查看: 1439|回复: 0
[分享] Striking an enclosed text area in AutoCAD using .NET
已领礼包: 859个
发表于 2014-5-9 12:26:20 来自手机 | 显示全部楼层 |阅读模式
封闭区域点一点标注面积
http://www.tuicool.com/articles/VjQRjyZI’m still on pseudo-vacation. We really had a great week in the snow: sun during the day (everyday!) with the odd bit of fresh snow overnight on a couple of occasions. It’s snowing again now, but unfortunately this time it’s set to snow all the way through to the end of the day tomorrow, so it’s quite possible we’ll head home a little earlier than expected. Which, on the plus side, will allow me to do some prep-work for Monday’s Geneva Motor Show project installation.
Anyway, all this to say that I’ve written this post really quickly with plenty of shortcuts. Alex Fielder pinged me earlier with a requirement he has, and – given the other things going on – I thought I’d start with something quick and dirty.
Happy Friday! @keanw am wondering what approach to take WRT inserting crossing lines like this in Paperspace: pic.twitter.com/Ss2BDX8dPn
— Alex Fielder (@AlexFielder) February 28, 2014
Consider this a classic strawman implementation that’s designed to stimulate user feedback: it probably doesn’t come close to meeting Alex’s needs, but then it gives him some tyres to kick and say what’s working or not.
The various “issues” I have with the implementation are listed in the comments in this simple C# code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace StrikeText
  public class Commands
    [ CommandMethod ( "STXT" )]
    public static void StrikeTextArea()
      var doc =
        Application .DocumentManager.MdiActiveDocument;
      var db = doc.Database;
      var ed = doc.Editor;
      // Ask for a point. Could also ask for an enclosed text entity
      // and use the picked point or the text's insertion point
      var ppo = new PromptPointOptions ( "\nSelect point" );
      var ppr = ed.GetPoint(ppo);
      if (ppr.Status != PromptStatus .OK)
        return ;
      using ( var tr = db.TransactionManager.StartTransaction())
        // Use Editor.TraceBoundary() to check for a suitable
        // boundary. This may throw up a dialog, if selecting a
        // space inside a table, for instance (before you explode
        // it manually). Not ideal - it basically uses the same
        // code path as BHATCH or BOUNDARY, which includes a dialog
        var oc = ed.TraceBoundary(ppr.Value, false );
        // Only deal with the case where we get a single entity
        // returned
        if (oc.Count == 1)
          var ent = oc[0] as Entity ;
          if (ent != null )
            // Get the extents of the entity and determine points
            // at the top left and bottom right corners. This is
            // super-simplistic: will only work if we're dealing
            // with a WCS-aligned area. More work needed if dealing
            // with areas with other alignments
            var ext = ent.GeometricExtents;
            var pt1 = new Point3d (ext.MinPoint.X, ext.MaxPoint.Y, 0);
            var pt2 = new Point3d (ext.MaxPoint.X, ext.MinPoint.Y, 0);
            // Create a line between these points
            var ln = new Line (pt1, pt2);
            // Add it to the current space
            var btr =
              ( BlockTableRecord )tr.GetObject(
                db.CurrentSpaceId, OpenMode .ForWrite
            btr.AppendEntity(ln);
            tr.AddNewlyCreatedDBObject(ln, true );
        // Commit even if we didn't add anything
        tr.Commit();
When you run the STXT command and selecting a point in an enclosed area, it should strike it through from top-left to bottom-right. Providing the various assumptions mentioned in the code are true, of course.
GMT+8, 2026-11-3 07:36 , Processed in 0.407415 second(s), 28 queries , Gzip On.
