查看: 1265|回复: 0
[分享] Testing whether a point is on an AutoCAD polyline using .NET
已领礼包: 859个
发表于 2014-5-16 08:02:04 | 显示全部楼层 |阅读模式
Occasionally I come across a topic that I’m sure I’ve addressed in a previous post, but for the life of me I can’t track it down. The code in a recent response by Balaji Ramamoorthy, from the DevTech India team, fits firmly into this category: it shows how to iterate through a polyline’s segments, testing whether a point is on the polyline.
I did some refactoring of Balaji’s code to extract it into a helper function (although not an extension method, which people who use them may prefer), but otherwise this C# code is basically his.
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Geometry;
  5. using Autodesk.AutoCAD.Runtime;
  6. namespace PolylineTesting
  7. {
  8.   public class Commands
  9.   {
  10.     [CommandMethod("POP")]
  11.     public void PointOnPolyline()
  12.     {
  13.       Document doc =
  14.         Application.DocumentManager.MdiActiveDocument;
  15.       Database db = doc.Database;
  16.       Editor ed = doc.Editor;
  17.       PromptEntityOptions peo =
  18.         new PromptEntityOptions("\nSelect a polyline");
  19.       peo.SetRejectMessage("Please select a polyline");
  20.       peo.AddAllowedClass(typeof(Polyline), true);
  21.       PromptEntityResult per = ed.GetEntity(peo);
  22.       if (per.Status != PromptStatus.OK)
  23.         return;
  24.       PromptPointResult ppr = ed.GetPoint("\nSelect a point");
  25.       if (ppr.Status != PromptStatus.OK)
  26.         return;
  27.       Transaction tr = db.TransactionManager.StartTransaction();
  28.       using (tr)
  29.       {
  30.         Polyline polyline =
  31.           tr.GetObject(per.ObjectId, OpenMode.ForRead) as Polyline;
  32.         if (polyline != null)
  33.         {
  34.           bool isOn = IsPointOnPolyline(polyline, ppr.Value);
  35.           ed.WriteMessage(
  36.             "\nSelected point is {0}on the polyline.",
  37.             isOn ? "" : "not "
  38.           );
  39.         }
  40.         tr.Commit();
  41.       }
  42.     }
  43.     private bool IsPointOnPolyline(Polyline pl, Point3d pt)
  44.     {
  45.       bool isOn = false;
  46.       for (int i = 0; i < pl.NumberOfVertices; i++)
  47.       {
  48.         Curve3d seg = null;
  49.         SegmentType segType = pl.GetSegmentType(i);
  50.         if (segType == SegmentType.Arc)
  51.           seg = pl.GetArcSegmentAt(i);
  52.         else if (segType == SegmentType.Line)
  53.           seg = pl.GetLineSegmentAt(i);
  54.         if (seg != null)
  55.         {
  56.           isOn = seg.IsOn(pt);
  57.           if (isOn)
  58.             break;
  59.         }
  60.       }
  61.       return isOn;
  62.     }
  63.   }
  64. }
When you run the POP command and select a polyline and a point, you’ll see a message on the command-line indicating whether the latter is on the former
[url]http://through-the-interface.typepad.com/through_the_interface/2012/01/testing-whether-a-point-is-on-an-autocad-polyline-using-net.html[/url]
GMT+8, 2026-11-3 06:07 , Processed in 0.431557 second(s), 28 queries , Gzip On.
