查看: 1693|回复: 0
[分享] 带关键字的SSget
已领礼包: 859个
发表于 2014-5-15 09:23:21 | 显示全部楼层 |阅读模式
  1.         private string keyWord;
  2.         [CommandMethod("myTest")]
  3.         public void Test()
  4.             {
  5.             Editor ed = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument.Editor;
  6.             keyWord = "LIne";
  7.             PromptSelectionOptions opt = new PromptSelectionOptions();
  8.             opt.SetKeywords("[CIrcle/LIne/POlyline]", "CIrcle LIne POlyline");
  9.             opt.MessageForAdding = "\nSelect objects or " + opt.Keywords.GetDisplayString(true);
  10.             opt.KeywordInput += onKeywordInput;
  11.             ed.SelectionAdded += onSelectionAdded;
  12.             PromptSelectionResult psr = ed.GetSelection(opt);
  13.             ed.SelectionAdded -= onSelectionAdded;
  14.             if (psr.Status == PromptStatus.OK)
  15.                 ed.SetImpliedSelection(psr.Value);
  16.             }
  17.         private void onKeywordInput(object sender, SelectionTextInputEventArgs e)
  18.             {
  19.                 this.keyWord = e.Input;
  20.             }
  21.         private void onSelectionAdded(object sender, SelectionAddedEventArgs e)
  22.             {
  23.             RXClass rxc;
  24.             switch (this.keyWord)
  25.                     {
  26.                     case "POlyline":
  27.                         rxc = RXClass.GetClass(typeof(Polyline));
  28.                         break;
  29.                     case "CIrcle":
  30.                         rxc = RXClass.GetClass(typeof(Circle));
  31.                         break;
  32.                     default:
  33.                         rxc = RXClass.GetClass(typeof(Line));
  34.                         break;
  35.                 }
  36.                 ObjectId[] ids = e.AddedObjects.GetObjectIds();
  37.                 for (int i = 0; i < ids.Length; i++)
  38.                 {
  39.                     if (ids[i].ObjectClass != rxc)
  40.                     {
  41.                         e.Remove(i);
  42.                     }
  43.                 }
  44.             }
GMT+8, 2026-11-3 04:04 , Processed in 0.459317 second(s), 28 queries , Gzip On.
