查看: 3026|回复: 2
[教学] API应用 选择首尾连接线
发表于 2014-5-17 09:28:06 | 显示全部楼层 |阅读模式
  1. (defun c:tt (/ e d ss lst outlst len p1 p2 s)
  2.   (if (not **GlobleFuzz**)
  3.     (setq **GlobleFuzz** 0.01)
  4.   )
  5.   (if (and (setq e (car        (xdrx_entsel
  6.                           "\n拾取起始线: "
  7.                           '((0 . "*line,arc,circle,ellipse"))
  8.                         )
  9.                    )
  10.            )
  11.            (if (setq d
  12.                       (getdist
  13.                         (strcat "\n误差距离<" (rtos **GlobleFuzz** 2 3) ">: ")
  14.                       )
  15.                )
  16.              (setq **GlobleFuzz** d)
  17.              (setq d **GlobleFuzz**)
  18.            )
  19.            (setq ss (ssget "x" '((0 . "*line,arc,circle,ellipse"))))
  20.       )
  21.     (progn
  22.       (ssdel e ss)
  23.       (setq lst           (mapcar '(lambda (x)
  24.                               (list x
  25.                                     (vlax-curve-isclosed x)
  26.                                     (vlax-curve-getstartpoint x)
  27.                                     (vlax-curve-getendpoint x)
  28.                               )
  29.                             )
  30.                            (xdrx_pickset->ents ss)
  31.                    )
  32.             outlst (list (list e
  33.                                (vlax-curve-isclosed e)
  34.                                (vlax-curve-getstartpoint e)
  35.                                (vlax-curve-getendpoint e)
  36.                          )
  37.                    )
  38.             tf           t
  39.       )
  40.       (while (and lst tf)
  41.         (setq l1 (length outlst))
  42.         (foreach a outlst
  43.           (foreach b lst
  44.             (cond
  45.               ((and (cadr a) (not (cadr b)))
  46.                (setq p1        (vlax-curve-getclosestpointto (car a) (caddr b))
  47.                      p2        (vlax-curve-getclosestpointto (car a) (last b))
  48.                )
  49.                (if (or (equal p1 (caddr b) d)
  50.                        (equal p2 (last b) d)
  51.                    )
  52.                  (setq outlst (cons b outlst)
  53.                        tmplst (cons b tmplst)
  54.                  )
  55.                )
  56.               )
  57.               ((and (cadr b) (not (cadr a)))
  58.                (setq p1        (vlax-curve-getclosestpointto (car b) (caddr a))
  59.                      p2        (vlax-curve-getclosestpointto (car b) (last a))
  60.                )
  61.                (if (or (equal p1 (caddr a) d)
  62.                        (equal p2 (last a) d)
  63.                    )
  64.                  (setq outlst (cons b outlst)
  65.                        tmplst (cons b tmplst)
  66.                  )
  67.                )
  68.               )
  69.               ((and (not (cadr a)) (not (cadr b)))
  70.                (if (or (equal (caddr a) (caddr b) d)
  71.                        (equal (caddr a) (last b) d)
  72.                        (equal (last a) (caddr b) d)
  73.                        (equal (last a) (last b) d)
  74.                    )
  75.                  (setq outlst (cons b outlst)
  76.                        tmplst (cons b tmplst)
  77.                  )
  78.                )
  79.               )
  80.               (t)
  81.             )
  82.           )
  83.         )
  84.         (if tmplst
  85.           (foreach c tmplst
  86.             (setq lst (vl-remove c lst))
  87.           )
  88.         )
  89.         (setq tmplst nil
  90.               tf     (/= l1 (length outlst))
  91.         )
  92.       )
  93.       (setq outents (mapcar 'car outlst))
  94.       (setq s (ssadd))
  95.       (foreach x outents (ssadd x s))
  96.       (sssetfirst nil s)
  97.     )
  98.   )
  99.   (princ)
  100. )
发表于 2014-5-18 14:29:16 | 显示全部楼层
首尾相连的,不是很麻烦。能不能弄个像express里的fast select一样的功能?(fsmode模式设为on的那种情况)
 楼主| 发表于 2014-5-20 00:36:05 来自手机 | 显示全部楼层
不明白什么意思,没用过这个fs,不过既然有了为什么还要再写?
GMT+8, 2026-11-22 11:07 , Processed in 0.312619 second(s), 14 queries , Gzip On, File On.
