查看: 2080|回复: 0
[分享] Creating a multileader in AutoCAD using a jig from .NET
已领礼包: 859个
发表于 2014-5-11 17:23:01 来自手机 | 显示全部楼层 |阅读模式
http://through-the-interface.typepad.com/through_the_interface/2007/09/creating-a-mult.html
I'm now back from a fantastic break in Italy and am trying hard to catch back up. Next week I'm off again to San Diego (work, this time), which may cause further interruptions in blog postings.
This question came through from Genésio from Brazil:
I wish jig a leader with an bubble in the and of the leader, at the same time. Can you help me. Perhaps post the solution in your blog (through the interface).
It took me a while - frustratingly long, in fact, and probably this is not exactly what Genésio is after - but here's what I managed to come up with. The "bubble" is framed MText, but it should be modifiable to use a classic bubble block, instead. I drew heavily on this previous post for the jig code.
The positioning of the text took some work, but I'm reasonably happy with the results. If anyone has tweaks to suggest, please post a comment.
Here's the C# code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
namespace DimensionLibrary
  public class DimensionCmds
    class MLeaderJig : EntityJig
      Point3dCollection m_pts;
      Point3d m_tempPoint;
      string m_contents;
      int m_leaderIndex;
      int m_leaderLineIndex;
      public MLeaderJig(string contents)
        : base(new MLeader())
        // Store the string passed in
        m_contents = contents;
        // Create a point collection to store our vertices
        m_pts = new Point3dCollection();
        // Create mleader and set defaults
        MLeader ml = Entity as MLeader;
        ml.SetDatabaseDefaults();
        // Set up the MText contents
        ml.ContentType = ContentType.MTextContent;
        MText mt = new MText();
        mt.SetDatabaseDefaults();
        mt.Contents = m_contents;
        ml.MText = mt;
        ml.TextAlignmentType =
          TextAlignmentType.LeftAlignment;
        ml.TextAttachmentType =
          TextAttachmentType.AttachmentMiddle;
        // Set the frame and landing properties
        ml.EnableDogleg = true;
        ml.EnableFrameText = true;
        ml.EnableLanding = true;
        // Reduce the standard landing gap
        ml.LandingGap = 0.05;
        // Add a leader, but not a leader line (for now)
        m_leaderIndex = ml.AddLeader();
        m_leaderLineIndex = -1;
      protected override SamplerStatus Sampler(
        JigPrompts prompts
        JigPromptPointOptions opts =
          new JigPromptPointOptions();
        // Not all options accept null response
        opts.UserInputControls =
          (UserInputControls.Accept3dCoordinates |
          UserInputControls.NoNegativeResponseAccepted
        // Get the first point
        if (m_pts.Count == 0)
          opts.UserInputControls |=
            UserInputControls.NullResponseAccepted;
          opts.Message =
            "\nStart point of multileader: ";
          opts.UseBasePoint = false;
        // And the second
        else if (m_pts.Count == 1)
          opts.BasePoint = m_pts[m_pts.Count - 1];
          opts.UseBasePoint = true;
          opts.Message =
            "\nSpecify multileader vertex: ";
        // And subsequent points
        else if (m_pts.Count > 1)
          opts.SetMessageAndKeywords(
            "\nSpecify multileader vertex or [End]: ",
            "End"
        else // Should never happen
          return SamplerStatus.Cancel;
        PromptPointResult res =
          prompts.AcquirePoint(opts);
        if (res.Status == PromptStatus.Keyword)
          if (res.StringResult == "End")
        if (m_tempPoint == res.Value)
          return SamplerStatus.NoChange;
        else if (res.Status == PromptStatus.OK)
          m_tempPoint = res.Value;
          return SamplerStatus.OK;
      protected override bool Update()
        try
          if (m_pts.Count > 0)
            // Set the last vertex to the new value
            ml.SetLastVertex(
              m_leaderLineIndex,
              m_tempPoint
            // Adjust the text location
            Vector3d dogvec =
              ml.GetDogleg(m_leaderIndex);
            double doglen =
              ml.DoglegLength;
            double landgap =
              ml.LandingGap;
            ml.TextLocation =
              m_tempPoint +
              ((doglen + landgap) * dogvec);
        catch (System.Exception ex)
          Document doc =
            Application.DocumentManager.MdiActiveDocument;
          doc.Editor.WriteMessage(
            "\nException: " + ex.Message
          return false;
        return true;
      public void AddVertex()
        // For the first point...
          // Add a leader line
          m_leaderLineIndex =
            ml.AddLeaderLine(m_leaderIndex);
          // And a start vertex
          ml.AddFirstVertex(
            m_leaderLineIndex,
            m_tempPoint
          // Add a second vertex that will be set
          // within the jig
          ml.AddLastVertex(
            m_leaderLineIndex,
            new Point3d(0, 0, 0)
        else
          // For subsequent points,
          // just add a vertex
          ml.AddLastVertex(
            m_leaderLineIndex,
            m_tempPoint
        // Reset the attachment point, otherwise
        // it seems to get forgotten
        // Add the latest point to our history
        m_pts.Add(m_tempPoint);
      public void RemoveLastVertex()
        // We don't need to actually remove
        // the vertex, just reset it
        if (m_pts.Count >= 1)
          Vector3d dogvec =
          double doglen =
            ml.DoglegLength;
          double landgap =
            ml.LandingGap;
          ml.TextLocation =
            m_pts[m_pts.Count - 1] +
      public Entity GetEntity()
        return Entity;
    [CommandMethod("MYML")]
    public void MyMLeaderJig()
      Document doc =
      Editor ed = doc.Editor;
      Database db = doc.Database;
      // Get the text outside of the jig
      PromptStringOptions pso =
        new PromptStringOptions(
          "\nEnter text: "
      pso.AllowSpaces = true;
      PromptResult pr =
        ed.GetString(pso);
      if (pr.Status == PromptStatus.OK)
        // Create MleaderJig
        MLeaderJig jig =
          new MLeaderJig(pr.StringResult);
        // Loop to set vertices
        bool bSuccess = true, bComplete = false;
        while (bSuccess && !bComplete)
          PromptResult dragres = ed.Drag(jig);
          bSuccess =
            (dragres.Status == PromptStatus.OK);
          if (bSuccess)
            jig.AddVertex();
          bComplete =
            (dragres.Status == PromptStatus.None);
          if (bComplete)
            jig.RemoveLastVertex();
        if (bComplete)
          // Append entity
          Transaction tr =
            db.TransactionManager.StartTransaction();
          using (tr)
            BlockTable bt =
              (BlockTable)tr.GetObject(
                db.BlockTableId,
                OpenMode.ForRead,
                false
            BlockTableRecord btr =
              (BlockTableRecord)tr.GetObject(
                bt[BlockTableRecord.ModelSpace],
                OpenMode.ForWrite,
                false
            btr.AppendEntity(jig.GetEntity());
            tr.AddNewlyCreatedDBObject(
              jig.GetEntity(),
              true
            tr.Commit();
Here's what you get when you run the MYML command:
You might also like:
GMT+8, 2026-11-3 04:02 , Processed in 0.482430 second(s), 28 queries , Gzip On.
