查看: 3093|回复: 3
[分享] EntLast EntNext
已领礼包: 859个
发表于 2014-5-10 18:46:52 来自手机 | 显示全部楼层 |阅读模式
http://www.theswamp.org/index.php?topic=37409.50;wap2
I'd guess that your translation may be skewey.
Can you post the VB.net code you used for each or post he solution zipped so I can test it here.
huiz:
I thought they did work in C# but unfortunately not in vb. Here are the examples in vb:
--- Code: ---<CommandMethod("InsDXF7")> _
Public Sub InsDXF7()
        Dim doc As Document = AcadApp.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        Dim tmpDb As New Database(False, True)
        tmpDb.DxfIn("K:\ToTest\Squircle.dxf", "K:\ToTest\Squircle.log")
        Dim pnt1 As New Point3d(0, 0, 0)
        Dim pnt2 As New Point3d(1000, 1000, 0)
        Dim scale As Double = 10.0
        Dim vector As New Vector3d(0, 0, 0)
        Dim transform As Matrix3d = Matrix3d.Scaling(scale, pnt2) * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2))
        Dim lastEnt As ObjectId = AcUtils.EntLast()
        Dim newColor As Autodesk.AutoCAD.Colors.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 1)
        db.Insert(transform, tmpDb, True)
        Using tr As Transaction = doc.TransactionManager.StartTransaction()
        ' if the db was empty lastent will be null
        Try
        If lastEnt = ObjectId.Null Then
        lastEnt = AcUtils.EntFirst()
        idColl.Add(lastEnt)
        End If
        Dim nextent As ObjectId = AcUtils.EntNext(lastEnt)
        While nextent <> ObjectId.Null
        idColl.Add(nextent)
        nextent = AcUtils.EntNext(nextent)
        End While
        For Each id As ObjectId In idColl
        Dim acEntity As Entity = DirectCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
        acEntity.Color = newColor
        Next
        Catch exx As Autodesk.AutoCAD.Runtime.Exception
        ed.WriteMessage(vbLf & exx.ToString())
        End Try
        tr.Commit()
        End Using
End Sub
--- End code ---
--- Code: ---<CommandMethod("InsDXF8")> _
Public Sub InsDXF8()
        Dim idColl As New ObjectIdCollection()
        Try
        acEntity = DirectCast(tr.GetObject(lastEnt, OpenMode.ForWrite), Entity)
        End If
        acEntity = DirectCast(tr.GetObject(nextent, OpenMode.ForWrite), Entity)
        End While
        End Try
        tr.Commit()
        End Using
End Sub
--- End code ---
--- Code: ---<CommandMethod("InsDXF9")> _
Public Sub InsDXF9()
        Using tr As Transaction = tmpDb.TransactionManager.StartTransaction()
        Try
        Dim tmpDbBlockTable As BlockTable = DirectCast(tr.GetObject(tmpDb.BlockTableId, OpenMode.ForRead), BlockTable)
        Dim tmpDbModelSpace As BlockTableRecord = DirectCast(tr.GetObject(tmpDbBlockTable(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
        For Each id As ObjectId In tmpDbModelSpace
        acEntity = DirectCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
        Next
        tr.Commit()
        End Try
        End Using
End Sub
--- End code ---
Kerry:
Give these a run ...
(Code solution .ZIP attached)
--- Code: ---
Option Explicit On
Option Strict On
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Colors
Imports Utils = Autodesk.AutoCAD.Internal.Utils
<Assembly: CommandClass(GetType(InsertDXF.MyCommands))>
Namespace InsertDXF
    Public Class MyCommands
   '' < snip >
    End Class
End Namespace
--- End code ---
--- Code: ---
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            tmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\ToTest\\Squircle.log")
            Dim transform As Matrix3d = (Matrix3d.Scaling(scale, pnt2) _
                                         * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2)))
            Dim lastEnt As ObjectId = Utils.EntLast
            Dim newColor As Color = Color.FromColorIndex(ColorMethod.ByAci, 1)
                Try
                    If (lastEnt = ObjectId.Null) Then
                        lastEnt = Utils.EntFirst
                        idColl.Add(lastEnt)
                    End If
                    Dim nextent As ObjectId = Utils.EntNext(lastEnt)
                    Do While (nextent <> ObjectId.Null)
                        idColl.Add(nextent)
                        nextent = Utils.EntNext(nextent)
                    Loop
                    Dim id As ObjectId
                    For Each id In idColl
                        Dim acEntity As Entity = DirectCast(tr.GetObject( _
                    Next
                    ed.WriteMessage((ChrW(10) & exx.ToString))
                End Try
                tr.Commit()
            End Using
        End Sub
--- End code ---
--- Code: ---
            tmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\\ToTest\\Squircle.log")
                Try
                        acEntity = DirectCast(tr.GetObject( _
                    End If
                    Loop
                End Try
                tr.Commit()
            End Using
        End Sub
--- End code ---
--- Code: ---
            tmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\\ToTest\Squircle.log")
            Dim tr As Transaction = tmpDb.TransactionManager.StartTransaction
            Try
                Dim tmpDbBlockTable As BlockTable = DirectCast(tr.GetObject( _
                Dim tmpDbModelSpace As BlockTableRecord = DirectCast(tr.GetObject( _
                        tmpDbBlockTable.Item(BlockTableRecord.ModelSpace), _
                Dim id As ObjectId
                For Each id In tmpDbModelSpace
                Next
                tr.Commit()
            Finally
                If (Not tr Is Nothing) Then
                    tr.Dispose()
                End If
            End Try
        End Sub
--- End code ---
kaefer:
--- Quote from: Kerry on March 29, 2011, 02:35:49 am ---
--- Code: ---Option Explicit On
Option Strict On
--- End code ---
--- End quote ---
Does the culprit sit right here?
Cheers, Thorsten (missing bargepole, won't do VB)
Kerry:
--- Quote from: kaefer on March 29, 2011, 03:18:43 am ---
Option Strict On
--- End code ---
--- End quote ---
--- End quote ---
Don't know Thorsten, but it didn't seen correct to me to code with them off .... but that's probably just me :)
I've decided I need to at least be able to read VB and write a little ... as much as I hate the Dim word  :-P
已领礼包: 1632个
财富等级: 堆金积玉
发表于 2014-5-10 19:21:47 | 显示全部楼层
以下是原贴中的VB代码
  1.         Public Sub InsDXF7()
  2.             Dim doc As Document = Application.DocumentManager.MdiActiveDocument
  3.             Dim ed As Editor = doc.Editor
  4.             Dim db As Database = doc.Database
  5.             Dim tmpDb As New Database(False, True)
  6.             tmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\ToTest\\Squircle.log")
  7.             Dim pnt1 As New Point3d(0, 0, 0)
  8.             Dim pnt2 As New Point3d(1000, 1000, 0)
  9.             Dim scale As Double = 10
  10.             Dim vector As New Vector3d(0, 0, 0)
  11.             Dim transform As Matrix3d = (Matrix3d.Scaling(scale, pnt2) _
  12.                                          * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2)))
  13.             Dim idColl As New ObjectIdCollection
  14.             Dim lastEnt As ObjectId = Utils.EntLast
  15.             Dim newColor As Color = Color.FromColorIndex(ColorMethod.ByAci, 1)
  16.             db.Insert(transform, tmpDb, True)
  17.             Using tr As Transaction = doc.TransactionManager.StartTransaction
  18.                 Try
  19.                     If (lastEnt = ObjectId.Null) Then
  20.                         lastEnt = Utils.EntFirst
  21.                         idColl.Add(lastEnt)
  22.                     End If
  23.                     Dim nextent As ObjectId = Utils.EntNext(lastEnt)
  24.                     Do While (nextent <> ObjectId.Null)
  25.                         idColl.Add(nextent)
  26.                         nextent = Utils.EntNext(nextent)
  27.                     Loop
  28.                     Dim id As ObjectId
  29.                     For Each id In idColl
  30.                         Dim acEntity As Entity = DirectCast(tr.GetObject( _
  31.                                 id, OpenMode.ForWrite), Entity)
  32.                         acEntity.Color = newColor
  33.                     Next
  34.                 Catch exx As Autodesk.AutoCAD.Runtime.Exception
  35.                     ed.WriteMessage((ChrW(10) & exx.ToString))
  36.                 End Try
  37.                 tr.Commit()
  38.             End Using
  39.         End Sub
回复 支持 1 反对 0
已领礼包: 1632个
财富等级: 堆金积玉
发表于 2014-5-10 19:18:33 | 显示全部楼层
将楼上原贴其中一个例子的VB代码转成了C#代码, 现贴出来以便大家学习.
  1. public void InsDXF7()
  2. {
  3.   Document doc = AcadApp.DocumentManager.MdiActiveDocument;
  4.   Editor ed = doc.Editor; Database db = doc.Database;
  5.   Database tmpDb = new Database(false, true);
  6.   tmpDb.DxfIn("K:\\ToTest\\Squircle.dxf", "K:\\ToTest\\Squircle.log");
  7.   Point3d pnt1 = new Point3d(0, 0, 0);
  8.   Point3d pnt2 = new Point3d(1000, 1000, 0);
  9.   double scale = 10.0;
  10.   Vector3d vector = new Vector3d(0, 0, 0);
  11.   Matrix3d transform = Matrix3d.Scaling(scale, pnt2) * Matrix3d.Displacement(pnt1.GetVectorTo(pnt2));
  12.   ObjectId lastEnt = AcUtils.EntLast();
  13.   Autodesk.AutoCAD.Colors.Color newColor = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 1);
  14.   db.Insert(transform, tmpDb, true);
  15.   using (Transaction tr = doc.TransactionManager.StartTransaction())
  16.    {
  17.            try
  18.     {
  19.       if (lastEnt == ObjectId.Null)
  20.       {
  21.         lastEnt = AcUtils.EntFirst();
  22.         idColl.Add(lastEnt);
  23.       }
  24.       ObjectId nextent = AcUtils.EntNext(lastEnt);
  25.       while (nextent != ObjectId.Null)
  26.       {
  27.         idColl.Add(nextent);
  28.         nextent = AcUtils.EntNext(nextent);
  29.       }
  30.       foreach (ObjectId id in idColl)
  31.       {
  32.         Entity acEntity = (Entity)tr.GetObject(id, OpenMode.ForWrite);
  33.         acEntity.Color = newColor;
  34.       }
  35.     }
  36.     catch (Autodesk.AutoCAD.Runtime.Exception exx)
  37.     {
  38.       ed.WriteMessage(Constants.vbLf + exx.ToString());
  39.     }
  40.     tr.Commit();
  41.   }
  42. }
赞一个,省得我再了解VB.NET了  详情 回复 发表于 2014-5-10 19:40
已领礼包: 859个
 楼主| 发表于 2014-5-10 19:40:13 来自手机 | 显示全部楼层
赞一个,省得我再了解VB.NET了
GMT+8, 2026-11-3 07:35 , Processed in 0.446414 second(s), 39 queries , Gzip On.
