查看: 1477|回复: 0
[分享] File.AppendText
已领礼包: 859个
发表于 2014-5-17 19:08:53 来自手机 | 显示全部楼层 |阅读模式
File.AppendText
MSDN的例子
C# code
using System;
using System.IO;
class Test
    public static void Main()
        string path = @"c:\temp\MyTest.txt";
        // This text is added only once to the file.
        if (!File.Exists(path))
            // Create a file to write to.
            using (StreamWriter sw = File.CreateText(path))
                sw.WriteLine("Hello");
                sw.WriteLine("And");
                sw.WriteLine("Welcome");
        // This text is always added, making the file longer over time
        // if it is not deleted.
        using (StreamWriter sw = File.AppendText(path))
            sw.WriteLine("This");
            sw.WriteLine("is Extra");
            sw.WriteLine("Text");
        // Open the file to read from.
        using (StreamReader sr = File.OpenText(path))
            string s = "";
            while ((s = sr.ReadLine()) != null)
                Console.WriteLine(s);
GMT+8, 2026-11-3 06:04 , Processed in 0.431558 second(s), 28 queries , Gzip On.
