObjectId);
  48.                                 TypedValue[] XdataOut = rbf.AsArray();
  49.                                 if (XdataOut[3].Value.ToString() == "{ACAD_REACTORS")
  50.                                 {
  51.
  52.                                     ObjectId reactorId = (ObjectId)XdataOut[4].Value;
  53.                                     DBDictionary GrpDic = (DBDictionary)trans.GetObject(database.GroupDictionaryId, OpenMode.ForWrite);
  54.                                     Group grp = (Group)trans.GetObject(reactorId, OpenMode.ForWrite);
  55.
  56.                                     string str = grp.Name;
  57.                                     NewNam = string.Concat(str.Substring(0, str.IndexOf("-", 0, str.Length) + 3), DateTime.Now.Millisecond.ToString());
  58.                                     Group NewGroup = new Group(NewNam, true);
  59.                                     NewGroup.Description = DateTime.Now.ToShortDateString();
  60.
  61.                                     ObjectIdCollection IDCol = new ObjectIdCollection(grp.GetAllEntityIds());
  62.                                     IdMapping IDMap = new IdMapping();
  63.                                     IDMap = database.DeepCloneObjects(IDCol, database.CurrentSpaceId, false);
  64.
  65.                                     foreach (IdPair pair in IDMap)
  66.                                     {
  67.                                         if (pair.IsPrimary)
  68.                                         {
  69.                                             Entity en = (Entity)trans.GetObject(pair.Value, OpenMode.ForRead);
  70.
  71.                                             en.UpgradeOpen();
  72.                                             en.TransformBy(MoveMat);
  73.                                             NewGroup.Append(en.ObjectId);
  74.                                             en.RecordGraphicsModified(true);
  75.                                             trans.TransactionManager.QueueForGraphicsFlush();
  76.                                             en.DowngradeOpen();
  77.
  78.                                         }
  79.                                     }
  80.                                     GrpDic.SetAt(NewNam, NewGroup);
  81.                                     trans.AddNewlyCreatedDBObject(NewGroup, false);
  82.                                     NewGroup.DowngradeOpen();
  83.                                     AcadDocument ADoc = (AcadDocument)document.AcadDocument;
  84.                                     AcadObject AO = ADoc.Dictionaries.Item("ACAD_GROUP");
  85.                                     IAcadGroups iags = (IAcadGroups)AO;
  86.                                     iags.Add(NewNam);
  87.                                     trans.Commit();
  88.                                     editor.WriteMessage("\nGroup < " + str + " > selected. ");
  89.                                 }
  90.                             }
  91.                             else
  92.                             {
  93.                                 editor.WriteMessage("\nMust be Group related. ");
  94.                             }
  95.                         }
  96.                     }
  97.                     else
  98.                     {
  99.                         editor.WriteMessage("\n *Cancelled* ");
  100.                     }
  101.                 }
  102.                 else
  103.                 {
  104.                     editor.WriteMessage("\nNothing Picked: *" + selection.Status.ToString() + "*");
  105.                 }
  106.             }
  107.             editor.WriteMessage("\n\nCommand:\n");
  108.             database.Dispose();
  109.         }
  110.
  111.         public Object GroupDisplacementPoint()
  112.         {
  113.             Document document = Application.DocumentManager.MdiActiveDocument;
  114.             Editor editor = document.Editor;
  115.             PromptPointOptions options2 = new PromptPointOptions("\nPick location point: ");
  116.             options2.AllowNone = false;
  117.             PromptPointResult point = editor.GetPoint(options2);
  118.
  119.             return point.Value;
  120.
  121.         }
  122.     }
  123. }
已领礼包: 859个
 楼主| 发表于 2014-5-2 19:57:30 来自手机 | 显示全部楼层
标记一下
GMT+8, 2026-11-3 07:33 , Processed in 0.440461 second(s), 30 queries , Gzip On.
