查看: 1774|回复: 1
[分享] Sorting an AutoCAD Point2dCollection or Point3dCollection using .NET
已领礼包: 1268个
发表于 2014-5-5 13:08:40 来自手机 | 显示全部楼层 |阅读模式
http://through-the-interface.typepad.com/through_the_interface/2011/01/sorting-an-autocad-point2dcollection-or-point3dcollection-using-net.html
已领礼包: 859个
发表于 2014-6-23 00:31:05 | 显示全部楼层
留存
Thanks to Virupaksha Aithal, from DevTech India, for providing the technical response to an ADN member than inspired this post.
When working with the Point2d and Point3d objects from AutoCAD’s .NET API it’s common to use the in-built collection types, Point2dCollection and Point3dCollection. Neither of these objects provides the capability to sort their contents (and, in any case, sorting would mean different things to different people when it comes to containers of objects with multiple data entries).
So how can you sort one of these collections?
The answer is fairly straightforward: you convert them to a .NET array, sort them using standard .NET capabilities and then recreate an AutoCAD collection.
The below C# code does this for collections of both Point2d and Point3d objects.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using System.Collections.Generic;
using System;
namespace PointSort
  internal class sort2dByX : IComparer<Point2d>
    public static bool IsZero(double a)
      return Math.Abs(a) < Tolerance.Global.EqualPoint;
    public static bool IsEqual(double a, double b)
      return IsZero(b - a);
    public int Compare(Point2d a, Point2d b)
      if (IsEqual(a.X, b.X)) return 0; // ==
      if (a.X < b.X) return -1; // <
      return 1; // >
  internal class sort3dByX : IComparer<Point3d>
    public int Compare(Point3d a, Point3d b)
      return 1; // >
  public class Commands
    private double DeNormalize(double a, double max)
      // Random numbers are from 0 to 1.0, so we
      // multiply it out to be within our range
      // (this will create a value from -max to max)
      return (2 * a - 1) * max;
    public Point2d Random2dPoint(Random rnd, double max)
      double x = rnd.NextDouble(),
            y = rnd.NextDouble();
      return new Point2d(
        DeNormalize(x, max),
        DeNormalize(y, max)
    public Point3d Random3dPoint(Random rnd, double max)
            y = rnd.NextDouble(),
            z = rnd.NextDouble();
      return new Point3d(
        DeNormalize(y, max),
        DeNormalize(z, max)
    public Point2dCollection Random2dPoints(int num, double max)
      Point2dCollection pts = new Point2dCollection(num);
      Random rnd = new Random();
      for (int i = 0; i < num; i++)
        pts.Add(Random2dPoint(rnd, max));
      return pts;
    public Point3dCollection Random3dPoints(int num, double max)
      Point3dCollection pts = new Point3dCollection();
        pts.Add(Random3dPoint(rnd, max));
      return pts;
    public void PrintPoints(Editor ed, Point2dCollection pts)
      foreach (Point2d pt in pts)
        ed.WriteMessage("{0}\n", pt);
    public void PrintPoints(Editor ed, Point3dCollection pts)
      foreach (Point3d pt in pts)
    [CommandMethod("PTS")]
    public void PointSort()
      Document doc =
          Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Point2dCollection pts2d = Random2dPoints(20, 1000.0);
      Point2d[] raw = pts2d.ToArray();
      Array.Sort(raw, new sort2dByX());
      Point2dCollection sorted2d = new Point2dCollection(raw);
      ed.WriteMessage("\n2D points before sort:\n\n");
      PrintPoints(ed, pts2d);
      ed.WriteMessage("\n\n2D points after sort:\n\n");
      PrintPoints(ed, sorted2d);
      Point3dCollection pts3d = Random3dPoints(20, 1000.0);
      Point3d[] raw3d = new Point3d[pts3d.Count];
      pts3d.CopyTo(raw3d, 0);
      Array.Sort(raw3d, new sort3dByX());
      Point3dCollection sorted3d = new Point3dCollection(raw3d);
      ed.WriteMessage("\n3D points before sort:\n\n");
      PrintPoints(ed, pts3d);
      ed.WriteMessage("\n\n3D points after sort:\n\n");
      PrintPoints(ed, sorted3d);
  Some notes on this implementation:
  • For the purposes of this example, we’re assuming “sorting” means to sort on the X value of each point
    • It should be obvious how to change the implementation to use different sort criteria
  • To test the sorting, we’re populating the collections with a set of randomly-generated points
    • We create 20 points in each collection, each with coordinates in the range of –1000 to 1000
    • I’ve kept the number of points in each collection low, just to keep the post to a reasonable length and still be able to include the results
  • Converting to a .NET array is a little different for 2D and 3D collections
    • Point2dCollection has the ToArray() method
    • Point3dCollection has the CopyTo() method
Something I will say about the above code... It’s code like this that makes me yearn for a more dynamic environment (I’m writing this in “classic”, statically-typed C#). There are several duplicate classes with basically the same implementation but taking different types: plenty of code that just feels redundant.
It would be interesting to rework this IronPython, to see what that it brings (or even to see if using the dynamic keyword would help – I should really install VS 2010 and give it a try). This is also exactly the kind of problem that F# excels at solving, so I’ll expect I’ll be giving that a try, too, before too long, just to see how much code can be ripped out.
Here are some sample results from  running the PTS command:
Command: PTS
(546.62044884014,333.683370302284)
(273.865409788613,671.008432130799)
(786.237089795171,-664.37283328938)
(-951.588503062533,-221.942868652727)
(-362.490728200642,-93.6347987007512)
(-938.590817124858,-889.46122764119)
(628.55356355596,-180.880018128492)
(485.986099339084,329.109809980313)
(525.820961001246,-659.813289372164)
(-902.095012321181,-931.107034874664)
(683.452251219867,931.710177069395)
(110.748492698534,-899.346025613763)
(47.6774876227963,-794.155224130561)
(-993.500254113926,438.08932389975)
(994.927220044158,-722.431948279232)
(198.020555636855,462.94129894252)
(-693.78015850381,-930.635690656787)
(-330.415913523369,497.267734025264)
(-855.102567866027,951.917634323201)
(520.609316192851,-779.07530860001)
(-282.271111981138,909.546242053409,285.631638618946)
(371.393521023632,762.584686168742,-119.380790330181)
(386.957248387373,-908.643945077734,648.815548815213)
(494.069362754966,93.28737999,323.425575775758)
(494.450510244095,586.600064107496,680.753123797827)
(489.99652056489,712.608007580325,660.061542717768)
(132.996848380657,-910.9989078301,-602.627639473708)
(564.335921576403,-454.319581135325,78.9875290724391)
(276.740193961533,837.884722202031,922.783010603293)
(-314.830172487921,370.544476141475,-925.548076594969)
(865.08049995875,-543.389787684842,101.277599624022)
(-267.499718473991,616.808070622761,558.13882665622)
(-782.131620581323,-289.302226756374,373.464381961834)
(832.297310155024,-629.765324122163,523.183570021383)
(614.174030541523,-112.834495079161,366.034026893803)
(-234.866094419205,43.4879246370345,265.665525228561)
(-255.009830582426,195.9628114458,-851.765022544081)
(374.128198891007,532.42736753655,-900.2289231402)
(-385.354406845455,153.392966442459,363.865823188734)
(-793.355890453493,-905.346672937901,924.69996396671)
  Update
Thanks to Dan Smith for provide a refactored version of the code: if you use multiple inheritance – in the case of our “comparer” classes – and generics/LINQ – in the case of the point generation piece – then it’s certainly possible to factor out the redundant code in good old C#. (You will have to target .NET Framework 3.5 or higher to get this to build.)
using System.Linq;
using System;
namespace PointSort
  internal class sortByX
    protected static bool IsZero(double a)
    protected static bool IsEqual(double a, double b)
    protected int Compare(double aX, double bX)
      if (IsEqual(aX, bX)) return 0; // ==
      if (aX < bX) return -1; // <
      return 1; // >
  internal class sort2dByX : sortByX, IComparer<Point2d>
      return base.Compare(a.X, b.X);
  internal class sort3dByX : sortByX, IComparer<Point3d>
      return new Point2d(
        DeNormalize(y, max)
      return new Point3d(
        DeNormalize(z, max)
    TPoint[] RandomPoints<TPoint>(
      int num, double max, Func<Random, double, TPoint> generator
      var pts = new TPoint[num];
      var rnd = new Random();
        pts = generator(rnd, max);
      return pts;
      var pts = RandomPoints<Point2d>(num, max, Random2dPoint);
      return new Point2dCollection(pts);
      var pts = RandomPoints<Point3d>(num, max, Random3dPoint);
      return new Point3dCollection(pts);
      Document doc =
  It’s still more verbose than I’d like, given the relatively low complexity of the problem, so I’ll still give IronPython and F# a go to see how they compare, when I get the chance.
GMT+8, 2026-11-3 10:39 , Processed in 0.484727 second(s), 30 queries , Gzip On.
