查看: 2062|回复: 0
[分享] Displaying a progress meter during long operations in AutoCAD using .NET
已领礼包: 859个
发表于 2014-5-11 17:00:28 来自手机 | 显示全部楼层 |阅读模式
http://through-the-interface.typepad.com/through_the_interface/2007/05/displaying_a_pr.html
It's often desirable to show a progress meter during lengthy operations. Although there's currently no public API to make use of AutoCAD's progress meter from .NET, there are nevertheless a couple of approaches to doing so.
In this post I'll show how to do this using P/Invoke (using some code borrowed from Fenton Webb, from DevTech Americas) and in my next post I'll show how to use the "internal" AutoCAD managed assembly.
Here's the C# code that uses P/Invoke, which should work for AutoCAD 2007 and 2008:
using Autodesk.AutoCAD.Runtime;
using System.Runtime.InteropServices;
using System.Windows.Forms;
namespace ProgressMeterTest
  public class Cmds
    [DllImport(
      "acad.exe",
      CharSet = CharSet.Auto,
      CallingConvention = CallingConvention.Cdecl,
      EntryPoint = "?acedSetStatusBarProgressMeter@@YAHPB_WHH@Z"
      //This should work for AutoCAD 2006...
      //EntryPoint = "?acedSetStatusBarProgressMeter@@YAHPBDHH@Z"
    private static extern int
      acedSetStatusBarProgressMeter(
        string label,
        int minPos,
        int maxPos
    [DllImport(
      "acad.exe",
      EntryPoint = "?acedSetStatusBarProgressMeterPos@@YAHH@Z"
      acedSetStatusBarProgressMeterPos(int pos);
    [DllImport(
      "acad.exe",
      EntryPoint = "?acedRestoreStatusBar@@YAXXZ"
    private static extern int acedRestoreStatusBar();
    [CommandMethod("PB")]
    public void ProgressBar()
      acedSetStatusBarProgressMeter("Testing Progress Bar", 0, 100);
      for (int i = 0; i <= 100; i++)
        for (int j = 0; j <= 10; j++)
          System.Threading.Thread.Sleep(1);
          acedSetStatusBarProgressMeterPos(i);
          // This allows AutoCAD to repaint
          Application.DoEvents();
And here's what you see when it runs:
Update:
Thanks to Chris Bray for pointing out the above technique (and the one I was about to show in Part 2) is unnecessary from AutoCAD 2007 onwards. A new class was introduced in AutoCAD 2007 called Autodesk.AutoCAD.Runtime.ProgressMeter.
Here's some C# code that demonstrates the use of this class:
  public class Cmds
    public void ProgressBarManaged()
      ProgressMeter pm = new ProgressMeter();
      pm.Start("Testing Progress Bar");
      pm.SetLimit(100);
      // Now our lengthy operation
        System.Threading.Thread.Sleep(5);
        // Increment Progress Meter...
        pm.MeterProgress();
      pm.Stop();
The original code is still the technique to use for AutoCAD 2005 & 2006, although you will need to uncomment the line in the DllImport attribute for acedSetStatusBarProgressMeter(), to make sure it uses the EntryPoint with the non-Unicode string argument ("?acedSetStatusBarProgressMeter@@YAHPBDHH@Z"). You'll clearly also need to comment out the current EntryPoint assignment, of course.
I'll forego the Part 2 post (and rename this one from Part 1), as there's really no need to look any other technique for this, at this stage.
GMT+8, 2026-11-3 06:18 , Processed in 0.497976 second(s), 31 queries , Gzip On.
